Question about Samsung Computers & Internet
Fix pedestal for samsung 740BF
Part that holds monitor to pedestal is broken
  • 56 Answers
You can buy a wall mount for under 12 bucks. Or alternately you can buy an VESA 100 mm compatible stand for about 30 bucks
There're are out there lots of solutions for LCD, arms for mounting in desk, wall or poles.
Posted on Mar 25, 2014
Electrolux pedestal drawer won't close
Good Afternoon Apetgroomer,
I see that you're having trouble with your Electrolux pedestal drawer, model# EPWD15TS, door not closing. There are 2 pieces inside the drawer that help to keep the drawer shut that could be broken. One is the drawer strike, which is actually attached to the drawer itself. The other is the drawer actuator, which is attached to the casing which holds the drawer. Check both of these parts, and if it is one of them, i suggest contacting the manufacturer to se if they have any replacement parts.
-Best Regards-
WP
Apr 02, 2014 | Electrolux 15 Turquoise Sky Pedestal...
Broken samsung 740BF pedestal
The way computer monitors are made today, there is no extra runs for repair parts. You could use a monitor stand whereby you detach the broken stand and attach to a new stand.
Mar 22, 2014 | Samsung Computers & Internet
Remove pedistal base from 24h898 aoc envision tv
You need to remove the cover that hides the 4 screws that hold the stand to the monitor. There are 3 pieces to the pedestal base. The base plate, the pedestal, and the screw cover. To remove the screw cover, look on the back where the pedestal attaches to the monitor. There is a cover just above the pedestal. Pinch the top left and top right sides (about one inch from edge) to unclip the cover. Remove the 4 silver screws (2 on each tab) and put them in a ziploc bag to avoid losing them. Tape them to the pedestal/base and cover.
Jan 18, 2014 | AOC 24 Envision L24H898 1080p Widescreen...
My samsung syncmaster 740bf monitor has developed a problem, a few minutes after start up the monitor screen just goes blank (white), but you can be able to0 revert back to the normal screen by pressing...
White glowing screen is indicating that the T-CON board on the LCD panel assembly is not getting the signals or voltages from the main board, you may inspect the caps in the power supply and in the main logic board first.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Jan 04, 2011 | Samsung SyncMaster 740BF 17" LCD Monitor
Hllo, samsung 740bf screen not working
Try it with another PC first.
Look for bad caps in the power supply first.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Sep 02, 2010 | Samsung SyncMaster 740BF 17" LCD Monitor
Line on monitor samsung syncmaster740bf
Open the monitor, examine the circuit boards. Look for small components that look like small cans, these are capacitors. If you see any that look bulged on top, then your problem can probably be solved by replacing these. Check out the following sites;
http://www.youtube.com/watch?v=9Q6_TgNJvQw
Follow the directions and good luck!
May 08, 2010 | Samsung SyncMaster 740BF 17" LCD Monitor
Pedestal for Samsung washer & dryer, will other brands fit too?
Just bought a red Samsung washer/dryer, looking for pedestals, but don't want to buy $200.00 ea., any suggestions
May 07, 2010 | Samsung WE356A5W Washer/Dryer Laundry...
How do I open my Samsung 2233sw LCD monitor? I need to open it because something is lose inside going all over the place and I don't want it to short out.
ericc539, To actually SEE how it is done, you could try a visit to YOUTUBE and search for video clips of "lcd monitor repair" and or "lcd monitor disassembly" !!!! My only advice to you is "don't use any sharp cutting instruments like carving knives to part the front bezel from the rear cover after any screws and pedestal have been removed. Could more than triple cost of repair if trip to hospital "ER" is required to fix monitor. Good luck. 12fixlouie
Apr 08, 2010 | Samsung SyncMaster 2233BW 22" LCD Monitor
What is a DVI cable purpose? can the 740bf work without it julianb2005
The DVI cable provide higher resolution signals than a standard VGA cable. You can get a DVI to VGA converter at electronic stores such as Radio Shack or best buy etc. The monitor will work fine with the adapter connected to it.
Nov 15, 2009 | Computers & Internet
Computers & Internet Logo
88 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
