Want to start my router
Where do I enter the code on line
  • 62 Answers
Click the signal meter which is next to the sound icon (on my image) and that will pop up the wifis around you. select your wifi and put in the code.
Posted on Mar 23, 2014
How do I reset my password?
In the below example i'm setting password as cisco for enable mode & Virtual terminals of router
1)Connect to the router and follow the below steps
Router>
Router>enable
Router#configure terminal
Enter configuration commands, one per line. End with CNTL/Z.
Router(config)#enable secret cisco
Router(config)#line vty 0 4
Router(config-line)#password cisco
Router(config-line)#login
Router(config-line)#exit
Router#exit
Router con0 is now available
Press RETURN to get started.
Test:
Router>enable
Password: (type cisco to enter into the router privilaged mode)
Router#
Aug 09, 2015 | Computers & Internet
Can't find the site to enter the code
Tell me what make the router is please.
Then try: Start key+ R Type "Cmd" without "" it opens you comand line
type "ipconfig /all" and tell me your ip
the site of your router will have a similar ip
Mar 21, 2011 | Computers & Internet
What is the default IP address
Click Start
Click Run
Type CMD
Press Enter
Type IPCONFIG
Press Enter
Look for a line like: Default Gateway......192.168.123.456
The value you see is the current IP-address for the D-Link router.
Start Internet Explorer.
Type http://192.168.123.456 (using the values that you see)
to access the web-server "inside" the router.
Oct 22, 2010 | D-Link AirPlus Xtreme G DI-624 Wireless...
I'm trying to reconnect my router do i need a disk i am the original owner
Use an Ethernet cable to connect one of the LAN ports on the router to the network-port on your computer.
Click Start
Click Run
Type CMD
Press ENTER
Type IPCONFIG
Look at the output for a line like:
Default Gateway . . . . . . . . . : 192.168.5.254
Enter http://192.168.5.254
to access the web-server inside the router
Login to the router
Click "reset to factory settings"
Jun 12, 2010 | D-Link DIR-625 (790069292637) Wireless...
Where is the pin number for a wrt54gs router
RESET to DEFAULT IP Address, Password
Set router POWER ON.
Reset router: With a straightened paperclip, press RESET button 15secs.
Wait 60 secs.
PC Command Line:
Click [Start] - Click [Run...] - enter: cmd, Click [OK]
At the prompt (c:\.....>) enter: ipconfig /release, press [ENTER]
At the prompt (c:\.....>) enter: ipconfig /renew, press [ENTER]
TEST: Open Web Browser: Connect to http://192.168.1.245
Username: [blank] or admin
Password: admin
Apr 11, 2010 | Linksys Wireless-G WRT54G Router
Hi I have a MSI RG54G3 ROUTER could someone tel me where the WEP number is or where can i obtain one Please can you help
Take an Ethernet cable, and connect one computer to one of the LAN ports on the router.
Click Start
Click Run
Type CMD and press ENTER
Type IPCONFIG and press ENTER
Look for a line of output like:
Default Gateway . . . . . . . . . : 264.468.326.124
Type http://264.468.326.124 and press ENTER
Login to the Router (ID/password required)
Run the Wireless Networking Setup Wizard,
and create an SSID and create a WEP-key.
Jan 25, 2010 | MSI Wireless-G RG54G3 Router
Cannot access my router
Connect an Ethernet cable between your computer and the router.
Click Start
Click Run
Default Gateway . . . . . . . . . : 241.683.326.41
Type http://241.683.326.41
to access the web-server "inside" your router,
where '241.683.326.41' is the same IP-address as in that line of output.
You are now accessing your router.
Nov 27, 2009 | Westell Wirespeed LiteLine 6100...
How to instal D-link
Read the "Quick Install Guide" that came with the router.
Or, connect an Ethernet cable between your ADSL/Cable modem to the 'WAN' port on the router.
Connect another Ethernet cable between LAN port #1 on the router and your computer.
Turn the router on.
Restart your computer.
Click Start
Click Run
Default Gateway . . . . . . . . . : 124.168.136.111
Type http://124.168.136.111 and press ENTER.
Login to the router's web-interface.
Run the "Wired Setup Wizard".
Run the "Wireless Setup Wizard".
Nov 16, 2009 | D-Link DIR-655 Wireless Router
Security
ok , you need to set up a WEP key
so only u fam. can connect dont want pirates
ok go to ur command prompt and type in (ipconfig)
vista command prompt is on (all programs | accessories | then command prompt )
in xp go to ur start then RUN menu type (cmd) and run
should pop a black screen
type in (ipconfig) and hit enter
get the default gateway no.
enter that on ur address bar and go in ur router
go to ur wireless settings and make a WEP code
****if any pc in home is connected to wireless might be prompted for key code type the wep code u made and that should be it
,JULY
ps rate my service please
Apr 11, 2009 | Belkin (F5D7231-4) Wireless Router
2wire 1700HW - forgot password. numbner under bar code is 8699603351 Thank you, Debbie
Sure,
Go to Setup wizard, and enter the password that in square brackets under the S/N barcode on the first line.
Enter your desired password twice on 2nd and 3rd lines.
That will reset the password to yours. Continue to the end of the wizard, and you are done.
Alex.
Jun 25, 2008 | 2wire 1800HG Router (RG1800HG00)
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
