Question about Samsung Galaxy S II Skyrocket
Lango not running
Keeps saying lango not running
    Producer:
    Uploaded 30 video answers.
  • Samsung Expert
  • 309 Answers
Reprograms ^_6
Posted on Jul 04, 2014
My mule will not keep running. Stopped suddenly after good start. Replaced the fuel pump. Still will not keep running. Fires. Then stops. Fires on starting fluid. What could it be?
When you say it fires with starting fluid can you keep it running with the starting fluid or does it just fire while cranking the starter then stop when the key is turned to run if it keeps running with the starting fluid then you still have a pump problem or the filter could be plugged or the carb could be bad but if it'd fuel injection then it might just not getting enough pressure fuel injection takes high pressure
Sep 18, 2017 | Cars & Trucks
I cannot keep this weed wacker running.
i do not think this is a voltage issue, this a wattage or power out is not enough power in watts to keep the weed eater running, you need to know what wattage the weed eater requires to run.
even though you have a generator that says it will run 3000watts, but in the generator only runs at 1500watts continuously running time until it runs out of gas.
know lets say your generate say 2000watts, that means you are only going to get 1000watts continuously unit you run out of gas.
Oct 05, 2015 | Electrical Supplies
Facebook technical support
Been locked out and can not remember one of the security question ,and can not get to log in
Jan 12, 2014 | Facebook Social Network
2004 dodge durango keeps running hot..i keep adding coolant then it stop for couple of days then start running hot again
If yo keep adding then you're obviously losing antifreeze somewhere. If it's not dropping on the ground then I'd say you have a blown head gasket and it's going out the exhaust. If you keep running it hot and it is a blown head gasket, sooner or later you'll warp the head or crack it, then you'll really be outting out the money for a fix.
Jan 29, 2013 | 2004 Dodge Durango
Compaq computer keep saying system is not fully installed please run setup againWhat's your problem?
Were you doing a system reload? and upgrade? If not reboot and try at pre boot/start up repeatedly tap F-12 to enter restore/recovery mode and restore or recover your OS.
Nov 09, 2012 | Compaq Presario Computers & Internet
I open LuckyWire and it keeps saying "An instance
I would do a CTRL-ALT-DEL and look at the processes running. If you can identify the process associated with that program, terminate it and you'll be OK.
Sometimes a program stops running and you can't see it on the task bar, but it's process is still running.
var fctb_tool=null; function FCTB_Init_d362655cb7f747479026eb127d6c68fb(t) { fctb_tool=t; start(fctb_tool); }
Feb 03, 2011 | LuckyWire
My nokia n73 keeps saying it is full but it isnt
Memory low will (possibly) be RAM running low.
I occasionally had it on my N73, but since updating to v4 haven't had the error once (had it regularly on v3, less said about v2 firmware the better).
Type in *#0000# to check the firmware - if its prior to v4, then run a firmware update via the Nokia Software Update.
Jul 12, 2010 | Nokia N73 Cellular Phone
Fg2000tc tried a 1000 watt jack hammer but overload alarm came on what to do
Your gen. is a 2000 wt max 1000wt running out put. Means it will start your jackhammer but will not maintain the wattage to run it long. You are using the max it has to put out. So let me try to explain - 2000 watt max output works like this - We will use a fan as an example. A fan sitting still and not turning takes more amperage/watts to start. that is called lock rotor amps. So lets say the fan is a 1000w to run. 2000w start the fan turning then it takes 1000w to keep it turning. Your gen. can start the fan but not keep it running it is using all it has to put out, now if that fan only uses say 750 w running watts you have some head room to keep it running with out things getting hot. Hope this is clear as mud.
Jun 06, 2010 | McCulloch 13HP 338 Cc Portable Generator #...
Dose the Lincoln 1989 Town Car have a relay switch
Under the hood you will see battery cable running to a terminal block. This is your starter solenoid. Tap on it lightly. If what you are saying is after the car is running the starter keeps running. You will need to replace it.
If you are saying the motor is running with the key on there is wires running to the bottom of the distributor.
Look for a round plug. unplug it. You have a rod that runs from the key switch. To a switch at the column. It may be bad.
May 17, 2010 | 1989 Lincoln Town Car
Samsung Galaxy S II Skyrocket Logo
26 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
