Vehicle Parts & Accessories Logo
e
eddie poli Posted on Mar 23, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
P0011 error code
Its throwing two codes. P0011, andP0021. Itsounds like the timing is way advanced
Daniel Mc Entee
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Vehicle Part... Master 1,449 Answers
  • Posted on Mar 25, 2014
Daniel Mc Entee
Level 3:
Renaissance:
Answers
1449
Questions
0
Helped
275568
Points
3556
What car is it. if it is a nissan ,then check your oil level ,you may need to do an engine flush as it can be dirty oil. blocking your pump in the sump.
2006 Nissan Micra 1.2 auto. Idling is fairly rough. Got the error code below. No lights on dash. Any idea? Maurice. P0011. Bank 1 'A' Cam Position Timing System Performance.
https://www.google.com/search?q=Nissan+P0011
P0011 Nissan See the error code p0011. it indicates the engine control module has determined that the bank 1 intake camshaft is more advanced than what the engine control module has commanded it to be. Jul 23, 2021
How to Fix NISSAN P0011 Engine Code in 4 Minutes [1 DIY ...
Honda accord 2008 p0011 code and oil light on
What the P0011 code means. P0011 is the OBD-II generic code indicating the engine control module (ECM) has determined that the bank 1 intake camshaft is more advanced than what the ECM has commanded it be. This over-advanced condition could be during advancing or retarding of the camshaft timing.
The timing belt or chain may have jumped and the noise could come from valves hitting the piston head.
3.5l. What are the probable causes of DTC P0011?
According to the error code list (see the link below) it is an over advanced cam shaft timing. It well may be a mechanical fault as opposed to an electrical fault. Read about it here:
http://www.obd-codes.com/p0011
There's also a Youtube video which may be of use to you:
2006 impala 3 5L error code p0011 advanced timing fix part number 12589784
Code p0011
http://www.datsc.com/tabid/122/OBD-Error-Code/P0011/Diagnostics/Mercedes-Benz/Default.aspx
"..........OBD Code P0011refers to
A code P0011 refers to the VVT (variable valve timing) or VCT (variable camshaft timing) components and the car's PCM (powertrain control module, also called an ECM). That consists of a few different components but the P0011 DTC specifically refers to the camshaft (cam) timing. In this case, if the cam timing is above a set limit (over-advanced), the engine light will be illluminated and the code will be set. The "A" camshaft is either the intake, left, or front camshaft.
SymptomsPossible sumptoms of OBD code P0011
Most likely a P0011 DTC will result in one of the following: hard starting, poor idle, and/or stalling. There are potentially other symptoms as well. Of course, when trouble codes are set, the MIL (malfunction indicator lamp, a.k.a. the check engine light) illuminates.
CausesPossible causes of OBD code P0011
A P0011 DTC trouble code may be caused by one or more of the following: Incorrect camshaft timing Wiring problems (harness/wiring) in intake timing control valve control solenoid system Continuous oil flow to VCT piston chamber Failed timing valve control solenoid (stuck open)
Possible SolutionsThis DTC code is a result of a mechanical fault of the VCT unit or related components, so there is no need for electrical diagnosis. Refer to vehicle specific repair manual to perform component tests for the VCT unit. Notes: Dealer techs have advanced tools and the ability to follow detailed troubleshooting steps, including the ability to test components using a scan tool.
Related CodesP0010 P0012 P0020 P0021 P0022..........."
P0011 code
The P0011 means "A" Camshaft Position - Timing Over-Advanced or System Performance.
__________________
mini vci for tis
1helpful
What are the codes P0011 on a 2005 VW passat?
Incorrect camshaft timingWiring problems (harness/wiring) in intake timing control valve control solenoid systemContinuous oil flow to VCT piston chamberFailed timing valve control solenoid (stuck open)
Hope helps.
2helpful
2answers
6helpful
P0011 WHAT DOES THIS CODE MEAN?
P0011 "A" Camshaft Position - Timing Over-Advanced or System Performance (Bank 1)
  • Incorrect camshaft timing
  • Wiring problems (harness/wiring) in intake timing control valve control solenoid system
  • Continuous oil flow to VCT piston chamber
  • Failed timing valve control solenoid (stuck open)
8helpful
Identified as P0011
P0011 - "A" Camshaft Position - Timing Over-Advanced or System Performance (Bank 1)
What does that mean?
Potential Symptoms:
Causes:
* Incorrect camshaft timing
* Wiring problems (harness/wiring) in intake timing control valve control solenoid system
* Continuous oil flow to VCT piston chamber
* Failed timing valve control solenoid (stuck open)
Possible Solutions:
Other related DTCs: P0010 - P0011 - P0012 - P0020 - P0021 - P0022
Hope helps (remember rated this).
7helpful
My VW Eurovan,2002 has 2 fault codes. P0011 and
P0011 - Intake camshaft position timing ( over advance bank 1 )
O0420 - catalyst system efficiency below threshold bank 1. Hope this was helpful.
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
john h
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
