Question about Sendec Tachometer And Hour Meter
Reset oil change
How do you reset the oil change from flashing after it has been serviced?
Tip
Pontiac service light 1983-01
Firebird
1998-01
To reset the "CHANGE OIL" light, press and hold the "TRIP/OIL RESET" button on the instrument panel for 12 seconds. When the light flashes and goes out, the system is reset.
Grand Am
1999 -01
To reset the Change Oil light, open the driver's side instrument fuse panel and turn the ignition on. Press the "RESET" button and release. The light will flash. Press the button again and the system will be reset.
Grand Prix
1999-01
Driver Information Center If Equipped). Turn the ignition to ON without starting the engine. Fully press and release the accelerator pedal three times within five seconds. If the CHANGE OIL SOON indicator flashes two times, the system is resetting. Turn the ignition key to OFF, then start the vehicle. If the CHANGE OIL SOON indicator comes on and stays on, repeat the procedure. To reset the OIL LIFE indictor if equipped with a Trip Computer: Press the trip MODE button until the light appears next to OIL LIFE. Press and hold the trip RESET button until the oil life percentage changes to be 99 percent.
Grand Prix
1997-98
To reset the oil life indicator, press the "MODE" button until the light next to "OIL LIFE" is lit. Press and hold "RESET" for 3 seconds until oil life percentage is 100%.
Grand Prix SE
1997
Turn the ignition on, but do not start the vehicle. Within 5 seconds, push the accelerator to the floor 3 times. Turn the ignition off. Start the car and the Change Oil Soon indicator light will be reset.
Grand Prix
w/ Trip Computer
1988-93
To reset "CHANGE OIL", "CHANGE OIL FILTER", or the mileage of either on the Trip Compute, continually press the "SERVICE" or "SYSTEMS CHECK" button until the item appears with the mileage below it. Then press the "RESET" button and the mileage will be reset to the maximum value. If you want to reduce this value, hold the "RESET" button down and the mileage will count down. Release the button at the mileage you would like to observe.
Bonneville,
6000
w/ Driver Information Center
1983-91
To reset "CHANGE OIL SOON" or "OIL FILTER" or to adjust the mileage on the Driver Information Center, continually press the "DIC" button until either message appears with the mileage below it. At this point, hold down the button. In 5 to 10 seconds, the mileage will count down. When it passes 0, it will cycle back to a maximum figure. Release the button when the mileage gets to the service interval you'd like to observe. If "CHANGE OIL" or "OIL FILTER" already appears, just hold the button down to reset the mileage. "CHANGE OIL" and "OIL FILTER" are reset separately.
on Dec 07, 2009 | Pontiac Grand Prix Cars & Trucks
Tip
Ford-Lincoln service light 1988-01
LS
2000-01
To reset CHANGE OIL SOON/OIL CHANGE REQUIRED message on the Message Center, press the STATUS control to access the System Check mode. Press the RESET button to display OIL LIFE _% RESET FOR NEW. Press and hold the RESET button until OIL LIFE IS 100% is displayed.
Mark VIII
1993-97
When "CHANGE OIL SOON" or "OIL CHANGE REQUIRED" is displayed on the Message Center, turn the ignition on. Press and hold "OIL CHANGE RESET' or the "RESET" button until "OIL LIFE RESET TO 100%" is displayed on the Message Center.
Continental
1989-94
When "SERVICE" is illuminated, on the Message Center, press the "SYSTEM CHECK" button on the right of the display. Then press the "RESET" button. The "SERVICE" symbol and mileage will start to flash. Next, press the "SYSTEM CHECK" and "RESET" buttons at the same time. The display will show "7,200 miles/11,580 km" and will count down from there as long as the buttons are depressed. Release the buttons at the desired service interval.
Continental
1988
When "SERVICE DUE" is illuminated on the Message Center, press the "CHECK OUT" button located below the display. Then press the "RESET" button. The display should now read "SERVICE DONE?" Next, press the "CHECK OUT" button and "RESET" buttons at the same time. The display will show "7,200 miles/11,580 km" and will count down from there as long as the buttons are depressed. Release the buttons at the desired service interval.
on Dec 07, 2009 | Ford Lincoln Continental Cars & Trucks
I had the oil changed but the change oil light is still on, how do i reset the computer? 2000 oldsmobile alero
How to Reset the Change Oil Light
After changing the engine oil, the system must be reset.
With the ignition key to ON, push the RESET button
located in the driver's side instrument panel fuse block. The
CHANGE OIL light will start to flash, press and hold the
RESET button again. The reset is complete when you hear
the chimes sound and the CHANGE OIL light goes out.
Oct 25, 2010 | 2000 Oldsmobile Alero
How do you reset the computer after oil change
Resetting the Oil Service or Service Interval Message.
Ignition key must be "off".
• Press and hold the trip odometer button in the instrument cluster (left button), and turn the ignition key to the first position (KLR).
• Keep the button pressed for approximately 5 seconds until one of the following words appear in the display: "OIL SERVICE, or "INSPECTION", with "reset".
• Release the reset button and press and hold it again until "reset" begins to flash.
• While the display is flashing, press the left button briefly to reset the service interval.
After the display has shown the new interval, the following will appear: "END SIA".
Dec 11, 2009 | 2006 Land Rover LR3
I have ust serviced my 2001 volvo s40 and now the
did the sevice light come on before you serviced it? when you "serviced" it I assume you changed the oil and now need the service light reset.
I bought the 1998 S70. it got time to change the oil. Being how I am I changed the oil myself. I had to call dealership about resetting the service light.
they said $29.96.
I said 29.95?!!! how much if YOU would have changed my oil and reset the light?
they said $29.95.
so I learned you need to access the OBDII to reset the light.after service. hope this helps.
Jun 13, 2009 | 2005 Volvo S40
BMW528i 1999-How do you reset oil service light after oil change?
With the key in the ignition but in the off postion press and hold your odometer trip button in then turn your key to the first postion hold the trip button in for 5 seconds the display will read oil service or inspection then it will say reset release the button and then press it again untill the reset starts to flash then release and press the button briefly to reset
May 28, 2009 | 2008 BMW 528i Sedan
How do I reset the change oil soon light?
Hi to reset the oil life monitor
turn the key on engine off
push the gas pedal to the floor 3 TIMES WITH IN 5 SECONDS
the light will flash then go out
May 12, 2009 | 2005 Chevrolet Equinox
2006 Honda Accord was serviced but oil life light is flashing at -17
It means they didn't reset the oil change light. It means it's 17 miles past due and counting.
To reset, hold down the reset button for about ten seconds until everything in the display starts flashing.
Then while it's still flashing, hold down the reset button again for ten more seconds until the oil life says 100%.
Then, your all done. :)
Apr 19, 2009 | 2006 Honda Accord
I had my 2003 BMW M3 in for it's annual oil change and they didn't reset my oil change maintanence light. It is still showing 3700 miles before next oil change and I just got it done.
1. Key in 0 or off position.
2. Press and hold odometer button and turn key to 1 or acc. position... like you're turning the car on, but don't crank the engine.
3. Keep button pressed until any of the following words appear in display: "oil service" or "inspection", with "reset" or "re". For vehicles with "high cluster", the fuel amount (in litres) remaining until next service is displayed (i.e. 3224).
4. Press and hold button again until "reset" or "re" flash.
5. While display is flashing, press button briefly to reset service interval indicator. After display has shown new interval, the following will appear in display for approx. 2 seconds:"END SIA"
Apr 14, 2009 | 2003 BMW M3
Sendec Tachometer And Hour Meter Logo
466 people viewed this question
Top Sendec Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Sendec Measuring Tool and Sensor Expert? Answer questions, earn points and help others
