Question about Epson - PowerLite S1+ Multimedia Projector
Settings to create short throw rear
I have done simple setting changes to turn my projector into a rear projector. However, I want to use it on the back of a stage projecting onto a rear proj. screen only about 8 feet in front of my PowerLite. Are there settings I can change to make it project large onto this 6'x8' screen?
  • Epson Master
  • 10,291 Answers
You'll need a short throw lens.
Posted on Mar 23, 2014
Mitsubshi sl4su
THis is a very short throw even for a "short throw" lens. I would verify that this is the proper lens by its numbers and verify what you should be seeing by its tech specs (focal distance./image size to be expected)
Jan 09, 2013 | Mitsubishi SL4SU ColorView Multimedia...
Upside down picture
turn the projector up the other way,
or
Press the Menu button.
Select the Advanced menu. You see the features and their settings on the right side:
Press Enter and use the directional buttons and the Enter button to set the following option:
Projection
Front: Projector is in front of the screen
Front/Ceiling: Projector is in front of the screen, mounted upside-down from the ceiling
Rear: Projector is behind the screen
Rear/Ceiling: Projector is behind the screen, mounted upside-down from the ceiling
Feb 22, 2011 | Epson EMP-54 Multimedia Projector
I have the mp771 model. My set up: 2 benq mp771 and 1 mitsubishi ew223 short throw. The 1st mp771 is the left projector, the 2nd is the mitsubishi (center) and the other mp771 is the right projector all...
Swap the two MP771s over and see if the fault lies with the projector or not. If the problem image swaps over then your two projectors are behaving differently. Perhaps a factory reset might help.
I'd say that it is more likely that the problem lies with your graphics card settings rather than the projector. Projectors, in general, have a native resolution. Most of them will accept non-native resolutions and interpret them to fit, but the actual resolution of the projector can't change. Triple Heads to Go are quite tricky to setup. You should check the TH2G manual and see that the screen resolution which you are attempting to use is supported, the analog versions are quite particular.
Adjust your graphics card settings and see if that helps (This is where you will find the solution!). You need to compare possible settings with those of the TH2G and the projectors (The projectors get 1/3 if the TH2G accepts and splits the signal properly). You should be able to view the actual projector input settings to see how they compare to what you expect.
Start at the lowest 12x3 screen resolution that the TH2G will accept and see if that helps. Make sure refresh rates are set to match too.
It can be a fiddly process, however once you find the correct settings then it should all work great for you.
Feb 20, 2011 | BenQ MP771 DLP Projector, 1024x768 XGA...
Upside down images
the projector will project 4 image configurations: front, rear, ceiling front, and ceiling rear. go into the menu, under settings, and change it from ceiling to front.
Jan 07, 2010 | InFocus In2102 Projector
Why is the image reversed?
the projector has 4 settings: front, rear, ceiling, and ceiling rear. yours is set for rear projection. go into the menu and change it to front.
Jan 05, 2010 | Sharp Office Equipment & Supplies
Menu flipped on screen
Hi Andy!
Yepp, you can do that, each and one of your projectors have separete settings. So you can run one hanging from the roof and the other one standing on a table if you want. How the picture is showing depends on how you set up the the settings in the specific projector. The the signal that comes to the projectors are always the same, its only the settings on the projector that can change that.
Good luck
Nic
Apr 22, 2009 | Sony VPL-CX85 Multimedia Projector
How do I make my projector image "square"?
i Believe you need to go into the projectors settings and adjust what is called the keystone, this changes the tilt effect that the projector throws, just keep messing with that setting until you get it how you like it.
Mar 05, 2009 | Sharp NAVITAR 1.2 INCH BUHL LCD LENS,...
My picture is up side down on projector model--EB-X6
PLESE GO TO SETTINGS MENU AND YOU CAN FIND REVERSING OPTION . sELECT THAT.
Jan 21, 2009 | Office Equipment & Supplies
Infocus projector, words projects backwards
change the orientation from rear to front in the menu
Dec 29, 2008 | InFocus In2102 Projector
Epson - PowerLite S1+ Multimedia Projector Logo
62 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
