Question about Audiovox BA100 Car Subwoofer
I have RCA preout connections at the back of my Kenwood CD player and I am needing to know do I connect here or do I just tap into the Rear Speaker wiring to power the + and - connections on the Subwoofer ? I currently have it connected to the rear of the CD player at the RCA plugs but the subwoofer is not functioning ... Thanks for your help ..
  • 365 Answers
If I understand you right, you should be running a single wire to the amp in addition to the RCA's
Posted on Jun 14, 2009
Kenwood how to connect
You need a stereo mini to RCA cable to connect the laptop's headphone audio jack to the Kenwood. Here is an example of one below. They are very common and available at just about any electronics store for a few bucks.
http://www.amazon.com/Gemini-PH62089-Stereo-Mini-Male-RCA-Male/dp/B0001GAOE0
The Kenwood receiver should have a number of red and white "RCA" audio connectors on the back.
Just connect the RCA portion of the cable to a spare input. They should be clearly marked on the back of the unit and color coded (red for right channel and white for left channel). But it really doesn't matter if you mix the right and left up, it will still make sound.
EX:
Most receivers will have inputs that are labeled "CD" or "Aux" that you can connect any audio source to.
If you connect your laptop or an MP3 player to the audio input connections labeled "CD" behind the Kenwood receiver, you can listen to the device by selecting the CD as the source.
It is really easy!
May 04, 2014 | Kenwood VR-305
Need a stereo wiring diagram
Hiya,
Here's the wiring connections for the Kenwood KDC-3025.
Black: Car chassis (-) ground wire
Yellow: Battery (+) wire (must connect to retain memory settings)
Red: Ignition/Accessory wire
White (w/black stripe): Front Left speaker (-)
White: Front Left speaker (+)
Gray (w/black): Front Right speaker (-)
Gray: Front Right speaker (+)
Green (w/black): Rear Left speaker (-)
Green: Rear Left speaker (+)
Purple (w/black): Rear Right speaker (-)
Purple: Rear Right speaker (+)
Blue (w/white): Power Control wire (used with ext. amp only). Do not expose this wire, if no amp is used.
Blue: Antenna Control wire
Brown: Telephone Mute wire (used with handsfree carkits).
Hope this helps,
Cheers,
Scott
Feb 01, 2013 | Kenwood Sirius KDC-3025 CD Player
MY KENWOOD CAR CD PLAYER IS SAYING PROTECT??
Kenwood head units show "protect" when there's a problem with the speaker outputs. This might mean a shorted speaker wire, a blown speaker, or an internal defect in the head unit. Once the condition that's causing the "protect" mode is fixed, the CD player should be back in normal mode the next time you turn it on.
If it's staying in "protect", then you'll definitely have to remove the stereo and do some troubleshooting to fix it. Many car audio stores will do system troubleshooting, for a fee. If you want to do it yourself, here's what you need to do:
Pull the Kenwood unit from the dash and disconnect all the speaker wires. Turn it on and see if the "protect" message displays. If it does, the stereo has an internal defect and will need to be serviced. If it doesn't, then turn it off, and re-connect one speaker. Turn it on again and see if it displays "protect".
If it works with a single speaker connected, keep re-connecting the others until you identify the speaker that's causing the problem. There may be a wiring problem or defective speaker in that location.
If it displays "protect" with a single speaker connected, then disconnect that one and try a different one. If all the speakers cause a "protect" mode, then you're probably back to a defective head unit, unless your friend managed to blow all your speakers at once.
Thanks,
Dec 09, 2009 | Kenwood KDC-319 CD Player
I have a kenwood kdc-w3541 cd player and would like to wire it to a 4ch amp can you tell me how to wire it....thanks
Your kenwood only has preouts for a subwoofer. If you want to add the amp the amp will need to have some high inputs. If it does not then you will need to buy an accessory that will allow you to connect speakers and have rca outputs. From there yo will need two sets of rca jacks to run to the amplifier.
Nov 07, 2009 | Kenwood Car Audio & Video
Cant get bass, fuse is fine
You don't say if you've configured the Receiver to know you have a subwoofer (under Multicontrol - SUBW YES). Unless it knows about the Sub it won't send anything out that single "preout". You can get an RCA splitter to run that single output to both inputs in the Sub.
Just as an experiment, temporarily run one a pair of cables from the REC OUT to the Sub's inputs and tune an FM station to prove the Sub amplifier is alive. If it's still silent, it's dead. If there is sound (muffled) you need to go back to the Receiver to figure out why the Sub Preout is signal-starved.
May 16, 2009 | Kenwood Audio Players & Recorders
HOW DO I INSTALL A RCA ADAPTER TO MY VEHICLE
There should be a diagram entitled "adding and amplifier to a factory stereo" in the owner/install manual of the high to low convertor. You need to signal tap some audio signal from your front or rear stock speakers in the car and those wires need hook up to the high to low convertor's input side. From the convertor you connect RCAs that go to your amp. In other words find your rear speaker wires and hook them to your adapter then hook up the rca wires
Dec 02, 2008 | RCA Pie Pio/P Rca Adapter P Bus Mcd To Aux...
Pioneer DEH-P3000IB... Hook up RCA cables to 2, 2 channel amps for front and rear control. Supposed to be able to set rear to either rear full or sub... can't find how and all I'm getting is sub response.
Here are the directions according to the manual:
1 Use MULTI-CONTROL to select
SW CONTROL.
2 Press MULTI-CONTROL to display the
setting mode.
# Press BACK to return to the previous display.
3 Press MULTI-CONTROL to select the segment
you wish to set.
Press MULTI-CONTROL repeatedly to switch
the segment in the following order:
REAR SP (rear speaker setting)—PREOUT
(RCA output setting)
4 Use MULTI-CONTROL to select the desired
setting.
Turn to change the setting.
When REAR SP (rear speaker setting) is selected.
REAR SP:SUB W(subwoofer)—REAR SP:FULL
(full-range speaker)
When PREOUT (RCA output setting) is selected.
PREOUT:SUB W (subwoofer)—PREOUT:REAR
# When no subwoofer is connected to the rear
output, select REAR SP:FULL.
Hope this helps.
Oct 13, 2008 | Pioneer Audio Players & Recorders
Kenwood KDC-X590 CD Player
what do you mean by one set is a hard wire and other is an rca jack?the hard wires go to the speakers and the rca is wired to an amplifier of some sort which is wired off to more speakers or subwoofer(s)
Aug 12, 2008 | Kenwood KDC-X590 CD Player
Car audio
Yes you can use the speaker output in conjuction with the rca pre-outs...but depending on the wattage of the amp, there may be a big difference between the loudness of the front speakers over the rear speakers. If you have a 4 channel amp you can put the rear speakers on the amp also and lower the input gain for the rear speaker. Or if you have a 2 channel amp, you could use a passive crossover to filter out some of the bass to the rear speakers since they are smaller, this would help prevent over-driving them...as it is normally too much bass that distorts and blows a speaker. I'm not sure what you are asking about the hi-rear preouts vs the mid front pre-outs. If you decide to use the amp for the fronts you should be able to connect the amp from the front preouts of the deck. Hope this helps.
Mar 30, 2008 | Audio Players & Recorders
Only sound out preouts only
Power amp ic is more then likely defective I may be able to get you a service manual kstahl65@att.net
Jan 23, 2008 | Kenwood KDC-X717 CD Player
Audiovox BA100 Car Subwoofer Logo
221 people viewed this question
Top Audiovox Car Audio & Video Experts
xxxxxx xxx
Jaime Hernandez
Marvin
Marvin
Are you an Audiovox Car Audio and Video Expert? Answer questions, earn points and help others
