Question about Radio Communications
Is the ProScan PLT8801K bluetooth compatible - Radio Communications
How can I program a proscan tv to proscan remote?
If it is a compatible remote there shouldn't be any need to "program" it.
Dec 29, 2016 | Proscan Televison & Video
Is there a sound bar that works with the 50 Proscan Tv?
There is no sound bar compatible for this set.
Oct 28, 2016 | Proscan Televison & Video
I just bought a new 40" proscan tv and my comcast remote won't program to it. I've tried every code.
that is not unusual as comcast is not a universal remote . non compatible units
Dec 20, 2015 | Proscan Televison & Video
How to pair my ilive blue tooth wireless head phones with a proscan tablet
Open the blue tooth menu on your tablet (usually -> Settings -> Bluetooth)
Turn on your head set. Usually there is a pairing button option, on your set, you need to turn the headset off, then turn it back on but hold the power button for 8 seconds until they will flash red/blue.
You should be able to find your headset then on your device.
How to pair bluetooth headphones to your phone
Nov 08, 2015 | Proscan 10.1-Inch Internet Tablet,...
On the proscan tablet where is the bluetooth setting so I can connect my bluetooth headphones
At the top right of the screen, pull down the menu. Bluetooth settings can be set from there.
Feb 21, 2015 | Tablets & eReaders
How do i hook up phone to my proscan digital watch
Hi Kelly
bit confused as to which watch you want to connect phone to, as the AK09 tri band, is already a watch/phone it has its own sim card, however the proscan digital watch has not and is only bluetooth connectable, if it is the proscan watch you want to connect i have added a link to there web site which you can download the instructions on how to connect your phone to it, you didnt say what model number it is so i presume it will be this one, if not there site has 3 altogether you might find it on there hope this helps Item PBTW213 ProScan
Dec 17, 2014 | dealeurstore.com AK09 Tri Band Single Card...
PROSCAN PTL7100G TABLET CONNECTION TO COMPAQ CQ57 TO BURN NETFLIX
I believe the Compaq CQ57 does not have Bluetooth capability. If you installed a Bluetooth adapter on your laptop, you may not have the proper Bluetooth drivers installed.
Alternatives:
1. Connect the tablet and the laptop over your home WiFi network.
2. If your tablet can use microSD/microSDHC cards, transfer the files to the card.
Hope this helps.
Dec 12, 2014 | Cell Phones
My keyboard will not work on proscan tablet
Is it a Bluetooth or USB keyboard? If you are talking about a Bluetooth keyboard, it has to be 'paired' with your tablet, a procedure that should be explained in your user manual. If it is a USB keyboard, try going into Settings and look for the Input Device section and see if you have to enable a USB keyboard. Many tablets are not capable of using a USB keyboard, by the way.
Aug 18, 2014 | Proscan 8" Tablet with 4GB Memory
PROSCAN 42LA30H
go into the dash board and try changing it there...?
Nov 20, 2007 | Proscan 42LA30H 42 in. LCD Television
Radio Communications Logo
60 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
