Question about LG 47LE5400 47 in. TV
HDMI ports not working. Possible lighting damage
How do I replace the HDMI ports
    Habit-Forming:
  • 84 Answers
I've seen alot of TV's with blown HDMI inputs. They seem to be easily damaged by power surges. If you are good with electronics repairs, you can locate the HDMI input chip on the main board of your TV and replace it. It is quicker and easier to locate a replacement main board on Ebay or Shopjimmy and just replace the whole board. Just make sure you buy the exact same board .
Posted on Mar 23, 2014
HDMI ports are not more working on my LG tv set.
If all the HDMI ports are faulty then the problem is probably a damaged HDMI cable.
The thin wiring in cheap HDMI cables can break after a time due to flexing. Make sure you replace the cable with one that is both sturdy and long enough to prevent flexing.
Buy from high street retailers like Currys or Argos who will replace any faulty goods.
Feb 07, 2017 | LG Televison & Video
46 inch Sony Bravia TV is 5 years old. HDMI ports 1,4 work fine but 2,3 don't.
I presume you've checked that the HDMI cables are good, and that the signal sources (e.g., blu-ray player, Roku, etc.) are working correctly. If the HDMI ports are individually selected by four buttons on your Sony remote, which is unlikely, it's possibly a problem in that remote. It's also possible that ports 2 and 3 are physically damaged by abuse. If you have ruled out all of those potential causes, this is almost certainly a problem in the way the defective ports are attached to the underlying printed circuit board inside the TV, or a flaw in that PCB. Too bad it's out of warranty. Repairing this will be a hassle if it can be done at all, and probably not cost effective. Instead, I suggest three possible workarounds for your consideration.
First, if you can find another way to get the signals into your TV, such as using the component inputs instead of HDMI, that will your cheapest and easiest alternative. This will only be doable if the signal source offers other types of outputs besides HDMI. Note that I am NOT suggesting adding any type of signal converter, just a different way of connecting the signal source to the TV.
A second alternative is to buy a multi-port HDMI switch with a remote control which you can find for less than $30 at online retailers like ebay. Plug that switch into one of your two good HDMI ports, and connect your unserved signal sources to the switch. It will be slightly less convenient to use the multi-port switch because you will need to operate one more remote control than you do now.
The third possible workaround is to buy an autosensing HDMI switch instead of the multi-port type, which would eliminate the need for the extra remote. However, an autosensing switch must have only one signal source active at any given time. This may not be possible if one of your signal sources is a streaming device that is continuously powered up. Good luck!
Mar 01, 2015 | Sony Televison & Video
Phillips hdmi ports not working
Yes,
When 1 HDMI port is broken most of the time all the ports are defect. This is because all the 3 HDMI ports are connected to 1 multiplexer IC. Only when the connector or the copper connection on the board is damaged the other two ports still be functional.
You still can use the other connections ( not HDMI) the should be working.
Regards GJ
Jun 14, 2014 | Philips 42PFL5332D 42 in. LCD Television
HDMI quit working Component still works- Possible lighting spike- is this repairable
Check and replace damaged component/s in the HDMI section circuit. The maim board might need replacement.
Jan 24, 2013 | Samsung LN-S4692D 46 in. LCD HDTV
Can a tv working normally after been stuck by lighting
In most cases no, depends on level of surge. I've seen cases where a surge came in through an HDMI cable and take out the HDMI port on a TV, everything else worked. I've seen cases where a surge damaged multiple boards on a set. So again it depends how how big of a surge, and whether the surge comes in through the power cable or an video/audio input.
Sep 07, 2012 | Toshiba 40WL753B Regza Wl 40 Inch Full Hd...
HDMI PORTS NOT WORKING
Try visually inspecting HDMI’s that are not working. Occasionally, pins on HDMI connectors are getting bent or pushed-in. If you can spot the damage, fix would be to replace HDMI connectors. If connector are not damaged, then main unit of the TV has to be replaced.
Jan 06, 2010 | Televison & Video
I cannot get the Input 3 HDMI port to work. The Input 3 Componet videoworks, but when I unplug the componet video and put in HDMI port nothing works. I do have something else in the HDMI Input 1 port...
Hi.
To start ensure that each time you connect or disconnect the HDMI ports both TV and connected device are off.
Also ensure that HDMI input is active, as detailed here.
HDMI connectors carry voltage, and connecting the HDMI cable while TV or device is on may easily damage the HDMI port, making it unusable.
The HDMI 3 and Component 3 are separate input. The component input may work, and HDMI port may still be defective.
To test the port do the following:
Disconnect TV power cord, and connected device (eg. Receiver, DVD etc.).
Leave units disconnected for five minutes.
While power is disconnected, test connecting on port three a device that was previously working on HDMI 1. Also use a cable that you know is working.
Connect back power with HDMI cable already connected. If HDMI 3 is still not detected, then the port is defective.
In that case ring Pioneer at the number listed on the owners manual.This model is often advertised as only two HDMI inputs. Call Pioneer to ensure the third port can be enabled.
Dec 26, 2009 | Pioneer PDP-4350HD 43 in. Plasma...
Hitachi l42vpo1u no sound through hdmi
HDMI port damaged, mainboard need to be replaced.
But be absolute sure your HDMI port is not working properly, I recommed you try it again with another HDMI cable, you can also try same cable in another TV.
Bye
May 18, 2009 | Televison & Video
Onkyo TX-SR605 hdmi output jack was damaged and needs replacing. A) Where can I get the part and how much for it? B) Does the replacement part require solder or is it a snap in type connection?
The hdmi output and inputs are on a modular circuit board that you only need a philips screwdriver to swap out. I need this board as well since I also have a damaged hdmi output jack but have not been able to locate the replacement board. If anyone knows where to look I would appreciate knowing.
Apr 25, 2008 | Audio Players & Recorders
LG 47LE5400 47 in. TV Logo
396 people viewed this question
Computer Repairing
Computer Repairing
