Question about 3ware Computers & Internet
Cannot find 3ware 8506-8 digitally signed driver for x64
I am trying to run a 3ware 8506-8 SATAII raid controller and cannot find a digitally singed driver anywhere
  • Eric Tucker
    Eric Tucker Mar 23, 2014
    I am running Server 08 R2 X64 on a Supermicro H8DAE2
Windows 7 driver needed
If you have Windows 7 32-bit, the XP driver will probably work. http://www.driverguide.com/driver/detail.php?driverid=754345 has a copy. However most copies of Windows 7 are the x64 version. To check your OS version, click on Start and choose the Control Panel from the right hand column. Click on the System and Security link and then the System link. Read the version information. If it ends with x64, you aren't going to find a driver. You can try the compatibility mode with this driver but it often doesn't work for drivers. (Right click on the exe after downloading and choose properties. Go to the Compatibility tab and try setting it to Always Run in the compatibility mode with XP. Then right click again and choose Run As Administrator.) You may need to repeat this for the installed software as well; note the folder destination for the files.
If you have Win7 x64 and the compatibility mode fails, you would be better off upgrading to Windows 7 Pro and installing Virtual PC and XP mode. Then use the above driver in the XP virtual computer that is created. Alternatively, look into getting a new racing wheel controller that has a Windows 7 x64 driver.
This product was produced for systems with 16-bit and 32-bit versions of Windows. Since Microsoft requires digital signatures on x64 drivers, there would be significant costs to writing new drivers and getting them approved and signed. I'm not sure Game Elements is still in business.
I wish that I had better news for you.
Jan 16, 2014 | Game Elements HV-5 (GGE904) Wheel And...
I can t use on win 7 64 bits.i don t have drivers
Hi!
For most driver
here is
a web site that lets you scan your computer and automatically display the different systems drivers compatible.
Just launch detection and follow the instruction
http://www.touslesdrivers.com/index.php?v_page=29
thank you for choosing Fixya
May 30, 2011 | 3ware Escalade 8506-4LP 10Pk (8506-4lp 10...
Have an SYBA PCI IDE RAIDx2 and very urgent need the driver for Windos 7 Ultimate x64. The VIA site is out of service..!!
hi I found this link below for all syba driver updates and downloads, hope this helps.
http://it.us.syba.com/support_download/download/index.html
Feb 13, 2011 | SYBA SD-SIL680-RAID Ultra ATA 100/133 IDE...
Íå óñòàíàâëèâàþòñÿ äðàâåðà íà çâóê
3Ware RAID card is the only game in town!
Use SSD for parity to best performance.
IDE is slow.
Use SATA or SCSI 3Ware card for the job.
Jan 25, 2011 | Computers & Internet
I recently upgraded my school server computer from 32 bit window xp to 64 bit window7. After that my raid drives were not detected. My raid drives are AMCC 9650SE-8LPML model, though. I think I need to...
Supposedly, there are no additional drivers required. Windows 7 should be able to use it by default:
http://www.microsoft.com/windows/compatibility/Windows-7/en-us/Details.aspx?type=Hardware&p=3ware%209650SE-8LPML%20RAID%20Controller&v=3ware&uid=&pf=2&pi=8&c=Graphics%20Cards%20%26%20Components&sc=Other%20Components&os=32-bit
Jul 30, 2010 | Computers & Internet
How to install raid controller for my PM 800 BMS motherboard pc
hi,
here's the document I used to configured my raid.
http://www.3ware.com/support/UserDocs/InstallGuide-9.2.1.1.pdf
see if it helps you.
good luck.
Mar 31, 2009 | Jetway PM800BMS Motherboard
HARD DRIVE INCOMPATABILITY ISSUES
I evidently figured this problem out on my own. Because I pulled these two drives apart and they were part of a two disc array, the 3Ware Raid controller assigned one as "master" and one as "slave". So, even though they will appear as perfectly good hard drives to ANY pc and you can load an O S on them, they will read as either a slave or master upon hard boot-up. There are two ways around this. One--you can leave them in your pc and "delete" the array in the BIOS and then re-format them, or Two--before or after you reload your O S, power down and unplug your pc. Then pull the COSMOS battery out and reset the "clear cosmos pins" on the motherboard. Leave the battery out for 3 to 5 minutes and then re-install the battery and re-set the "jumper pins" back to their original position. Ofcourse, if you had any overclocking settings previously set in the BIOS, you will have to set the parameters of your choice once you re-boot. It actually takes longer to write this explanation than to do the deed. Problem solved.
Feb 27, 2009 | Western Digital Raptor X WD1500AHFD 150...
Computers & Internet Logo
134 people viewed this question
Top 3ware Computers & Internet Experts
David Payne
David Payne
Are you a 3ware Computer and Internet Expert? Answer questions, earn points and help others
