Question about Craftsman Garden
Install spring return idler
I can't find a diagram to show me where to install the spring return idler part 169022 for Craftsman tractor model 917.273460. Help?
4 Suggested Answers
mowerman1857
  • 389 Answers
SOURCE: CRAFTSMAN Tractor Model%23 917257643 adjust idler
First things first! Before you installed the new belt, did you check the blades and idler pulleys to see if they all turned freely with no resistance while the belt was off and the blade brakes released? Release the blade brakes by engaging the handle with the engine off!
When you installed the new belt, did you put the back side of the belt against the flat pulleys and the inside of the belt in the V-pulleys? Did you double check to make sure you didn't inadvertently miss a belt guide getting the belt on the outside of it instead of underneath it. Did you look at the picture in your owners manual to make sure you had it routed correctly and make sure it is not rubbing against anything when you have the blade lever engaged? CHECK THIS WITH THE ENGINE OFF If you don't have your owners manual, look under the foot boards on the tractor, many of the Sears tractors have the routing diagrams there. If it is not there you can go to searspartsdirect.com , enter model number 917.257644 (NOTE the number difference) and look at the picture of the deck, it shows what the belt should look like when it is installed. You can also download an owners manual there. As best as I can remember, there is no adjustment for the idler pulleys.
Posted on Oct 25, 2009
  • 146 Answers
SOURCE: 609 yard machine tractor idler pulley spring broke
Here's a diagram, not a great copy, but it may help:
The spring hooks to the idler arm on the opposite end from where the pulley is mounted. The other end of the spring looks like it hooks to a raised tab on the deck, straight behind the left mower spindle. Hope this helps you, please rate my solution if so, thanks!
Posted on Jun 08, 2010
  • 6468 Answers
SOURCE: Does anyone have a diagram on how and where to attach the tension springs / and the spring return idler on the mower deck of the craftsman LT1000 Tractor Mower. The transmission belt keeps falling off
look on the bottom of the foot rest sears places a label there
Posted on Apr 07, 2012
I have a craftsman lawn tractor having problem with spring extn. 732046168. Tractor model 247288851. the spring is connected to idler bracket bracket assembly.
Howard, possibly the wrong spring # not matching as parts diagram in links below, do you have the old spring to sort of match it up or are you possibly putting it in the wrong retaining hole. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http www searspartsdirect com model part 247288851 0247 1509200 1106099p...
http://www.searspartsdirect.com/partsdirect/user-manuals/247288851-craftsman-tractor-manual
http://www.repairclinic.com/Shop-For-Parts/a21b317d1124318/Model-247288851-Craftsman-Lawn-Mower-Parts
No Need to see diagram of the springs that are on the deck of riding mower...
Jun 10, 2016 | Craftsman Garden
Where does the spring on the idler arm hook up to
well since you didn't mention the brand/model we can't help either
Oct 24, 2014 | Garden
Need diagram installation. A drive belt.
If you have a Craftsman, under the seat is the model number. Go Here to get the operators manual. The manual will have all the belt diagrams. Water Filters Lawn Garden Appliance Parts
Oct 14, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
How to tighten a craftsman LT1000 belt ?
There is an idler pulley that engages the mower deck and tightens the belt automatically on your model. Check to make sure the belt is routed correctly, return spring is in place and that your cable is operating smoothly.
Jul 19, 2014 | Craftsman Garden
The clutch return spring broke on my lawn tractor model 917.272242 and i cannot see at what points it connects my diagram is not a real .can you help
If you go to searsparts.com and put in your model number they will have a diagram as to how the spring attaches.
Jun 20, 2014 | Craftsman Lawn Mower
I have a Craftsman mower, model 917.273810, and when you engage the blades, the brake pads that are used to stop the blades from turning when you disengage the blades...won't release and it trys to...
Sounds like you have a broken spring #148 on diagram, part #169022 that holds the idler arm back. Go to www.searspartsdirect.com and enter the model # of your mower and click on the mower deck to print drawing out, take your deck off the mower and see if all the springs are ok. If the pads are closed on the pulleys and the pads release when you turn the idler arm, the deck is ok. The problem will be a bad or disconnected safety switch that cuts the motor off if you try to ingage the mower. If the switch is disconnected under the seat it will kill the engine when the mower is engaged. I had this problem on my mower, just plug the wiring into this switch or replace it if it is bad.
Aug 16, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I have a 17 HP 42" craftsman mower. When I disengage the blade lever, the blades do not fully disengage until I slow down the engine with the throttle lever. This has only begun recently. The tractor...
There are blade brakes, one on each blade pulley. You will need to check that the brakes are in good working order and that the springs holding them against the pulleys are in place. Also there is a spring to return the idler pulley to the neutral position. The spring could be broken or the idler pivot rusted not allowing it to return to fully neutral position. This should get you going down the right track. Hope this helps; please vote yes. Thank you.
Nov 21, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Garden Logo
390 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
