Question about Motorola Mobility HK250 Universal Bluetooth Headset
Brand new HK250 bluetooth, been plugged in since 12:30 & it's still not charged. How long does it take to charge up?
Since it's a new Bluetooth, do I have to take it to sprint to have them connect it?
  • 210 Answers
No , bluetooth headsets are usually simple to pair , read your manual on how to pair with your device
Posted on Mar 30, 2014
  • 46 Answers
SOURCE: HOW TO INSTALL A MOTOROLA H550 BLUETOOTH HEADSET
Usually to pair a new device like that, there would be some trick to set it up. Im not familiar with your exact model, however ive had success with holding some buttons in.
Usually you would hold down the power button, or perhaps the volume up and down together, hold them down for a few secs and the light will go blue/red/blue/red to show its in pairing mode.
Posted on Jun 18, 2008
jmgldsmth
  • 1869 Answers
SOURCE: The Motorola H800 bluetooth headset doesn't charge or turn on. While charging it just displays blinking green light
open and, replace the rechargeable batteries
Posted on May 29, 2009
  • 65 Answers
SOURCE: I can't pair my h700 bluetooth to my Palm device
Depending on the phone... try and remove the currentbluetooth device. Close the headset. Go to the phone and choose discover, or search. Open theheadsetand press and hold the big button. It should then turn purple and should be recognized.
Also make sure thebatteryon theheadset is charged before doing this.
If this doesntwork: Start the search onthe phone, Keep the boom of the mic closed when you press and hold the buttonon the h700. the light should turn purple. After this, open the boom
The passkey will be 0000, four zeros.
Posted on Jul 30, 2009
Schmead10
  • 650 Answers
SOURCE: motorola H500 bluetooth won't turn on!
Hold the phone button down for about 4 seconds.. The light should blink 2 times and then stay on to add device to your phone once connected light will go out...Hold button down again light will blink 3 times and go off...........
Posted on Aug 07, 2009
  • 7 Answers
SOURCE: old phone quit and blue tooth won't pair with new phone
Hold the volume buttons on the side while holding the call button for 10 seconds. It will reset the bluetooth and remove any other devices it may have been paired to. Then turn it off, back on and it will eventually stay lit blue and then you need to set it up through your phone. I hope this helps, I had the same problem and mine is working fine!
Posted on Sep 22, 2009
Motorola hk250 bluetooth was put in the dryer now it won't work
The instruction set was discharged when the heat and static from the dryer caused the data to blank out. Motorola is the only source for repairs, and the chances are the Bluetooth is damaged beyond repair.
Mar 05, 2014 | Motorola Mobility HK202 Bluetooth Headset
Mettre mon motorola hk250 en francais
Hello
I have a Motorola HK250, I find several languages except French, ars there a way to add French as an option? thank you
Dec 29, 2013 | Motorola Mobility HK250 Universal...
My Motorola HK250 wont charge is flashing red all the time
Mine is too. Mine will sit solid red for a little then turn solid blue. Then after that it will flash red all the time. I've had it on the charger for the last 2 days and that's all its been doing. I read the flashing red light means the battery is either unchangeable or not making proper contact.
Oct 22, 2013 | Motorola Mobility HK250 Universal...
MY LG TONE HBS-730 WILL NOT CHARGE
It is charged when the red light goes out. Press and hold the VOLUME DOWN button for one second and an audible will give you the battery charge level - high - medium - low.
Apr 20, 2013 | LG Tone HBS-730 Bluetooth Stereo Headset -...
My brand new madcatz bluetooth headset wont charge, when plugged in the charging light is red, but it increases/ decreases in brightness after 4 hours it will not turn on or sync. This is the second one...
i just got mine and it when i plug it in to charge the red light turns on for like 10 seconds then turns off and it wont turn on so itss dead... return it?
Aug 29, 2010 | Mad Catz Bluetooth Headset for PS3
Just received a brand new, in original packaging, ...
Your headset should enter the pairing mode just by opening its boom. If it has never been paired before, it will be in pairing mode right away. Otherwise, make sure that the bluetooth radio of all devices preivously paired with it, are turned off (or, at least, out of reach). As soon as its boom is opened, and it can't find any paired device active, it will enter the pairing mode. Once your headset is in pairing mode, make the bluetooth application of your phone search for new devices. After a while the H700 should appear on the phone screen. Select it and make the application connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). The pairing process should be done only one. All subsequent connections between any two previously paired devices should be done automatically, provided that their bluetooth radios are on and with each other's reach.
Hope you are able to sort your problems out.
Regards, Carlos
May 19, 2010 | Motorola Mobility H700 Wireless Headset
Lost charger who can I call?
The nice thing about the ps3 is it can charge the bluetooth from the charge cord for the controllers. Just plug the bluetooth into the charging wire from the ps3 and the bluetooth will charge.
Jan 27, 2010 | Mad Catz PS3 Bluetooth® Headset Wireless...
Can't pair bluetooth
....My madcatz bluetooth will not charge everytime i plug it in the ps3 the red light comes on then it goes off and it keeps on doing it and its a brand new bluetooth...i hold it for a long time and it still wont work..HELP PLEASE!!!!!!1
Feb 06, 2009 | Mad Catz PS3 Bluetooth® Headset Wireless...
RAZR/bluetooth light/charging problems.
From the symptom it indicate that the bluetooth having charging problem.one thing you can do is to ensure the charge contact ( both charger & bluetooth ) is good ,mean you may need to do some cleanning.if still can't hold the charge then the battery in bluetooth may need to replace. hope it help.
Aug 24, 2007 | Motorola Mobility Bluetooth Headset H3 for...
Motorola Mobility HK250 Universal Bluetooth Headset Logo
118 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
