Question about Singer Quantum 9910 Computerized Sewing Machine
My machine doesn't run although it is on
I have to jiggle the foot pedal's cord at the machine connection to get it to move.
  • Deborah Wright
    Deborah Wright May 06, 2014
    Deborah's do agree: You probably have a short at the machine side of the cord, which is loosing it's electrical pathway. You need to replace the cord by having it serviced at a SEW&VAC store or other authorized repair store.
  • matty_w May 16, 2014
    Actually, I believe that Deborah is referring to the whole foot pedal. Believe it or not there are not that many foot pedals out there, and yours should be easily and relatively inexpensively replaced. My favorite method is to go to eBay and type in that model, and most of the time, SOMEONE is offering a replacement foot pedal for your machine. Alternatively, you could try Sewing Parts Online; they have a comprehensive list of parts that they sell.
  • Singer Master
  • 7,365 Answers
The plug that connects the foot pedal and machine needs to be checked to see if there is a short
Posted on May 05, 2014
  • 5 Answers
SOURCE: singer 2010 doesn't want to stop
I have a Singer Merritt 4530.  I don't know if the foot pedal works the same way on your model, but on mine it is held together not by screws or latches, but simply by white plastic rods that serve as hinges.  These rods have a hole drilled in their center, presumably so some special tool can be used to pull them out.  Lacking a special tool, I glued a nail into the hole, and once the glue dries you can pull the nail and pull the rod out with it.  The rod is about an inch long and held in place merely by friction - no glue or screw threads.  Once one rod is removed, you should be able to slide the pedal off of the rod on the other side, though that might have only worked because some of the plastic housing was cracked on mine.  If you don't want to take the time to test that, just glue a nail into both rods and pull them both out.
Once you get the pedal open, mine had a giant white cylinder that looks kind of like a battery or a fuse.  This thing was getting very hot the longer the pedal was left plugged in.  I read on many web sites that this object can cause overheating or short circuit the pedal so it's always sewing.  It's called a suppressor and can be safely thrown away.  I haven't found an explanation for precisely what it does or why it can be safely thrown away, but I theorize it's a surge suppressor and that most modern wiring isn't going to surge too much.  I got rid of it and the pedal still works and doesn't overheat.  It may be safest to plug the machine into a surge-protected power strip once the suppressor is gone - just my theory.
Posted on Jun 16, 2009
  • 980 Answers
SOURCE: I have a singer 514. I recently got a new foot
Sounds like you need to open the foot control and adjust the carbon bar, you will soon see it, just undo the screw and move it away from the contact or adjust the screw in the end.
Posted on Sep 13, 2009
  • 109 Answers
SOURCE: Singer 2259 - The machine has stopped moving, the
Check to see if you have your bobbin winder on. That's usually the problem. Just push it to the left and you should be ok.
Posted on Sep 11, 2010
  • 1788 Answers
SOURCE: Singer sewing machine will not operate. push foot
Make sure that your bobbin winder is pushed all the way to the left (sewing position) and that you have selected a stitch pattern and the length is not on zero.
Posted on Dec 14, 2010
  • 111 Answers
SOURCE: trouble shooting a Singer Athena
Yes it's true, most parts are not available for this machine anymore. You might try to push the red reset button on the bottom of the machine. Also make sure that the reset button is not being depressed by anything that the machine is sitting on, and that the reset button pushes in and out freelyl.
Posted on Apr 30, 2011
Will a 6440 foot pedal and cord work on a 6460 Viking sewing machine
According to this site (although the parts are no longer available), it looks like the same foot control will work on both machines:
Foot Control Cord Viking 4116405 02
Dec 29, 2016 | Sewing Machines
What would cause my Kenmore sewing machine's light to turn on but the motor seem to have no power?
The wiring for the older Kenmore is simple. The light switch completes the connection to the light. If the foot pedal has failed or connection loose where the wire attaches from the foot-pedal the motor will not run.
Also if the brushes in the motor are worn or failing to contact the motor internally the motor will not run.
With light on and pedal partially depressed attempt to activate motor to determine if brush connection are faulty. If the motor reacts at all the brushes will likely need to be replaced.
No success borrow a foot pedal from a friend or sewing center to determine if the pedal control is faulty.
Hope this helps?
Oct 15, 2016 | Kenmore Sewing Machines
Pneumatic air foot petal
If the machine won't work with two pedals that are good then the problem isn't the foot pedal. Does the light turn on? If this is functional then you know there is "electricity" attached to it. Since both pedals aren't functional you will have to have the motor and connecting cord (inside machine) to see which is the problem. By the way; if the problem is the cord inside the machine you may not want to plug it in. You stand a chance of getting shocked. Have it checked for safety.
Sep 27, 2016 | Sewing Machines
Viking 980 foot pedal not making contact with machine although machine has power.
It could be lint jammed into the jack the cord plugs into. Make sure the jack and plug are both clean and free of lint. It also could be a damaged cord. If a friend has a working Viking pedal try borrowing theirs to see if it works on your machine. If not, your machine might need service.
Sep 15, 2014 | Husqvarna Viking 1
Are you sure the cords are not broken inside the wiring? It happens to lots of electronic things.
Brother serger slows down
it could be the motor or the power cord or the foot pedal,
check to make sure the power cord and the
foot pedal are connected correctly to the machine.if they are
then the machine and power cord and foot pedal need to be
checked
Nov 13, 2012 | Brother 1034D Serger Sewing Machine
Foot pedal doesn't work when pressed
you can either have that foot pedal checked or buy a new one
sewing machine parts
sewingpartsonline.com
sew4less.com
sewusa.com
premiersewing.com
ebay
Apr 12, 2012 | Sewing Machines
Why isn't my husqvarna foot press not connecting giving power for my needle to move. Machine does have power but does not run when pressing foot press.
have you checked to make sure the foot pedal is connected correctly to the machine?
if the foot pedal is connected correctly, then the machine needs to be checked to see why it's not responding
Mar 27, 2012 | Sewing Machines
Singer Quantum 9910 Computerized Sewing Machine Logo
110 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
