Question about Refrigerators
Frigidaire gallery refrigerator ice maker repair
What is happening and is it something we can fix ourselves?
  • 400 Answers
Please give MUCH more information, model number, symptoms of problem, when did it start, and anything else you know about the problem. I assume (that's dangerous) it is not making ice. Look in the users manual for the troubleshooting guide. It will most probably give you the common causes of problems. Is there water getting to the icemaker? Is the motor activating to dump the ice? Is the ice level detector bar locked in the up position? There are many simple things you can check before you need to panic and call for help. I hope this steers you in the direction of solving your problem.
Posted on Mar 23, 2014
  • 43 Answers
SOURCE: the Frigidaire Gallery freezer has ice build up restricting air flow
#1. DEFROST TIMER stuck or defective. Not allowing DEFROST CYCLE to occur. Most probable.
#2. THERMOSTAT (cold control) has gone bad.
#3. CIRCULATING FAN. It pulls air from the FREEZER side into the REFRIGERATED side.
#4. and lowest in probability. LOW (leaking) coolant charge.
Posted on Mar 09, 2008
  • 409 Answers
SOURCE: Frigidaire Gallery Series Side by Side doesn't crush ice
hi there,
could be that the ice maker arm is getting stuck or may have some frost on it. can you supply the complete model # please?
Posted on Sep 25, 2008
vanni7
  • 163 Answers
SOURCE: water dispenser and ice maker not working
Hi!! tony , yes you have a bad water valve its located on the bottom back of your frig..Replace your water valve..Good luck..
Posted on Jan 03, 2009
woodchuck789
  • 4070 Answers
SOURCE: ice maker dispenses cruched ice in cube ice mode
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid.
With your model number I can find a diagram which may help.
Posted on Oct 05, 2009
SOURCE: Ice maker only producing crushed ice, only I have
We had this problem and have visited several friends houses in our neighborhood who all have appliances of approximately the same age, 6 to 7 years old and found this to be quite common.
The solution to this specific problem was rather simple, and has proven effective on several different brands, to the relief of many befuddled husbands and frustrated wives and now happier children.
Though the mechanism is in a slightly different location on some models.
I removed the ice hopper and looked in the back of the freezer and found the steel drive prongs that power the feed screw inside the ice hopper.
An inch down and a few inches to the right of it I found the mechanism that actuated the arm to open the chute for cubes or keep it closed for crushed ice. (on the Frigidaire Gallery Series)
I held the interior light switch closed and had someone push the ice lever on the outside and observed the drive prongs turn, but the mechanism that actuated the arm to open the chute did not move.
Stuck my finger in there and pushed it upwards manually and after a brief moment of resistance it moved freely.
Re-tested the operation of the mechanism that actuated the arm to open the chute, and it now opened when the ice lever was depressed and set to cube, and stayed closed when it was set to crush.
With the money we saved on the service call, I took the family out for chinese food.
Posted on May 14, 2010
My frigidaire gallery french door with ice maker is making a knocking noise every 5 seconds. Sounds like from the ice maker. How do I fix or stop the noise.
I have a different type. I rubber banded the little ARM in the UP position ( to fool the unit that I have enough ice). NO MORE SOUND>>
Jun 03, 2015 | Frigidaire FGHB2866PF3PCKIT Gallery...
I have a Frigidaire Gallery Refrigerator with bottom freezer that is only 3 yrs old. My problems are with the ice maker and the door seals. The ice maker in the top in the refrigerator makes ice but f
Thank you for your post, Genie Byrd!
From my understanding your Frigidaire refrigerator is not sealing properly which is causing an issue with your icemaker. You may need to replace the component for your seal. I would recommend having a professional technician out to your home to properly diagnosis and repair your refrigerator. Are you under warranty? Typically, if you are under warranty a repair should not come out of your pocket. I would consult with your manufacturer for warranty coverage. Hope this information helps. -OOS
Nov 22, 2014 | Frigidaire 27 in. Electric Gallery Pro...
Frigidaire gallery side by side won't send water to ice maker tray, but will to water dispenser
Hello Jim czyryca - From what you are describing if the ice maker is not making ice but is dispensing water, sounds like the refrigerator has a frozen water line, faulty ice maker valve or bad component that sends power to the ice maker valve when needed. The ice maker cycles internally to call for water so I strongly suggest contacting a professional to move forward accurately to assist with the repairs.
Jan 24, 2013 | Frigidaire FRS3R5EMB Side by Side...
The ice is not dropping when the cycle has completed. The ice is there but it will not fall. Do you know what could cause this to happen?
Look underneath the ice maker, there should be a reset or test switch. it should do a complete cycle and then come back to rest. If after that it still does not respond, then suggest a new ice maker module. To repair can be time consuming and costly and very seldom does one come right.
Aug 25, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire side-by-side ice maker hose froze up
I've seen three solutions to this but havn't tried them yet. One was to gently turn the tube counter clock wise to separate it from the refrigerator and then clear the ice form the end of it another was to use a hair dryer to thaw it out and the third was to wrap warm washrags around it to thaw it out.
Jun 15, 2009 | Frigidaire FRS3R5EMB Side by Side...
Ice maker not making ice
We do not use our ice maker. But all of the sudden water is leaking from it. Can you tell me how to fix this? Calling a plumber wil cost a fortune.
Mar 09, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire Side by Side Gallery Model Refrigerator
yes where thr water go\es into the ice maker is where the problem lies, take the ice maker out and then you'll see the tuding where the water goes into the ice maker. Then take a hair drier or a shop vac reversed and thae out the utde and the water will flow after it is thawed.
Jan 30, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
hi there,
Sep 25, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
