Question about Kenmore 24032\24036 Top Load Washer
I have a kenmore top load washer model 110.92582100 serial # CD1819383. it stops/starts frequently in the wash cycle (every 20 seconds or so it cuts off... then starts back up and then cuts off...etc...) the tub does fill with water; it does agitate and it does drain ok... is this a timer or circuit board problem, perhaps?? Thanks for any ideas and advice.
  • 1 more comment
  • philbee62 Jun 15, 2009
    thanks guys, how can i take the timer off? i have read some posts that suggest i check for burned contacts on the timer plug. i have opened the top control panel and have unscrewed the knob. i have also unclipped/removed the clear plastic part. now, i can't figure out how to remove the remaining black part on the front of the panel so that i can removed the timer box. thanks for any links/pics/explanation.
    i was able to pull that last piece straigt out and then i was able to unscrew/remove the timer. i looked at the contacts and they are not burned, as i have seen this problem in other posts. do you think the timer is likely my problem? If so, I'll oblige to have a local professional look it over. thanks again. phil
    i called a local repair tech to give me peace of mind... he confirmed it was the timer... he charged $120 for the part and $72 for labor+25% discount with a coupon i found.... seemed reasonable. thanks guys for your help and advice.
  • Kenmore Master
  • 3,361 Answers
Remove the cabinet to access the motor wire harness. Make sure it is plugged in really good.While it is removed, inspect all the wires carefully for a pinched or otherwise bad wire. If the motor wire harness is not the problem the timer will be.
Posted on Jun 14, 2009
  • steve
    steve Jun 15, 2009
    There are 2 screws through the front of the timer behind the knob holding the timer in.
    However, you do not need to remove the timer unless you know it is bad.Check the wires and the plug at the motor.
  • 867 Answers
There seems to be a sensor problem of some sort or sticky switch, you may need a repairman for a complex problem as this
Why does a Kenmore washer not finish the cycle?
Washer Repair - Not Advancing -Repair & Diagnostic ...
? 8:30
https://www.youtube.com/watch?v=IEr9A7uhdN8
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Repair your Kenmore Top Load Washer suffering from these following issues: Will Not Advance Past Rinse ...
Kenmore washer doesn't complete final spin cycle - ApplianceBlog
www.applianceblog.com/.../31894-Kenmore-washer-doesn-t-complete-fi...
May 16, 2012 - 9 posts - ‎2 authors hello, my kenmore washer doesn't complete the final spin cycle. i ... Does it stop in the middle of the final spin cycle or does it not go into the ... FIXED Kenmore Washer - Not finishing the spin cycle
Dec 20, 2014
FIXED Washing Machine Does Not Complete Cycle ...
Mar 14, 2013
FIXED Kenmore washer won't spin out all water from ...
Jun 27, 2009
FIXED GE front load washer WCVH6260F0WW stops ...
Jul 2, 2007
More results from www.applianceblog.com
Nov 05, 2015 | Kenmore Washing Machines
The washer quits half way thru the cycle and we have to push the stop button, wait a few seconds and push start again, it starts and then stops once again and we to repeat this process. Afterward, it...
How old is your washer? There is a problem with certain models that require an upgrade. Here is a number to call 1-800-659-7026. Give them your model number and serial number off of the machine. This problem is with the control board.
Dec 26, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Washer aggitate for 20 seconds then stops, starts
This could be your control switch. Remove the front cover at the top that has the dials on. Check main switch unit, it probably needs to be rebuilt, about $35 or installed new.
Nov 01, 2009 | Kenmore 22422 Top Load Washer
I own a kenmore top loading machine model number 110 10 amp 60 hertz 120 volts the machine gets power and runs but the big control knob that controls the diffrent cycles is running only about 20 seconds...
sounds like you should replace timer (big control) timer motor is part of timer. Is timer knob speeding thru cycle that fast or just start/stop.
110 is manufacturer code for whirlpool, number after decimal is model number. tech sheet avail inside console by unsnapping left and right console covers and removing hidden screw at front bottom corners, pull forward slightly then fold console back (hinged at rear top).
Apr 26, 2009 | Kenmore 22642 Top Load Washer
F1 error code on Kenmore Oasis He
Moister can get in between the contacts,is it in a high moister environment? Try using a hair dryer on the panel to dry it out.Also unplug it to reset.
Hope this helped.Let me know by rating me
For more help go to live chat.
lenwest
Jan 31, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
3 quick beeps during cycle if you can get it to stay in a cycle
MY KENMORE OASIS HE IS DRIVING ME CRAZY! THE CYCLE SIGNAL CONTINUES TO BEEP AT LEAST 25 TIMES, STOPS FOR MAYBE 20 SECONDS, THEN BEEPS AGAIN ABOUT 25 TIMES. THE WASHER WORKS GREAT, BUT IT WILL NOT STOP BEEPING! HELP!!!!!
Sep 13, 2008 | Kenmore Oasis HE 27062 Top Load Washer
3 audible beeps every 20-25 seconds
Try unplugging the washer for about 20 minutes then plug back in and use. I have found that this actually works! The only thing I can figure out is that it takes time for the electronic control to clear. If that doesn't fix the problem I would call sears tech since it is less than a year old. They have a 1-2 year warranty.
Dec 21, 2007 | Kenmore Oasis HE 27062 Top Load Washer
Kenmore 44072 Front Load Washer help
my kenmore washing machine has the timer out of time
Aug 08, 2007 | Kenmore 44072 Front Load Washer
Kenmore 24032\24036 Top Load Washer Logo
130 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
