Question about Wood Technology 4050.845.060 - Whisper Ride TV Lift Black
Whisper Ride TV Lift inoperative
About 3/4 of the way down the mechanism stopped. It will not go into the cabinet, nor will it come back up. Replaced batteries in the remote, nothing. Tried the manual rocker switch, nothing. What could be wrong?
Whisper quiet plus
There should be two thin metal tabs on top of dishwasher that extend out and attached to the underside of counter top. They may have been bent back or they are broken off
Mar 24, 2014 | Whirlpool Dishwashers
The washer tub won't come out
These drums ride on bearings. Remove the back cover of the dryer and then remove the cabinet from the frame, tub and motor assembly. Reposition the tub for the bearings and reinstall. time est 30 min.
Jan 12, 2014 | Whirlpool GEQ9800P Electric Dryer
How to repair a rotation switch
Tips are here
  • 1
    Unplug your washing machine. Make sure there is no power going to the washing machine.
  • 2
    Remove the screws from the cabinet top. Use the screwdrivers and the wrenches because you will have regular screws and bolt-head screws.
  • Lift off the cabinet top. You may have to lift the front part slightly and pull outward, or pull outward first and then lift the cabinet top off.
  • 4
    Locate the plastic switch and remove it. Pay attention to how the old switch is connected to the probes.
  • 5
    Install the new switch, attaching the probes in the same manner as the old switch. Some washing machines have clip-type probes, while others will have a U-shaped connector that is meant to be held with screws to the probe areas.
  • 6
    Replace your cabinet lid in the opposite steps you took it off. If you had to slide, then lift, set the cabinet lid down and then slide it backward. If you had to lift, then slide, set the back edge down, while keeping the cabinet tilted slightly, slide it back and then set it the rest of the way down.
  • 7
    Replace all of the screws and bolt-head screws in the proper locations, again using the screwdriver and wrenches.
  • 8
    Plug your washing machine back into the socket. Test the switch by turning on a cycle of the machine. Make sure that it is filling up, agitating, and spinning properly.
  • X2 Performance Chip
    Jun 19, 2012 | Washing Machines
    Door would not close all the way
    DOES IT REVERSE OR STOPS BUT NOT TOUCHING THE FLOOR?
    IF IT DOESN'T TOUCH THE FLOOR YOU EITHER NEED TO ADJUST THE DOWN TRAVEL OR LENGTHEN THE CONNECTING ARM.
    IF IT REVERSES YOU NEED TO DETERMINE IF IT IS THE SENSITIVITY OR THE SAFETY EYES.
    Jan 19, 2010 | Chamberlain 1/2-HP Whisper Drive Belt...
    Turntable mechanism is not working
    you will have to take it off the wall. There should be three screws in the cabinet above the unit . 1. unplug unit 2 place a large towel under unit to protect stove or cabinet 3 have someone support unit while u remove threee phillips screws 4 the back will hang on the wall rotate down lift and remove. the turn table is usually ran by a rubber belt and motor. Hope this was helpful please rate me
    Jan 12, 2009 | Sanyo EM-S8000 Microwave Oven
    Kenmore dryer
    It is very much easier to replace the belt from the front, than the back, the cabinet disassembles from the front, and the mechanism remians attached to the rear plate and cabinet floor.
    • pull lint filter out
    • remove 2 screws from under lint filter
    • with putty knife or other blunt blade, release clips at front corners of cabinet top
    • tilt up cabinet top
    • remove 1screw 1/3 way down each side of front of cabinet.
    • lift off cabinet front
    • drum, motor, tensioner, are all exposed
    • lift drum out forward
    • check rollers, drum felts, nylon glide bearings for wear
      (worn bearing surfaces are the most common cause of belt breakage and you dont want to do it again next month)
    • reinstall tensioner in slots in cabinet floor, reinstall tensioner spring between tensioner and cabinet floor
      (Once the cabinet is open the tensioner mounts are easily visible)
    • loop belt around drum at the wear marks of the prior belt
    • reinstall drum on unworn bearing rollers etc
    • loop belt around motor pulley
    • pull tensioner hard against spring to end of travel
    • loop belt around tensioner
    • relax tensioner
    • spin drum by hand to ensure belt isnt going to jump off
    reinstall cabinet in reverse order
    ~15 MINUTES, but I do 3-4 per day
    Oct 07, 2008 | Kenmore 62602 Electric Dryer
    Taking off shell of washing machine
    Remove the shell:
    nplug the machine. Remove the end caps on both sides of the console by putting a flat screwdriver in the top of the end caps from the back and gently prying up. Remove the two Phillips screws holding the corners of the console down. Lift the console and gently fold back. Unplug the lid switch. That's the 3-wire quick disconnect below the timer. (If you have a high price model, you'll have three hoses under a plastic cover on the left. disconnect those hoses before going further.)
    Using a flat screwdriver remove the gold clips holding the cabinet to the back. Place the blade of the screwdriver in the indentation closest to you and tilt the handle of the screwdriver back.
    Open the lid. Lift and tilt the entire cabinet toward you. Look down through the hole to the front bottom edge of the cabinet. It is hooked under the front edge of the washer frame. Remove the cabinet and place it aside.
    Replacing the shell:
    Pick up the cabinet, hook it under the front of the frame, and tilt it back into place. Push the sides of the cabinet in as you are tilting it back to make sure the hooks in the frame (back, sides) line up with the cabinet. You can know it's in place when the edges of the cabinet line up evenly with the edges of the back.
    Re-install the gold clips. Hook them into the back panel, put them into the slots in the cabinet, and push down until they snap into place. Re-connect the lid switch. Lower the console. Replace the screws. Replace the end caps - bottom first, then snap them in at the top.
    Happy washing!
    Mar 11, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
    Symphonic sc1304, vcr problem
    Pulley belt stretched, replace. Remove the back cover to tv, slide the chassis out, remove speaker connector, and other ones to allow the chassis to be out away from cabinet to take the metal cover off surrouding the vcr unit. Usually a couple of screws that hold the whole vcr unit in, remove these, lift the unit from the chassis carefully and check the belt as it is stretched and not making tight grip on the white pulleys that perform the mechanical functions of the VCR. When putting back together, and replaced the belt be sure to lift the vcr door inward before sliding the chassis back into cabinet so the door latch will open and close properly, otherwise you put a tape in and the door won't open back up.
    Jun 04, 2007 | Symphonic SC3813 13 in. TV/VCR Combo
    Wood Technology 4050.845.060 - Whisper Ride TV Lift Black Logo
    18 people viewed this question
    Top Wood Technology Televison & Video Experts
    Electro Med Services...
    Are you a Wood Technology Televison and Video Expert? Answer questions, earn points and help others
