Question about LG Washing Machines
Washer can't remove the soap , and have to wash the clothes handly to clean soap
And have to wash the clothes handly to clean soap
    New Friend:
  • 14 Answers
Remove the soap build up between the wash tub and the outer basin with a fridge or dryer lint brush. The soap accumulates and builds up between the two tubs. Clean it after a recent load of laundry so it has a chance to soften up. Make sure the washer is unplugged when you clean this area.
Use Borax and half the amount of soap in future wash loads to prevent this build up.
Posted on Apr 14, 2014
Duet washer , clean filter still get sud reading. Washes well without clothes. Wash with and without soap and did not put in clothes. The machine went throught the cycle with no problems. When you
do you get a lot of suds when you run it without soap and clothes ? if so put about a cup or 2 of vegetable oil into the washer and run a cycle . soap suds will adhere to the oil and it will help it to remove from washer . after you can run a clean cycle with bleach or white distilled vinegar.
Feb 20, 2013 | Washing Machines
Is there any kind of recall on a Maytay front loading washer, model #MAH6500AWW? I am having problems with mildew in the rubber part and terrible smelling water in the bottom.
The cleaning process for your Maytag Neptune front-loading washer, for example, requires some time and patience. Over time, your washing machine will need to be cleaned. It can develop offensive odors through multiple wash cycles. This makes the washing machine less effective at cleaning the clothes you put into it. Maytag offers some sound advice for cleaning your front-loading washing machine.
  • Pour 2/3 cup of liquid chlorine bleach into the bleach compartment of the dispenser drawer of your Maytag Neptune front-loading washer.
  • 2
    Run your Maytag Neptune front-loading washer on the "Clean Washer" setting. Press "Start" to start the cycle.
  • 3
    Leave the door open once the cycle is complete to allow the inside of your Maytag Neptune front-loading washer to ventilate and air dry.
  • 4
    Look closely at the gray seal of the Maytag Neptune front-loading washer's door opening. This seal can have a buildup of debris or detergent residue.
  • 5
    Spray the seal with an all-purpose appliance cleaner and scrub away any debris or residue with a cloth or scrubbing pad. Dry with a clean cloth.
  • 6
    Remove the soap dispenser drawer. Press the release lever and lift it out to clean.
  • 7
    Take out the inserts and rinse them and the drawer thoroughly.
  • 8
    Wash with a mild soap and cloth to remove any residue. Dry thoroughly before replacing.
  • ALWAYS LEAVE THE DOOR OPEN WHEN NOT IN USE! This prevents the mold and mildew from forming once you get it cleaned.
    Aug 20, 2011 | Washing Machines
    Dark clothes have lint left on them. what could help this problem?
    Are you sure it is lint and not soap? My washer does this, and it looks like lint, but it is soap.
    If it is lint, always keep the lint collector inside the agitator clean.
    If it is soap, and this might work for lint:
    1. Turn clothes, particularly black clothes, inside out.
    2. Use a concentrated soap with little or no filler.
    3. Use less soap than normal.
    4. Fully dissolve soap before adding clothes.
    5. Run rinse cycle again after completing full wash cycle.
    Jun 22, 2011 | Admiral AW22 Top Load Washer
    The whashing comes out with white powder like stuff. Can I clean the drum and if so how ? is it flint that gathers some where?
    Hello Sir Tommis,
    I understand that you are having a problem with your washing machine. When you wash clothes they come out with a white powder like substance on them. This white powder substance is the powder laundry soap that you are using.
    This is generally caused by adding to much soap and clothes to the washing machine. The soap is not getting dissolved and the clothes do not have enough room to agitate in the machine. Try to put 3/4 of the amount of clothes in the washer with the same amount of soap and see if the clothes come out with the same powder like substance on them.
    The clothes that currently have the soap on them will have to be hand washed with a scrub brush in oder to get the material off of them as running them though the washer will not remove the soaked in soap.
    Thank you for choosing FixYa.com
    Justin
    Mar 26, 2011 | Whirlpool 3.2 cu. ft. Washer
    How do i remove the agitator from the washer so i can clean it - there is so much buildup of soap scum that my clothes come out dirty - Maytag LAT6914AAM
    remove the cover from the agitator use a 7/16 socket with around a 9 in extension and unsecrew the bolt place both hands around the agitator and lift up in the future use affresh which can be found at any home depot it gets rid of the soap scum
    Apr 30, 2010 | Washing Machines
    How do you get rid of the musty smell in a front load washer.
    38c7a1e.jpg MNTECH
    Rank: Guru
    Rating: 93%, 650 votes
    Here is a response I recently gave to a person posting a similar problem. You do not state your model number, so: If you have a tub clean cycle, use that, if not, use the longest, hottest cycle with no clothes and a front load washer cleaner like Ahfresh, Washer Cleaner, SmellyWasher Cleaner, Tide front load washer cleaner, or Whilaway hot tub cleaner. Clean the tub gasket area by the door and remove the filter and clean it out also before you run the clean cycle. You may have to run the cycle with a cleaner twice to remove all the built up soap scum inside the washer. Now, after the washer is clean, USE ONLY ONE TO A MAXIMUM OF TWO TABLESPOONS OF HE LAUNDRY DETERGENT PER CYCLE !!!! (and no more than one teaspoon of fabric softener per cycle, if you use it)
    You could check out http://www.smellywasher.com/ for one possiblity. The big thing is that these machines use very little water, and many of the newer soaps are 2x or 3x concentrated, so you have to use very little soap. (much much less than the soap manufacturers suggest) in order to rinse all the soap residue out of the clothes and prevent it from builing up in your washer and causing odors. (oh, by the way, that one cleaner I listed as Washer Cleaner is actually " Washer Magic ") 73b1c2a.jpg fb3071a.jpg
    Aug 12, 2009 | Kenmore Elite 45986 Front Load Washer
    Moldy smelling clothes
    First, clean your washer with one of the front load washer cleaners on the market. (Affresh, washer magic, smellywasher cleaner, whirlaway hot tub cleaner, or Tide front load washer cleaner) Use the longest, hottest cycle your washer has, with no clothes.
    Second, rewash the smelly clothes with the heavy wash cycle and a second rinse option, using no soap or fabric softener. This will remove the soap and/or fabric softener build up in the clothes which is causing the smell. Third, begin using one to no more than two tablespoons of HE soap per load, and not more than 1 teaspoon full of fabric softener if you use it. This is because top load washers used up to 45 gallons of water per load, and your front load machine is only using about 12 gallons total. If you are washing a load of bath towels (which were only used to dry off your clean body, not wipe up the floor or something like that) they are not really dirty,...... for washing "clean" towels, don't use any soap, and of course never use fabric softener on towels.
    Jul 01, 2009 | LG WM-0532HW Front Load Washer
    My front loader doesn't use enough water.
    For low water volume - or "Trickling" effect...
    1. Turn off the water supply to both hoses.
    2. Remove hoses (one at a time so you don't get them confused)
    3. On the washer side - look for a removeable screen inside wher you just removed the hose.
    4. Using a small screwdriver - pop out the screen and reverse-flush it/clean it. It will likely be full of sediment and calcium deposits from your pipes.
    5. Replace the inlet screens.
    6. Re-fit the hose to the machine.
    7. Turn on water supply valves.
    8. re-try.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
    Feb 20, 2009 | Kenmore Elite 45986 Front Load Washer
    Where's the soap going?
    Clean the dispenser water hose ,stuck by liquid dried soup./ the hose going to washer was open during washing time so all soap loaded was gone /
    During water refill if nothing water pass to soap dispenser the soap will remain intact / but in washing time all soap will directly washout dispose to drain hose without to clean clothes.
    Jan 05, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    Clothes coming out dirty.
    A solution from the internet: Make a boil wash (with no clothes and detergents), put into the soap dispenser a cup of bicarbonate of soda.It should clean the machine and remove the bad smell. Another: I have a front loading machine also and am not willing to constantly clean out the machine -- the soap and fabric softeners you use are building up between the inner and outer drums (and on the drum itself sometimes). Because the machines door is so tightly sealed (to prevent water leakage) the smell from this buildup is awful. I finally found a solution. MAGGIE'S SOAP NUTS -- they are all natural (grow on trees) and will remove the grime from your drum and also clean your clothes (you won't even need fabric softener anymore). Stop using commercial detergents and fabric softeners and start using Maggie's Soap Nuts. They are not very cheap but they work great -- I have found that making a liquid out of the soapnuts and storing it in a bottle works better than putting them in the sack cloth they come with (because front loaders do not agitate constantly like regular machines, the cloth bag sits on the clothes and sometimes leaves a stain -- the liquid will not leave a stain. YOU WILL SOLVE YOUR PROBLEM AND HAVE SOFTER CLOTHES TO BOOT (without fabric softener so you save some money there). They are also better for septic tanks, the environment and your health! I believe Whole Foods sells them and they are also on the internet at www.Maggiessoapnuts.com Note: Also go to www.newstarget.com -- they are going to buy these in bulk to cut the cost in half but don't have them yet. You should be able to buy them there soon. Note: Forgot to tell you to run some of this thru your machine with hot water before washing your clothing to clean out the buildup that is already in the machine. Fixya is real cool.....
    Sep 12, 2007 | Whirlpool Ultimate Care II GSQ9669L Top...
    Washing Machines Logo
    54 people viewed this question
    Top LG Washing Machines Experts
    Dan Webster
    Dan Webster
    Gerry Harvey
    Gerry Harvey
    Are you a LG Washing Machine Expert? Answer questions, earn points and help others
