SAHARA KN1 LAPTOP BIOS FLASH
ACCORDING TO THE LAPTOP THE BIOS VERSION IS A Q3B71 BUT I CANT SEEM TO FIND AN UPDATE FOR IT. IS THERE AN UPDATE IN EXISTANCE AND HOW DOES ONE FLASH THE BIOS. ANY HELP WILL BE APPRECIATED. THANX
  • 50 Answers
Flashing the bios is a tricky thing to do. basically you will find the file ( i do believe it is a .bin file) , u save on a CD along with an executable file, once you rebooted the computer, it will update it automaticall. some you might have to run the program, pointe it to the bin file, and tada, flashed. try this utility (SIW)
it will tell you what is the BIOS version, among of tons the other info. the utility is free.
there are other methods of flashing, but be careful, you try the wrong thing, and you motherboard is bye bye.
Posted on Jun 16, 2009
Hello, My name is Keith and I run a small computer repair store in Alabama. I have a customer that has a Toshiba Satellite C75D-B7200 and he cannot remember the BIOS password
Hello Keith!
First of all, there is an OEM Toshiba software out there to flash the bios directly from windows, doing so will remove any password and restore the BIOS to it's original settings with an updated version. If that still doesn't work, consider a 3rd party software to recover the password or if the bios is socketed and none of the above solutions worked, order a new one directly from Toshiba.
Be ABSOLUTELY SURE to flash the BIOS with the correct version according to the model number of the laptop and that you connect the laptop with the power adaptor so it does not run out of battery in the middle of the process failing to do so might rend the computer unusable with a corrupted BIOS file.
Feb 12, 2015 | Toshiba Computers & Internet
Hi. I have netbook acer aspire one AO725, it seems the battery wont charging.. I read about solution that needs to update the the BIOS version.. current BIOS version v1.5, the latest is v1.8 but, it w
I suggest that you make sure the battery is in fact good before you update the BIOS. If the battery was charging OK and suddenly stopped charging then the problem is not the BIOS version.
If you do decide to update the BIOS you will need to find the appropriate procedure to follow by searching the Acer support site and/or knowledge base. Please be aware that using an incorrect method or if something fails during a BIOS update it can result in unrepairable damage.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/dave_fb2c45146b845cea
Oct 15, 2014 | Computers & Internet
Bios update
you must go www8.hp.com and according with your model, serial, etc download the appropiate version that you have, and then download the version BIOS update. Otherwise you must contact with them via ONLINE chat for get support in order to explain what going on with the BIOS update in your computer.
God bless you
Jul 10, 2013 | HP Compaq Presario V2000 Notebook
BIO PASS WORD
Reset BIOS password, it can be done in two ways
Manual
Open the cover under laptop, remove the CMOS battery about 7 seconds, then plug it back. Turn on laptop, BIOS password will be lost. Perform setting date, time, etc.
Online (conditions: the laptop can desktop access)
Toshiba gives services, online flash BIOS. Download and install software ACPI Flash BIOS, according to model of laptop.
Example: Toshiba Satellite L305-SP6983R, software version: ACPI Flash BIOS version 2.20 for Satellite/Satellite Pro L300/L305/L350/L355
Nov 17, 2011 | Toshiba Satellite Laptop L655S5150
I neeb bios update for sahara laptop al096
Don't do it unless there is a VERY COMPELLING REASON. BIOS flash upgrades don't always go well. If it fails for ANY reason, you are out of business ... rarely can you go back with success.
This is a case of if it ain't broke - don't fix it.
Thanks for your question @ FixYa.com
Sep 05, 2011 | Computers & Internet
Changing/reset CMOS Lifestyle S6410 fujitsu-siemens notebook?
Here is the link from where you can download Bios Flashing software according to your BIOS.
http://www.biosman.com/bios-flash.html
Download the software according to your BIOS.
your system BIOS is not available for download in the Fujitsu site.
you need to confiremed your BIOS Chipset manufacturer name with current BIOS version.and Check the upgrade version in the chipset manufacturer site only.
Note:  Fujitsu doesn't recommend BIOS upgradation.
Jan 01, 2010 | Fujitsu Siemens LifeBook E4010D Notebook
Bios not recognising USB Devices
The only thing i can suggest is that should try and update your BIOS.. Check your manufacturers website and see if there is a BIOS update avaible for your computer
Mar 11, 2009 | Computers & Internet
USB Ports won't work
Please enter CMOS setup and verify that the USB port is enabled.
Nov 25, 2008 | Toshiba Satellite A105-S2001 Notebook
Problem
In this situation I recommend you to try removing and reseating the DVD Drive of the Notebook manually. Get the Manual of the Notebook which can give you the instructions to remove and reseat the DVD Drive in the Notebook.
If the DVD Drive is not detected even after reseating, it may be faulty and needs to be replaced.
Sep 05, 2008 | Computers & Internet
Sahara KN1 laptop
Older motherboards like the one in your laptop may have a size limit on the hard drive. Maybe there is a bios update for the laptop to fix this issue. you will find that at the manufacturers website under downloads/support.
Feb 23, 2008 | Computers & Internet
Open Questions:
The smartest way to keep your business files secured on online cloud backup The most secure way to keep your important business data safe online on Cloud backup for easy access anytime anywhere. Apt for businesses of all sizes and also pocket friendly. If you need your life to be sorted out from all the trouble of managing the enormous amount of data that is being generated every day in businesses whether small or large, then look no further because business online backup service of Dataalign is all you need to keep all important data safe and accessible. We at Dataalign provide companies and businesses a unique and easy way to save their essential statistics, facts and information related to different clients securely encrypted on a safe Business Server Data Backup system which allows them to analyze and download their saved data anytime from the saved storage with just a click of the mouse. One of the most distinct and advanced feature of Dataalign Online Cloud Backup is that it makes all your searches easy with the use of artificial intelligence due to which any file or photograph can be accessed by just typing a name or phrase even if you don't remember the particular name of that file. This results from Computer Data Backup smartly and orderly organized documents for easy sorting and categorizing in order of file size, type, owner name, date of creation etc. You never have to worry about the security of your crucially important data on our business as access to all data is restricted only for the person intended. This system provides security and the freedom of choosing who can view all that data. One more feature of this that helps in Business Server Data Backup making our lives more convenient is the choice for the number of days for which you want to keep a data saved on the online storage so that it automatically gets deleted after that, for saving your extra effort of sorting all your data and getting rid of unwanted files and photos to save space for more important data. So, for making your lives less complicated and more sorted contact our toll free helpline number 888 784-9316 for any assistance regarding business online backup.
Aug 18, 2018 | The Computers & Internet
Computers & Internet Logo
498 people viewed this question
Alun Cox
David Payne
David Payne
