Question about Stoves 60" VULCAN RANGES GAS(CLICK HERE): 60XLFOUR OPEN BURNERS 36" GRIDDLE TOPTWO STANDARD OVENS Kitchen Range
Vulcan 60LC am looking for electronic ignitions. are they available? thanx
  • traboH Mr
    traboH Mr May 11, 2010
    Hard to imagine why you would rate the solution I posted as "Not Helpful" It is exactly what you asked for. Best of Luck
  • 725 Answers
Yes they are. We can ship the electronic ignitors to you. We need you to contact us with the model number so we can be sure to get the correct parts to you asap. Please call or email us at 975-859-0929 or email EllaWatson25@yahoo.com. We answer our phones from 7AM to 8PM CST Monday through Saturday. We look forward to working with you.
Posted on Sep 30, 2009
  • 27 Answers
See page 19 of this form
http://www.vulcanhart.com/manuals/F30536.pdf
Ignition module part # 857207-1
Your local Hobart branch may carry that in stock
http://www.hobartservice.com/Locations/
Hope this helps
Posted on Sep 20, 2009
Is their naybe and other distributor that i can modfy to fit on a 1199cc uno engin
You don't have enough information. What model is the car, does it have a point breaker ignition or is it electronic. Why do you want to modify the distributor?
There are electronic ignition kits available to fit to your existing points breaker ignition, so no need to fit another distributor.
Nov 21, 2014 | Cars & Trucks
In my dvd player some dvd, cd do not run and shows unknown disc. please advice me how can tbis be cured thanx rakesh l singh
Try to use Lens cleaner,its available from electronics store, if it doesn't cure maybe your lens is old enough & need replacement
Sep 13, 2011 | LG DE9523P DVD Player
Igniter does not work. I cannot find one anywhere.
You didn't mention what model / year / engine you are having problems with, so this will be generalized somewhat.
Assuming that you are referring to the ignition module / magneto, you may able to find a used one from a small engine repair shop. The shop may also be able to order an aftermarket replacement as well. If the unit that you need is just absolutely not available, then you might have better results looking for an ignition upgrade (point / condenser to electronic, etc).
Aug 19, 2010 | Garden
How to installation ? what the Accessories ? thanx
accessories is usually the first position of your ignition key when you turn key from off. no ignition lights should be lit and cigarette lighter should work. this is acc circuit.you need to connect acc wire of head unit to this circuit. (can pick it up at cigarette lighter ) but if your looking to wire REM wire to acc ---DON"T--- wire it to the blue wire on back of head unit(rem out)or blue with white stripe.
Jun 16, 2010 | Infinity Reference 7541a Car Audio...
I have a 73 ford 1.6 industrial motor. need electronic distributo
Look on E-bay for an electronic CD unit that fires from the original points, but generates about 400 volts to fire the standard coil. My guess is that there is no all-electronic ignition system available even as a racing option. Ford used this engine in the Pinto line of cars from`'71 to `73, and all of them used points and condenser distributors. The points and condenser units work fine if in good order and the point gap set at .025". Hope this gives you an assist!
Jan 16, 2010 | 1998 Ford Escort
Need electronic ignition wiring diagram for a 1966 thunderbird
The only place that I know that has a wiring diagram is the factory shop manual which is available thru any thunderbird restoration parts suppliers or ebay. If the electronic ignition, they called it transistorized ignition in 66, is original, you might consider changing to a point type ignition or a later electronic ignition or aftermarket like Petronics. The parts for the original transistorized ignition are very hard to find and even more pricier.
Oct 24, 2009 | 1983 Ford Thunderbird
Same problem - Slow engine speed doesn't run smooth either
You should look at the numbers AFTER the model and type number you noted in your post. The first two digits of the CODE are the year the engine was made. This looks to me like an old 5hp Briggs....old enough that it wouldn't have electronic ignition. If it has the old points and condenser, it could likely need a tune up. Electronic ignition modules or electronic ignition coils are available for this engine - see your Briggs dealer.
If you had the gas tank off, did you replace the gasket between the carb and engine block? This particular engine uses 2 (two) gaskets, not one.
By the way, you don't want to make a governor spring. It's best to use the one specifically manufactured for this particular engine or you run the risk of over-revving.
Jun 07, 2009 | Troy-Bilt Pony Garden Tiller
Oven will not light
Most gas ranges currently available employ one of 3 basic gas ignition systems; pilot ignition, hot surface ignition system (which uses a 'glow bar' or 'glow coil' - aka an "ignitor") and a spark ignition system. The latter two being referred to as "electronic ignition" systems as they use electricity in one form or another to operate the oven heating system. Only the pilot ignition system has an actual "pilot" (which is a small but real "flame") which might need manual lighting.
If the surface burners of a range are a spark ignition type, the oven IS one of the possible kinds of electronic ignition systems and thus will not usually have a "pilot" which needs lighting. Be aware though that just because the surface burners might light via a spark doesn't necessarily mean the oven uses the spark type ignition system too. spark-anim1.90x11.gif
There is one older style of electronic ignition system which does also use an oven pilot but it is very rare and such a system hasn't been used in oven models since the early to mid 70's. It is the 'constant pilot' *electronic ignition* system
Nov 20, 2008 | Frigidaire Ovens
Reply to your advice
well..that's a noble attempt to divert electronics from the landfill. however, parts availability in electronics has about a 2 to 3 year life. so if you find one, it's going to be from someone, like you, that has one around.
May 25, 2008 | Audio Players & Recorders
Stoves 60" VULCAN RANGES GAS(CLICK HERE): 60XLFOUR OPEN BURNERS 36" GRIDDLE TOPTWO STANDARD OVENS Kitchen Range Logo
150 people viewed this question
Top Stoves Kitchen Ranges Experts
Paul Carew
Oloyede Monsuru
Tony Houde
Tony Houde
Are you a Stoves Kitchen Range Expert? Answer questions, earn points and help others
