Question about Schwinn 250 Recumbent Bike
E-1 code on the 250 recumbent bike
Just bought the bike and turned it on and the code e-1 comes on
I've got a k6 1000,the f1 code comes up and when that does the bike goes off a cylinder,when I turn the bike off it goes back to normal again, any help would be great thanks
Hi, Adrian for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Suzuki, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
FI Fault Code List Dealer Mode Switch GSXR com
gsxr f1 codes
http://www.manualslib.com/manual/904423/Suzuki-Gsx-R1000.html
OEM parts for Suzuki
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
May 15, 2016 | Goes Motorcycles
How to assemble a weslo pursuit ct 4.2 bike video
Weslo Pursuit CT 4.2 Recumbent Cycle: Relaxing Exercise ...
www.kmart.com > ... > Recumbent Cycles
KmartSep 30, 2012 - Arts & Crafts · Video Games · Learning & Development · Stuffed Animals & Plush · Musical ... Weslo Pursuit CT 4.2 Recumbent Cycle 1 ... With a Weslo recumbent bike you can approach exercise with ease. .... Like all in box items it takes awhile to assemble, but works great, and great value for the money.
Weslo Exercise Bike - YouTube
? 2:55
https://www.youtube.com/watch?v=2ZLzpsk4BdE
Dec 22, 2014 - Uploaded by ReviewTube
Weslo Pursuit CT 2.0 R Exercise Bike http://amzn.to/1vgiQjF ...bike assembly,weslo exercise bike amazon ...
Weslo Pursuit CT 42 Recumbent Exercise Bike ... - YouTube
? 1:41
https://www.youtube.com/watch?v=tYdlVsnDNQo
Aug 20, 2015 - Uploaded by Geraldine T. Lane
SEE MORE Best Sellers in Exercise Bikes http://amzn.to/1frY7Yr The 3 Week Diet is an ... Weslo Pursuit CT 42 ...
Weslo Exercise Bike Product Support ' ManualsOnline.
Jan 17, 2016 | Weslo PURSUIT CT 4.2 Recumbent Cycle
How to replace the left crank on a schwinn 250 recumbent bike
Yes, special tools are required. Suggest you take to local bike shop for correct repairs.
Jun 25, 2014 | Schwinn Meridian Adult 26-Inch 3-Wheel...
How can I fix program screen on my Stairmaster 3800RC Recumbent Exercise Bike?
If you have not used your machine in about a year, most likely the battery is dead. You can find most of the parts you may need here:
Stairmaster 3800 RC Momentum Recumbent Bike Parts SPORTSMITH net
May 15, 2014 | Stairmaster 3800RC Recumbent Exercise Bike
Motorcycle will not start
My first question is did the bike work OK before it was stripped and painted?
It is possible paint has got onto the main earthing (ground) point on the chassis/frame. I would first check that there is a good earth connection from battery to frame and all light units. Other than the turn signals coming on do any other lights show when you turn the ignition on? If no I would try checking the battery. Remove the battery from the bike AND THIS IS MOST IMPORTANT remove the negative lead first then the positive.
Check the battery has voltage approx 12.5 to 13.2 volts is OK, next connect a 21 watt bulb to the terminals and see if the light dims over 1 minute. If OK get a dedicated motorcycle battery charger (a charger for a car is no good) with an output of less than 1 amp. Charge the battery for a few hours. Refit battery into your bike AND THIS IS MOST IMPORTANT TOO re-connect the positive lead first then the negative.
WARNING never try to jump start your bike from a car/van etc. The more powerful batteries in these vehicles will fry your bikes electrics.
ALWAYS use a dedicated motorcycle battery charger.
ALWAYS remove and refit your battery as stated above.
Good luck and hope this helps.
Apr 08, 2014 | 2006 Harley Davidson FLTRI Road Glide
Trouble codes
You may just have a stray fault, try to clear it and see if it returns: Key ON, Key OFF, Key ON, hit left turn signal 2 times wait for 2 flashes,,, hit right turn switch ONCE =>One Flash. Hit Right switch once =>2 flashes, Hit right turn switch once again =>3 flashes. Hit Left turn switch once than read codes to clear Hit left switch & hold for confirmation 2 flashes (hold at least 5 seconds).
If the code comes up again you've got a poor ground issue somewhere.
If you need further help, reach me via phone at https://www.6ya.com/expert/david_1f7d1c330c9dd97d
Apr 02, 2014 | 2002 Harley Davidson FLSTC - FLSTCI...
What are the benefits of recumbent exercise bike?
Recumbent exercise bikes offer a few benefits. First of all, they have lower back support, which is important for people with low back problems. Another benefit is that put less pressure on the knees compared to other exercise bikes. Moreover, if you have limited space available, these chairs are a great choice since they are very compact.
Feb 07, 2013 | Exercise & Fitness
Keeps defaulting to pause every 5 seconds
1) replace the batteries, and clean the contacts batteries with c. cleaner
2) adjust the REED switch, see the diagram attached, clean it and tight the connector very well.
3) tight the ribbon cable very well inside, and clean it with c. cleaner with carefully.
God bless you
Sep 09, 2012 | Schwinn 250 Recumbent Bike
What's better a recumbent or an upright exercise bike?
Recumbent bike works best for elderly people with back and hip problems because of the relaxed position and the angle that put's less pressure on those areas. Upright exercise bike works on more areas than the recumbent bikes including the lower abdominal muscles.
Aug 09, 2012 | Exercise & Fitness
Schwinn 250 Recumbent Bike Logo
81 people viewed this question
Top Schwinn Exercise & Fitness Experts
Steve
David Payne
David Payne
Matt Olenzek
Matt Olenzek
Are you a Schwinn Exercise and Fitnes Expert? Answer questions, earn points and help others
