Question about Fisher and Paykel GWL11 Top Load Washer
Fisher Paykel MW512 5.5kg top load washer won't fill, water pulses on and off... it'll spin as it fills okay, and then suddenly stop and seems to have trouble spinning suddenly, then it'll beep until
It used to have trouble just during the spin cycle, shutting off, but now it won't fill either.
gittos73
  • 244 Answers
SOURCE: Fisher & Paykel "clog Problem"
the water comes through 2 vavle 1 for washing and the other for rinsing more than likely that the rinse valve is down it will need replacing thats the more common fault for washers not rinsing
Posted on Aug 12, 2007
IFIXALL
  • 868 Answers
SOURCE: Fisher Paykel GWL11 Top Loader Washer
Please dont put any more money into this machine,if you wait long enough it will take alot more than a penny.
Posted on May 25, 2008
RescueTech
  • 145 Answers
SOURCE: Fisher paykel gwl10us wont fill
Both of you most likely are getting a "RPS Sensor Fault"
On a GWL10, when the motor rotor position sensor fails, it will act exactly like you describe. Many techs incorrectly replace the machine control or the water inlet valve(s). The RPS sensor is much cheaper. If you consult the tech sheet located under the control panel, you will see the fault code for RPS failure and I would bet the farm that the sequence of LEDs displayed when your washer faults out matches exactly with the RPS fault code.
The RPS sensor for GWL10 and GWL11 models is a part # 420296P and canbe purchased direct from Fisher Paykel Parts:
http://fisherpaykelparts.net/index.php?categoryid=111&productid=5
The procedure to replace it is a little involved but a handy person can do it. It would be best to consult the factory service manual and again, that can be purchased from Fisher Paykel Parts direct here:
http://fisherpaykelparts.net/index.php?categoryid=115&productid=15
Posted on Dec 15, 2008
appldoctom
  • 311 Answers
SOURCE: fisher paykel will not complete rinse spin cycle
will sence it will spin once the water is out .that must mean your pump is restricted.unplug go to buttom of washer find pump and clean out
Posted on Dec 31, 2008
  • 10 Answers
SOURCE: Fisher & Paykel GW612 Top Loading Washing
Hi there
That fault is the pump blocked error (no change in water level).
i have a quick and easy way to solve this problem.
first turn the machine off then tilt the machine back and lean it on something(a chair or wall), look underneath, in the top right hand corner of the plastic outer boul you will see a small pump motor it has a fan on it spin this fan and if it is hard to turn that means there is somthing stuck in the drain pump keep turning the fan and try to free whatever is stuck in the pump, then try the machine on spin again all goin well the object in the pump should come out with the drain water(doing this will not harm the machine) if the object is still stuck you will need to get the water out of the machine (bailing or siphioning will work) and tilt the machine back again and take the wires off the pump and there should be a white tab on the boul holding the pump on pull this tab and twist the pump anticlockwise about a quarter turn(you will need a few towels or a boul or bucket to catch the water) and it should come off exposing the blockage.
Hope this solves your Problem.
Nick
Posted on Aug 03, 2009
Replaced water pump and control panel, have power, but just beeps.
Fisher and Paykel GWL11 Top Loading Washer
ths.gardenweb.com > Home Forums > Laundry Room
Mar 5, 2008 - My GWL11 Top loading washer has had nothing but problems! ... 4) (Rinse Phase) Drain the water, then lock the lid for spin. ..... I plug the power cord in and I have nothing on the control panel. ..... As the controller was only replaced early in January, I've flicked F&P NZ an email to see if it's still under ...
How to repair a Fisher Paykel Washing Machine
www.instructables.com/.../How-to-repair-a-Fisher-Paykel-W...
InstructablesI removed the pump and control panel, found no blockage in the pump, so far ... Ihave just tried to fill my F/P machine but the water is just dripping in. ... I have aFisher Paykel washer have replaced the control module and now it .... washing machine MW612, stopped working and displayed beeping sound every second.
Jan 16, 2016 | Fisher and Paykel GWL11 Top Load Washer
Washing machine starts and stops
www.docstoc.com/docs/.../Fisher-and-Paykel-Circuit-Diagram-GWL11
http://washingmachinemanual.com/tag/user-repair-manuals-fisher-and-paykel-gwl11-top-load-washer/
Above is your service manual and a circuit diagram, Simply use the troubleshooting steps and you will soon isolate your issue and effect a repair.
May 29, 2010 | Fisher and Paykel GWL11 Top Load Washer
My fisher paykel eco-smart washer is filling up with water at the same time it is pumping the water out the drain.
My washer is filling up..but not very high and at the same time it is pumping out water into the sink. Will not spin or rinse
Jan 01, 2010 | Fisher and Paykel WA37TG1 Top Load Stacked...
It is very cold in my garage where my Fisher and Paykel washing machine is. First it would not fill it just ran and ran without filling, then it started filling fine, but then after a while started...
water freezes. sounds like first your fill pipes were froze then the pump froze. if you can find a place inside the house for washer or you may have to build a room around washer and dryer and heat it
Dec 13, 2009 | Fisher and Paykel GWL11 Top Load Washer
Fisher & paykel fill up with water then
Yep it sounds like another electronics panel has failed.
We never had this much trouble in the old days with the old electric timer machines.
Oct 19, 2009 | Fisher and Paykel GWL11 Top Load Washer
Intermittent water flow interupted by solenoids pulsing
I've got the same problem. If I pause the cycle, wait about 10 seconds, and then resume, the water starts normally. I suspect the Cold Water Inlet Solenoid is sticking, probably due to water sediment in the solenoid causing it to stick. I'll try cleaning it and then replace if that doesn't help and let you know what happens.
Sep 22, 2009 | Fisher and Paykel GWL11 Top Load Washer
Have a Fisher abd Paykel smartdrive excellance 7.5 all the lights workwill fill wiht water but will not spin by openeing ancl closing the lid you get 1/2 sec try to spin then nothing all you hear is a low...
fisher and paykel 6.5 excellence kelvinator washing machine,lights up,no water,checked hoses to the tap .water comes to the machine ,fill plastic reserve. no water goes in the tumbler.,? .any suggestions.thanks
Aug 15, 2009 | Fisher and Paykel IWL12 Top Load Washer
My washer won't stop filling up with water!
This is a faulty water valve assembly. replace asap if possible. the embedded water pressure sensor is damaged.
May 29, 2009 | Fisher and Paykel WA37T26G Top Load Washer
Stackable Washer Dryer won't fill with water
hi
first thought would be water soleniods but it is unlikely that both would fail you could try just selecting one temp and then swaping hose and select the other temp if it wont work on either then i would think it is not a sol. problem, lid switch could cause it not to fill also but you did say it would spin so that will rule it out ,its coming back to a module problem ,something to ponder on
cheers grant
Aug 17, 2007 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
46 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
