Question about Dell Alienware M14x Notebook
Alienware M14x stuck on windows starting scren, the video card driver seems to have been disabled
Currently it boots up fine and then freezes on the starting windows screen, but then I hear the sound of it going to the screen to put in my password. I can put in my password and hear it go onto windows 7 desktop but it still shows just the windows starting screen. i have tried to go into boot options to see if I can somehow restore the computer, but with no luck.
  • Matthew Grindle
    Matthew Grindle Mar 23, 2014
    I forgot to note that I currently do not have my windows 7 CD with me, I am currently away from my house visiting family.
  •  Mike M
    Mike M Mar 23, 2014
    Looks like you'll have to wait for the win7 cd option.
  • Dell Master
  • 3,320 Answers
Try going in to Safe mode. This loads the basic drivers and if you have a problem with hardware, it will still open up Windows.
Turn on computer and immediately press F8.
Any hardware issues will show up in device manager.
Posted on Mar 23, 2014
Testimonial: "When I start up safe mode,it starts loading all the drivers and then stops at Loaded: \Windows\system32\drivers\CLASSPNP.sys and never does anything else. Just continues to sit there not responding. I guess I could try going into the boot-up menu and see if last known configuration might be helpful."
  • Matthew Grindle
    Last known configuration did not work either.
Nowuser
  • 56 Answers
SOURCE: Dell Inspiron 6000 monitor display problem
Well it is most likely a issue with the Video driver as you are able to boot to the safe mode.I would suggest going back to the safe mode and deleting the present driver for the video from the device manager.before you restart the system just download the latest version from the support.dell.com so that you can reinstall it.Also check in the graphic properties which screen is set to be the defuat.Incase still not working i would suggest reinstalling the operating system before replacing any hardware.
Posted on Jan 03, 2008
justin217
  • 85 Answers
SOURCE: Dell 610 here stuck on boot up screen with green vertical lines
If it is unable to boot up, its probably not a monitor issue, although it could well be without examing it. If your good with computers, you can take it apart and look to see if the lcd ribbon cable is torn or damaged. If you don't feel you can do it, contact dell support or take it to your local computer repair shop. I hope this helps!
Posted on Jul 15, 2009
  • 10 Answers
SOURCE: UN MOUNTABLE BOOT VOLUME ERROR - BLUE SCREEN
Place a Windows XP disk in to a drive and just after pressing power button keep pressing F10 or F12 to get to the boot menu then choose cd/dvd drive and follow procedures from the screen to repair or install system. ANother way is by pressing F1 or F2 or Del just after pressing power button to get to BIOS the go to Boot options and set firs cd/dvd drive then press F10 and enter.
Posted on Jul 20, 2009
efs_perpends
  • 1996 Answers
SOURCE: Dell Inspiron 1525 Lap (Vista) boots to a black screen
That is the advanced boot options screen for your system. REpair your computer is not always available. See here. It sounds like your system may boot into safe mode, so why do you wish to restore to factory default? Why not boot into safe mode, then use Windows system restore to restore your system to a point prior to the update.
That should get you up and running, and you can troubleshoot the cause of the conflict from there, using the Event Viewer, SFC /scannow, chkdsk, etc.
The black screen could be the result of malware on the system. In that case, I recommend you follow these malware removal protocols.
Good luck. If you have more questions, please ask...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Aug 25, 2009
  • 4 Answers
SOURCE: Laptop will boot up but only shows color lines/pixels
If you tried another monitor, and you've verified that the other monitor is campatible and functioning, then the problem is most likely the card. However, you might check the pins in the video cable you used on the other monitor. Also, when you used the other monitor, did you use the keyboard controls to direct the video output to the other screen. If you don't know how to do this, you should be able to dicipher the controls by looking at your keyboard for something that looks like a monitor. Each laptop has slightly different controls. Mine is the function key+the F4 key. Typically there's a cycle in this control. e.g. 1st time pressed = both monitors, 2nd time pressed, just other monitor, 3rd time pressed=laptop monitor.
Hope this helps.
Posted on Dec 12, 2009
Testimonial: "detail answers and steps for amature PC users.."
SD Card and disc stuck in CD slot of Alienware M14x?
try taking a small piece of wire and bending a small hook into one end slide it in on TOP of the stuck disc and hooking the center hole of the disc, (you don't want to get the wire under the disc because you could damage the disc reading hardware) also once you have the disk hooked you may have to use the tweezers to gently hold the front of the disc up to align with the slot as your pulling it out. you should feel a little resistance but don't try to force the disc out too hard.
Mar 23, 2015 | Dell Alienware M14x Notebook
Need to set parental controls on alienware m14x
Activate Parental Controls b> Computers are great tools that help us in work, education and entertainment. They're versatile machines and provide great benefits, but that versatility opens the door for users to access inappropriate content. Microsoft Windows offers a number of controls to restrict or entirely block access to many content types. Unfortunately, the Parental Controls feature is not available in Windows XP or earlier systems, but Windows Vista and 7 have the utility preinstalled. You can set up the controls in a few steps and help protect anyone that uses your computer.
Click the "Start" button in the lower left corner of your screen and then click "Control Panel." Click "Control Panel Home" on the left of the Control Panel window, if it is not already selected. Click "Set Up Parental Controls for Any User." Select the account for which you want to set up controls. This is the "User Controls" section of that account. Select the "On, Enforce Current Settings" option on the left side of the window Click "OK." This activates whatever settings are currently on the computer. Parental Control Settings b> Access the "User Controls" section of the account you want to restrict. Select the type of control you wish to alter or put into effect. Your options include "Time Limits," "Games" and "Allow and Block Specific Programs." Windows Vista also has "Windows Vista Web Filter." Restrict when an account may be used under "Time Limits." You can set what hours the account is available for each day of the week. Set game rating limitations. These settings allow you to select which game rating is the highest permissible for that user. Restrict certain programs. You can block the use of whatever programs you prefer, such as video games or Web browsers. Set Internet restrictions. In Windows Vista, you can decide how strict to make the restriction level immediately; in Windows 7, you must first install the free Windows Live Family Safety 2011 suite http://explore.live.com/windows-live-family-safety?os=other Click the "OK" button in the "User Controls" section once you are finished with the control setup.
b>
Feb 12, 2013 | Alienware PC Systems Alienware M14X 140...
My m14x keeps shutting down when i usethe keyboard
Open Control Panel, Power Options, Set to High Performance, Open Advanced Power settings, Set Sleep and Hibernate to Never, adjust other advanced settings to your preference. If this fails to fix, Return it at once while your warranty is valid. After Dell bought Alienware they sort of went south.
Jan 23, 2013 | Dell Alienware M14x (dkfobs15) PC Notebook
My computer says my integrated webcam is working but when i try to use it on Oovoo it says the device is not found?
Hi I bought dell alienware M15X from my friend's at ma friend place its working fine, but after re install the window's the keyboard.speaker and back lights not working at all, even i try to download new version of CC, un install and install again twice time, but problem is still same, is there any 1 can help me out from this problem, THNX
Jan 22, 2013 | Alienware PC Systems Alienware M14X 140...
Is it possible to connect PS3 to Alienware m14x?
I know people who have tried but haven't had much luck. They use a USB capture device in review mode instead but you may get a slight delay on some cheap models but a good quality one is pretty instant.
Hope this helps
Barry
Apr 08, 2012 | Dell Alienware M14x Notebook
Alienware m14x battery won't charge
Remove main battery, get a stiff toothbrush and clean battery terminal in laptop and prongs on batteries. Install battery and charge, if no change! rechargeable battery needs to be replaced.
Mar 22, 2012 | Dell Alienware M14x Notebook
Dell Alienware M14x Notebook Logo
79 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
