Question about Epson - PowerLite S1+ Multimedia Projector
Rear Projection short range
I need to use my Epson PowerLite S1+ on a rear stage with the rear projection screen (6'x8') only about 8' in front of projector. Does this model have settings to allow it to be a short throw projector?
    Sergeant:
  • 223 Answers
Focus?
Posted on Mar 23, 2014
zabolyx
  • 38 Answers
SOURCE: epson powerlite s4 projector is pink
I assume this is an LCD. I don't remember the s4 being a DLP projector.
This sounds like the LCD panel used for the red color has gone out. The image is made up of red, green and blue images layered upon the screen. If the red panel has gone out then there is nothing filtering out the red light in the image. This causes a nice red hue to the whole screen.
It could be a simple open and reconnect fix. I personally have never opened a projector, so I'm not going to walk you through it as I do not know how hard it would be to tinker with. It should eb a cheap fix for a true repair man though.
Posted on Apr 01, 2009
  • 110 Answers
SOURCE: Epson PowerLite S1+
You have not set the port on the back of the projector settings.
Go into the projector menu and go into the IMAGE area. Somewhere in here you should be able to select computer.
Posted on Aug 22, 2008
dhiman
  • 115 Answers
SOURCE: the powerlite S1 projector has
check the fly eye lens and then Lamp unit. Service and check the LCD panels.
Posted on Jan 12, 2009
  • 144 Answers
SOURCE: need a projector that works from the BACK of the classroom
use digital zoom
Posted on May 08, 2010
gmontgome595
  • 225 Answers
SOURCE: Epson 460 powerlite hooked to smartboard green light blinking and no image.
Yes this is most likely the lamp. Does it eventually go back to just a red light?
Posted on Dec 06, 2012
Epson powerlite 84 dim projection dim projection
check them :
The lens
the lcd panels
the polarizer
May 18, 2012 | Epson Corporati PROJECTOR, EPSON,...
How do I flip the image
Go to the menu, and select the extended option, then select projection.
Then choose front or rear and ceiling or normal orientation.
If you select a ceiling option then the unit will require a longer cooling period after you switch it off.
Aug 13, 2011 | Epson PowerLite 1716 Projector
Need to know how to invert a picture on a epson projector
You didn't give your model, but on the Epson I have (a PowerLite S1), the projection mode is controlled through the "Settings" menu. This may not be right for your model, but I'd think another Epson would be similar.
On mine, this is how it works:
1) Press "Menu" on the projector (or remote, which will work the same way)
2) Use the "V" (down arrow) to highlight "Setting"
3) Press "Enter" to select the "Setting" menu
4) Press "Enter" to select the "Screen" sub-menu
5) Down-arrow to "Projection" and press "Enter" to select it
6) Use the up- and down-arrows to highlight the arrangement you want from the choices offered:
  • "Front": normal use
  • "Front/Ceiling": image is vertically flipped
  • "Rear": image is horizontally flipped
  • "Rear/Ceiling": image is flipped both horizontally and vertically
7) Press "Enter" to select
8) Press "Menu" to exit the menus
I hope this works for you, or at least gives you a starting point. Good luck, and thanks for using Fixya!
Apr 23, 2011 | Computers & Internet
I hooked up my Think Pad laptop to an Epson EMP-74 and the image projected is upside down. How do I fix?
Do the following for setting the screen.
1. Press the Menu button
2. Select Projection
In the Projection option,
Select Front : When the projector is in front of the
screen.
Select Front/Ceiling : When the projector is in front of the
screen and suspended from the ceiling.
Select Rear : When the projector is behind the
screen.
Select Rear/Ceiling : When the projector is behind the
ok
Apr 06, 2011 | Epson EMP-74L Multimedia Projector
How can i flip the screen up side down on the projecter
Go to Menu> Extended> Projection> select Front ( to project from the front of the screen ).Front/Ceiling ( If the projector is mounted upside-down from the ceiling ). Rear ( to project from behind onto a transparent screen ).Rear/Ceiling ( to project from behind when the projector is mounted upside-down from the ceiling ).
Or you can hold down the [A/V Mute] button for about 5 seconds to change the projection setup from Front to Front/ceiling or Rear to Rear/Ceiling.
Mar 31, 2010 | Epson EMP-S4 LCD Projector
47"Epson Rear Projrction TV
turn power off.
let rest for 30 mins.
take off right front panel.
open door to lamp.
unscrew lamp.
pull out and replace.
might want to unplug set also while working on it.
Aug 01, 2008 | Epson Livingstation LS57P2 57" Rear...
Screen removal
1) Remove lower,front speaker grill
2) Remove screws along bottom edge of screen frame
3) Lift screen assembly off cabinet
4) Lay assembly face down
5) Remove just enough frame screws to get back in position--
    Don't force it----
6) Reassemble.........T.
Oct 28, 2007 | Toshiba TP55G90 55" Rear Projection...
Epson - PowerLite S1+ Multimedia Projector Logo
37 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
