Reddy heater pro 110
I have a reddy heater R110 spark plug will not fire. I have already installed new transformer. Can anyone help with this problem?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 56 Answers
Check that power is getting to the transformer, if so test the transformer for continuity. if it is good look for a short in the high voltage(spark plug) wire, and that one side of the secondary is connected firmly to the chassis of the heater. if no power to the transformer then trace the wiring to find the defect.
Posted on Mar 24, 2014
tbugger
  • 232 Answers
SOURCE: reddy heater pro 110
Does your heater use the older spark plug technology or the newer Hot Surface Ignitor (HSI) technology?
Without this critical information about all this technician can do is guess.
My best guess at this time would be either water in the fuel or a restricted fuel filter.
Posted on Nov 01, 2008
My best guess is that you are are connecting to your AC receptacle with an extention cord that is too small. The Reddy Heater contains a computer that will shut the unit off if it cannot pull enough amps from your service. The longer the cord the higher the loss from receptacle to unit. This loss can be reduced by increasing the size of your extention cord. I run a 100' 10/2 cord.
Hope this helps!
Handy Home Guy
Boone, NC
HandyHomeGuy.com
Posted on Nov 22, 2008
tbugger
  • 232 Answers
SOURCE: reddy heater will not fire.
Your problem is most likely the lack of pressure from the air pump. Your pressure is extremely low. Pressure on a 100k heater should run 5psi. At 3psi there is not enough fuel and not enough air to atomize whats there. Bump the pressure up. If it won't come up, then you have an air leak. Test w/ soapy water. Keep your fingers clear of the fan!
Posted on Dec 04, 2008
Need parts for readdy Heater Pro 110 New
Posted on Jan 08, 2009
SOURCE: reddy heater pro 110 started up ok went to use it
cleaned electrodes , filter and sensor oiled fan motor
Posted on Dec 13, 2009
Ready heater r110 I have replaced nozzle, filers all, cleaned sensor, runs some times for 30 sec shuts down
The R110 is a spark plug heater, as you know. It does not have the sophisticated electronics that the newer heaters have.
My guess: SP heater runs 30 seconds & shuts down- bypassphotocell. If it runs fine, then the photocell is defective.The test is simpleIf the photocell proves to be good follow these troubleshooting tips
Oct 13, 2011 | Reddy Heater-30-55,000 BTU Variable
My Reddy Heater R110 will not fire up. motor runs but doesn't seem to spark. fan runs for a couple minutes then the reset goes off. It has a new spark plug and filter
samsclassics,
I have a tip at http://www.fixya.com/support/r4124129-yearly_maintenance_reddy_heaters which explains the problem, how to fix it and where to get the parts.
Thanks for using FixYa and for the great rating. Please consider a testimonial. Thank you.
hardrocko
Jan 19, 2011 | Reddy Heater- Variable 75,000-125,000 BTU
Reddy heater pro 110 started up ok went to use it
Dec 10, 2009 | Reddy Heating & Cooling
I have a Reddy Heater Model R110. It has operated great until it ran out of fuel. I filled it up and now it will not ignite. It is pumping fuel as fuel is running out the front of it. I cannot find my...
remove the cover and check for spark at plug when plugged in if no spark check spark plug gor proper gap, or defective transformer electronic ignitor if you see spark check for proper pump pressure and restricted fuel flow due to seal leak, filter blocked and restriction in nozzle. I would check for defective photocell first for soot/dirt if dirty wipe with clean damp cloth remove photocell from heater and connect ohmeter on the 1000 ohl (rx1k) scale. Hold the lens up to a light source (60 wtt bulb, with the lens of the photocell pointed towards the source the resistance of the meter should be low by clocking off the light source by putting thumb over opening of cell the resistance on meter should be high, replace photo cell if a change in resistance is not observed during this test, let me know if you need more assistance
Dec 07, 2009 | Reddy Heating & Cooling
My reedy heater pro 110 blows fuel out the front but does not ignite and then shuts down
The Pro 110 comes in 2 different technologies. The true model (examples: R110, RHD110T, etc) designates which technology your heater has. Rather than ask for clarification I am posting links to Troubleshooting Tips for BOTH types. You must investigate to see if your heater is the Spark Plug technology or the HSI (glowbar) technology.
Troubleshooting greatly differs between the 2 types.
Spark Plug Tips
HSI Tips
Nov 15, 2009 | Heating & Cooling
Model R110 Does not ignite on startup
Check:
  1. be sure the transformer is grounded
  2. If 110v is going in but nothing going to the plug then order an Ignition Device #102482-01
www.reddyparts.com keep them in stock
Dec 25, 2008 | Reddy Heater-30-55,000 BTU Variable
Reddy Heater will not ignite flame
Please answer the following questions. There are several folks on the board that can help but we need to know some vital information so we can get started. Answer these, if you can:
  1. Which Pro 110 do you have. We need the exact model number. Pro 110 is a series of heaters.
  2. Does the heater have a spark plug or a glowbar (HSI)?
  3. When the motor runs is it pumping fuel?
  4. When the motor runs is the spark plug firing (or glowbar glowing)?
Nov 13, 2008 | Reddy Heater-170,000 BTU Kerosene Deluxe
Nov 01, 2008 | Heating & Cooling
Jan 14, 2008 | Reddy Heater-30-55,000 BTU Variable
Heating & Cooling Logo
89 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
