Question about Breville Mini Smart Oven With Element IQ - BOV450XL
Breville mini oven shows only one setting, does not do toast or pizza etc
Turning the dial to any setting does not change display to anything other than 350 degrees. Toast function does not show darkness or slices options.
Black & Decker Toaster Oven CTO650 ... Numbers around dials has worn off. Where can I get a replacement panel?
Search Results
    Black & Decker CTO650 1500 Watts Toaster Oven - Read ...
    www.epinion.com/.../Black_Decker_CTO650_Toaster_Oven.../3529132...
    Black & Decker CTO650 1500 Watts Toaster Oven No complaints Is it really ... Cons:Numbers wear off around dials after years of wiping. ... It has a see-through glass door, 30 minute timer, variable temp up to 450 degrees F and signal bell.
    Black & Decker CTO650 1500 Watts Toaster Oven No complaints i should'a bought this one Is it ... Cons: Numbers wear off around dials after years of wiping. .... It hasa 4-slice or 9 pizza capacity and touch button controls with LCD display.
Jan 28, 2016 | Toaster Ovens
The oven does not heat up when I turn it on. what is wrong with it?
could be one of several things or several ,timer , switch ,element, fuse and on and on
Mar 17, 2015 | Toaster Ovens
What ever setting I use Toaster, Pizza etc the oven runs for 3 minutes and stops and in the read out window E 1 comes on the screen
Unplug the unit for at least 30 seconds. Plug in, set clock. When making pizza punch in the time you wish it to run, such as "7:30" then "start". Watch carefully the first time to see how much time it takes to cook to your liking.
Sep 03, 2014 | Oster Digital Countertop Oven With...
Black & Decker Toaster Oven - elements cycle on and off, which makes for a SLOW cook.
Oven has three modes: 1) oven mode cycles elements on and off to maintain a specific temp setting for up to 60 min. 2) toast should keep all elements on for a few min. 3) broil mode top elements only always on, up to 60 min. Make sure you have dials in correct position and use the toast timer.
Apr 17, 2014 | Toaster Ovens
I have 4 1132 Lincoln electric ovens. The 3 r at
What is the actual temp of the oven? Not what the display says? If the conveyor running normal? If so you just need a display board. Depending on what temp is there are many possibilties after that.
Sep 30, 2013 | Lincoln 1132-000-U 61" Electric Conveyor...
How do you set the clock on the delonghi DO400 toaster oven
  1. Press for 5 seconds the TEMP./SELECT/CLOCK but- ton (7) (the hours flash on the display).
  2. Press the TIME/TOAST COLOR buttons (8) to the desired time (hours). The time set will begin blinking on the display.
  3. Press the TEMP./SELECT/CLOCK but- ton (7) (the minutes flash on the display).
  4. Press the TIME/TOAST COLOR buttons (8) to the desired time (minutes). The time set will begin blinking on the display.
  5. Press the TEMP./SELECT/CLOCK but- ton (7) to confirm. It is pos- sible to press the button at any time during cooking to display the current time (the display shows the time set).
  • If you wish to change the hour on the display once it has been set, press the TEMP./SELECT/CLOCK but- ton (7) before proceeding to set the new time as described above.
  • It is possible to display the current time even after starting a function, by pressing the TEMP./SELECT/CLOCK button (7) (the time is displayed for 2 seconds).
Oct 14, 2010 | DeLonghi DO400 Toaster Oven with...
Can you toast bread in it?
You turn on the grill part, set the temperature dial to high wait a few minutes then place the bread on the grill tray provided.
You will need to position the grill tray near the top of the oven because that is where the elements are.
The grill gets hot so you will need to use tongs or gloves to gain access to the bread
Keep a careful eye on the bread because unlike a Toaster it will not eject the bread when it is done and it will catch fire.
Quicker and cheaper to buy a purpose built toaster and use the other one for doing casseroles etc
Jun 16, 2009 | Dualit 89100 1500 Watts Toaster Oven with...
Breville Mini Smart Oven With Element IQ - BOV450XL Logo
Top Breville Toaster Ovens Experts
Angel Joseph Jr.
Angel Joseph Jr.
Tom Chichester
Raviteja
Are you a Breville Toaster Oven Expert? Answer questions, earn points and help others
