Question about Sony VAIO VPC-L111FX/B 24- Inch All-in-One PC (Black) PC Notebook
Screen shadow and poor resolution
Screen majority of time has terrible resolution and shadows and sometimes has mediocre resolution. Recent move may have loosened connection. I am accustomed to getting into the tower style CPU box and check card seating. Don't know where to start on this one.
  • Sony Master
  • 3,320 Answers
In the desktop screen, click the right mouse button. click on Screen resolution in the drop down menu.
See what the resolution is set at. There should be a recommended setting. Try that. Try other resolutions and see if the condition changes.
In the Start menu, click the right mouse button on Computer.
Click on Manage in the drop down menu.
In the left hand menu choose Device Manager.
Click on Display adapters
The adapter in your laptop should be displayed.
Click the right mouse button on the specified adapter.
Choose Uninstall.
When the uninstall is complete, either reboot or Scan for Hardware changes.
This will reinstall the adapter drivers.
You may have to update the drivers.
Make a note of the adapter and model. Search Google for that make and model or go to Sony's site and find the drivers for your laptop. Reinstall or update the drivers.
If all this fails you may need a hardware technician to work on your system.
Posted on Mar 23, 2014
2 Suggested Answers
walesarumi
  • 6993 Answers
SOURCE: Hi: My Sony VGN FZ180E was dropped, OS won't boot
the problem should be from the Hard disk of your system. While it fell, the hard disk might have disconnected or has shifted and not properly fitted to its rightful position when the system dropped.
Turn of your system, remove the battery, then pull out the hard disk and fix it back into the system properly. Make sure its firm, couple it back, fix in the battery and try again.
Once your OS refuses to boot, the hard disk is the first thing to be checked. I believe the problem is from the hard disk part of your system.
Good luck.
Posted on Oct 09, 2010
Sony kdf-e50a12u rear projection lcd bravia. red shadows
This is due to you having a projection tv, some projection tvs are really bad for game playing and especially if you have a hdtv. even in the p23 manual it says that you shouldnt use with a projection tv cause it can damage your tv's screen permanently. I personally still play mine but, thats likly the problem.
Aug 11, 2007 | Sony KP-61HS10 61" Rear Projection...
LC-x50 has double vision or shadowing. What can cause this?
several reasons : 1.check cables, if too long and poor quality you get echoes in signal and shadows in the projected picture.
2.feed the right solution to the projector and adjust in menu pc adjustment the item FINE Sync. native resolution is 1024 x 768.
Jan 16, 2011 | Eiki LC-X50M Projector
Viewsonic VX2260wm has a shadow on the right side of the screen
install an AGP card in the AGP slot because internal display card of the motherboard does not support to high resolution because of insufficient memory . use 8X display card for the better result ..
Apr 18, 2010 | ViewSonic X Series VX2260wm 21.5"...
43'' SAMSONG FLAT SCREEN. SHADOWS RADOMLY APPEAR
Is your tv a plasma tv or an lcd tv? When you say shadow, do yo mean a band across or down the screen, or is it a patchy shadow?
Mar 17, 2010 | Televison & Video
My 2004 Honda shadow aero vt750 is running poorly. It only idles with the choke nearly fully engaged. I have added carb cleaner and changed the plugs. What else should I do?
has the bike been sitting for a time ..sounds like the carbs need pulled and cleaned..you could try draining the fuel out at the float bowls there should be drain screws at the bottom there could be dirt or water in them sometimes this will help without pulling them ..good luck
Aug 02, 2009 | 2006 Honda VT 750 Shadow
Acer AL 1912 (black) resolution issue
[u][b]LCD Monitor Shadow Effect[/b][/u]
This problem is best described as the LCD monitor "Shadow Effect".
The solution to this very simple. No software or hard ware changes required.
The cables that are connected to the LCD monitors are causing the problem. Its also called as electromagnetic noise or electrical noise.
[u][b]Solution: [/b][/u]Keep the two cables - (power cable and moitor display cable), that are connected to the LCD monitor as far away as possible with each other and also away from other electrical cables.
Thats it. Your shadow effect is fixed.
Thank you.
May 27, 2009 | Acer AL1912 19" LCD Monitor
I have a WS-55807 and a bad shadow
either you crossed some wires or you jared the lamp adjustment so it is not projecting right!
May 18, 2009 | Mitsubishi WS-55807 TV
Desktop icon shadow in acer monitor as 1024*768 resolution
go into your graphics card config and change the brightness levels
Feb 03, 2008 | Gateway FPD2275W LCD Monitor
Sony VAIO VPC-L111FX/B 24- Inch All-in-One PC (Black) PC Notebook Logo
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
