Question about Arris Computers & Internet
Arris modem blinking and won't let my ipad connect to internet
Just today this started...cannot connect either ipad
  • 400 Answers
Reset the modem. Unplug from power for about 30 seconds, replug and wait perhaps 2 minutes. Does it work now? If not, what lights are blinking? Depending on the model, the lights should tell you what is and is not working. The troubleshooting guide in the manual should tell you what is going on. You did not give a model number. I hope this helps you.
Posted on Mar 23, 2014
  • 86 Answers
SOURCE: cable modem + dlink router
Your modem needs to be rebooted in order for your router to pull an IP from the modem. To do this, look for a little hole in the back of your modem and use a pen to push the button. Wait for the reboot to finish and then try again in about 20 seconds.
Posted on Jan 20, 2008
SOURCE: Arris Modem connected to Mediacom Service
I didn't have incoming calls for a year (didn't mind, no telemarketers). But I fixed today.
Check with your home alarm company. Turns out they can download a signal. No, it wasn't the computer's internal modem, it wasn't the phone/cable company or the arris modem.
No need for service call.
Posted on Jul 31, 2008
  • 31 Answers
SOURCE: connecting my arris modem to x-box live
I have an Arris cable modem and use Xbox live. They work very well together. Most ISP's will only allow one active device at a time. When you switch between you cable modem and your Xbox you need to use a pen and press the reset button on the arris every single time you switch.
Posted on Apr 09, 2009
  • 31 Answers
SOURCE: i have an arris tm602gct and cannot connect thru my netgear
Can you connect if you are directly wired into the router?
You may want to try using a ball point pen and pressing the reset button on the back of the arris. Let it reboot and try again.
Some netgear routers come with the wireless disabled out of the box, so you need to be hard wired when you run the CD or if you try to connect through your browser 192.168.1.1
  • 17 Answers
SOURCE: Arris cable modem
if the power light is flashing then the modem is on battery backup and internet is disabled. plug the power cord into the modem or find a working power outlet, you should be set after that.
Power light flashing=bad
Posted on Jul 04, 2009
No matter what, when my arris reboots the DS light becomes solid, but the US light stays blinking. How do i fix this so i can get internet?
Have you talked to your ISP techies? Your modem has to be registered in their database before you get connected.
May 13, 2015 | Arris Computers & Internet
"Send" light keeps blinking and won't connect to the internet.
If you can connect to the modem from a computer, run its own test utilities.
If that doesn't return enough instructions either call the modem supplier or internet service provider - hopefully they'll be the same - with the test results, or consider a factory reset... not just a restart or a simple reset but a factory reset.
If the problem is with the modem, either a factory reset will solve it, or it needs replacing.
Be aware that a factory reseat will destroy all your settings
Nov 06, 2017 | Arris SURFboard SB4100 Modem
I have an Arris modem from Comcast that gives me phone and internet service. Prior to going to Comcast for telephony I used a regular, off the shelf, modem and I could connect to my Direct TV sat box via...
comcast use 10.0.0.1 for ip address, I think
check direct tv box for internet settings for it's ip address should 10.0.0.2 maybe call directv maybe they could further.
May 14, 2017 | Arris Touchstone 450a (CM450) Modem
I have my main computer set yp with arris router
  • You can use both Ethernet and USB interface to connect two PCs simultaneously with one cable modem.
  • If you plan to go wireless (and maybe connect more computers), you have to purchase a router to split/share the internet connection coming from the modem.
Apr 07, 2010 | Arris Touchstone 450a (CM450) Modem
My arris CM550A modem has all lights on but the link light is not blinking.wether it is connected to a router or to a computer there is no change. my isp also confirmed there is no disruption in service
As long as the modem is passing its data then i wouldn't really worry about the light not blinking. If you cant access the modem or it wont sync with a solid link light, then you have issues.
Feb 10, 2010 | Arris Touchstone 450a (CM450) Modem
We have just signed up for cable TV/high speed internet/cable telephone. The modem provided is an "Arris" version 1.5. The cable tech said I could connect my Belkin G router so that more than one computer...
Plug the ethernet net cord into the arris ethernet port. plug the other end into the router where it says "internet"
Plug a ethernet cable from one of the router ports to the computer.
First start up the arris modem, then power up the router, then start the computer.
Oct 22, 2009 | Belkin 802.11g Wireless Desktop Network...
I cant get out to the internet when I connect the netgear router.
Be sure that your cable company has enabled your internet. Power down the cable modem, power down any routers and computers. Start cable modem first, after internet connectivity is indicated, power up the router (if you have one) and then power upi the pc
Dec 27, 2008 | Arris Touchstone 450a (CM450) Modem
How is Arris Telephony Modem installed?
Hi taldrich6 - You have this listed under Arris CM450. Is that what you have?
Jul 22, 2008 | Arris Touchstone 450a (CM450) Modem
Jul 13, 2008 | Arris Touchstone 450a (CM450) Modem
Computers & Internet Logo
222 people viewed this question
Top Arris Computers & Internet Experts
bobkoure
Level 1 Expert
Jerry
Jerry
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
