Question about Garden
Echo gt 200r
My echo gt200r will start then kill. Could a dry rotted fuel tank grommet cause this?
  • Garden Master
  • 2,478 Answers
If little peaces getting carb. YES
Posted on Mar 23, 2014
2 Suggested Answers
  • 2841 Answers
SOURCE: what is mixed with the fuel for the Echo GT-200r weedeat trimmer
The mix is 50 to 1. Get an owner's manual for free here. http://www.echo-usa.com/documentation.asp?Model=GT-200R&lang=E Have a great day.
Posted on Jun 01, 2010
Gas leaking from grommet that goes into the gas tank.model pb-2111.
replace grommet. you may want to replace the fuel lines to you can use echo part number # 90098. its a fuel line kit and it come with all fuel lines, grommet, fuel filter, and vent. its plug and play.
Sep 21, 2011 | Echo Garden
I can't prime my carburator on my Echo GT200r weed wacker?
clean your fuel filter and then clean your carb and replace diaphram and needle and make sure hoses are good while you are at it, the methanol causes needle and diaphram to get stiff and gum up not letting fuel into carb when primed, replace your primer blb while at it
Sep 17, 2011 | ECHO, Inc. PB-251C Handheld Blower
Primer bulb will not remain full. Blower will start but dies when throttle is used. Appears to be leaking air around the grommet to the fuel tank.
you should maybe change grommets/pipes to the fuel tank,also the primer bulb maybe is not working properly,consider changing the primer bulb,rgds
Sep 25, 2010 | Echo Garden
Dry rotted tubing on my weedeater blower.
Have it replaced at a lawnmower repair shop.
1.) Have them check the grommet (black round rubber like a thick coin with 2 or 3 holes), replace it if it is crumbly. It holds the fuel line and the fuel vent line - if your trimmer has it. Grommets on the average cost about $6.00. Not all trimmers have fuel grommets, some of them only have holes right on the fuel tank. 2.) Replace the fuel line with Tygon fuel line hose. Tygon can withstand UV light, petroleum, high and low temperatures while retaining its shape. Just make sure the replacement tube is of the the same inside diameter. For a small piece of Tygon hose, ave. cost no greater than $8.00. 3.) Replace the fuel filter. The one inside the tank, connects to the end of the fuel line. Fuel filter, good ones are about $4.00.
Aug 23, 2009 | Garden
My Echo GT-200R will not start. The plug is clean and wet. The switch is "On". Fuel (50:1) is new. It was working 2 weeks ago. Thanks, Chuck My echo gt-200r will start and idle but any time you push...
Try cleaning the screen that is located behind the spark arrestor screen cover. This is located on the muffler. Soak it with gasoline and clean it with a wire brush.
May 29, 2009 | Worx 10" 18v 2 In 1 Grass Trimmer/In Line...
Garden Logo
53 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
