Question about Vizio E601I-A3 60-inch Class Razor LED HDTV - Smart TV - 1920 x 1080 -
Vizio tv - plays fine and in color. hooked up phillips dvd player - all connectors connected correctly. when i play the dvd, it is only in black and white . . . not color. how can i get my dvd to play color movies? yes . .. dvd movie is in color!
  • 400 Answers
Which input on the TV and which output on the DVD player are you using? HDMI is the best and easiest. Next is standard video plus audio (3 leads, yellow - video, red and white - audio). If you are using the component input, you can get B&W if you have the leads incorrectly connected. If you're going from component to video in, you might have the same result, I'm not certain. I hope this helps you resolve your problem. Let us know.
Posted on Mar 23, 2014
Dvd playing hooked up to an old t.v. plays in color when i hook it up to my lg tv it plays in black and white?
My DVD player only plays in black and white - TOSHIBA FORUMS
forums.toshiba.com/.../My-DVD-player...plays-in-black-and-white/.../47...
39L1350U) and am trying to hook up the DVD player. ... My DVD player only plays in black and white ... My DVD player is an old Sony. .... Was using and S-Video connecting cable to the TV. ... suggested to use VIDEO instead of COLOR STREAM, I changed that in the TV menu, plug the red and while at the back of TV where ...
No Color When My DVD Player Is Hooked Up - Community ...
community.insigniaproducts.com/...DVD-Players/...Color...My-DVD-Pla...
Jul 14, 2014 - I hooked up my DVD player and I have no color. ... you need to use the connections on the left side of the TV or on connections on the back. .... is turned on, which can cause this black and white image issue you're having. ... If the Player shows correctly on a different TV with the same hook up, and different ...
The picture from a disc player displays on the TV in black ...
Jan 17, 2016 | LG Televison & Video
My dvd player is hooked up to t.v. but only plays movies in black/white
How is the DVD player connected to the TV? If you are using component video, check that the cables are connected correctly.
If you switch the order on two of the cables, the black and white result is common. So double-check that the red, blue and green connections (RPbPy) have been connected to both devices in the same order. Next try a different set of component video cables, in case one of the wires is damaged.
If possible, try a different type of connection to rule out a damaged input/output. Connect the TV to a different DVD player or the DVD player to another TV, if possible, to rule out similar damage.
Please add a comment with the connection type for additional support. I hope this helps.
Oct 07, 2012 | Vizio L37 Television
Only playing in black and white
There is a regular video out jack in the rear of the DVD player
Try that to the Video -In on the TV
Also. with the component video , make sure the colors all match at both ends
Apr 18, 2010 | RCA RC5220P DVD Player
When I play a DVD it is in Black and White, how
check your component video cables, make sure they connected to the same color on both the dvd player and the tv.
Jan 16, 2010 | Vizio VO47L 47 in. LCD TV
New lcd tv and dvd player is playing movies in black & white
1. Verify connections are color coded.
2. If they are correct, take out movie, press Play/Stop at same time on the front of the unit (not remote) to reset any settings that may have been changed.
Jul 04, 2009 | Coby DVD-536
Cant get color picture when playing DVD's
I too had the same problem. On the Vzio there are AV plug ins on the left side (not the back, but the left side). Use these jacks when connecting to the DVD player and choose the AV button on the TV remote. Viola!
May 27, 2009 | Sony Televison & Video
Connecting COX DVR and Phillips DVD to Vizio HD TV
we connected the cable box to the coax connector while our philips dvd went into the HDMI1 connector, and we got both working fine and dandy
Jan 10, 2009 | Vizio L32 32 in. LCD HDTV
Nextech N600 DVD player problem
You may have connected one of the component outputs (usually colored red, green, and blue) of your DVD player to the composite input of your TV. Connect yellow to yellow. See section 3.2 for hookup details. Also, if you've hooked up component video, check the three cables to make sure one of them hasn't become disconnected or developed a short and that they are connected in the correct order. If you use an s-video connection, the chroma wire maybe broken -- try a different cable or try the composite connection.
If you live in a PAL country (most countries outside of the U.S., Canada, and Japan) you may be playing an NTSC disc in a PAL player, but your PAL TV can't handle the signal. If your player has a switch or on-screen setting to select the output format for NTSC discs, choosing PAL (60 Hz) should solve the problem. See section 1.19 for more information.
May 03, 2008 | NexxTech N600D DVD Player
Phillips Projection TV
make sure you have the correct video input connected, play a movie in the dvd player do you get anything, can you use a different video input?
if all is correct go to the menu and see if the menu screen comes up.
Dec 02, 2007 | Philips Magnavox 51MP392H Rear Projection...
Black and White
There some thing that you had done to get black and white on your tv with the dvd ,check your connections.if the connections are properly connected then the tv could be having a problem in the video input, have a tech look at it.
Apr 03, 2007 | Zenith C13A05LG 13" TV
Vizio E601I-A3 60-inch Class Razor LED HDTV - Smart TV - 1920 x 1080 - Logo
123 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
