Question about Kenmore Elite HE3 Steam 8674 Dryer
Siemens dryer powers on, but will not tumble.
I took my dryer apart to clean all the lint out of the vent fan. Now, it powers on, but will not tumble or start drying.
    Scholar:
    New Friend:
  • 111 Answers
Work on mainly Whirlpool Products did you put the belt on correctly there is probably a belt switch which is closed with a properly installed belt it is under the spring loaded idler pulley or maybe you for got to hook up the door switch hope this helps.
Posted on Mar 23, 2014
JR JR
  • 116 Answers
SOURCE: check lint screen light on and dryer not turning on
check belt might be broken,,,,
Posted on Nov 30, 2008
SOURCE: kenmore dryer
This may not be the solution to your exact problem but for those looking for why there timer will not advance and why it keeps running even when the items are dry: The usual problem is not the timer but the mosture sensor (if your dryer has one).
1: Check the mosture sensor light/indicator. If is still shows some mosture or flashes even when the items are dry, you have a mosture sensor problem, probably not a timer issue - luck you.
2: Check if the timer will advance and the dryer will turn off when you have it in the TIMED mode (i.e. 10mins - NOT the more/less dry modes.) If so, then it is indeed a sensor problem.
2: Check that the wires to the mosture sensor have not fallen off (as in my case - a simple repair). The senor is usually two metal bars somewhere near the front part of the inside of your dryer. You may have to take off the door and the front pannel (be sure to unplug the dryer first) to get at the two wires to clip on to the sensor. Clean any lint and make sure they are conneted. If well connected then replace the sensor ($15-$20 and very easy to do).
Posted on Jul 01, 2008
jsrock516
  • 5911 Answers
SOURCE: Kenmore dryer...How to remove toe panel to clean lint out.
Insert a putty knife into the seam where it meets the front panel about 2 inches in from each side. There is a small retainer clip that you will need top depress in order for the panel to release. If you go to searspartsdirect.com and enter your model number, you can find a helpful illustration under the "Cabinet" heading. The clips I mention are listed as item 46 just ot give you a perspective. I would also strongly recommend that you UNPLUG the dryer before cleaning the interior cabinet. There are live voltages present even with the dryer turned off. Particulary around the heating circuits. I hope you find this information helpful.
Posted on Oct 29, 2008
  • 17 Answers
SOURCE: My Kenmore Elite HE3 Dryer is not drying.
It may not be your heating element. Your dryer lint vent pipe out the back of the machine or maybe out the side may be plugged. You have to pull the machine out and clear that pipe or rebuild it out to a soffit vent or static vent if it is in the attic, or out through your crawl space. This will make a huge difference. If that hot air and moisture doesn't get out of the machine it just goes back into your clothes.
Good luck!!
Posted on Mar 25, 2009
jsrock516
  • 5911 Answers
SOURCE: Clean Dryer Lint Vent in Kenmore elite HE4
If you wish to clean the interior cabinet of the dryer follow these steps:
1. UNPLUG the dryer. Dangerous voltages are still present even with the dryer turned off.
2. Open the dryer door and remove the lint screen. IMPORTANT: You must remove the lint screen first in order to remove the blower fan housing.
3. Remove the lower toe panel directly below the dryer door by removing the screws under the bottom front edge of the panel. With the screws removed, the panel will drop down, then come off. NOTE: For better access, you can prop the front feet of the dryer up (a 2x4 works well).
4. Loosen the screws on the blower fan housing directly below the drum and remove. There's usually a small clip holding the cover in at the bottom that you may need to pull out to release. NOTE: You may also have to disconnect the auto dry sensor plug (yellow wires with white plug - use a small screwdriver to release the locking tabs) and/or ground wire to accommodate removal of the cover.
You should now have access to the dryer interior and the blower fan squirrel cage motor. Take the time to clean out the blower fan housing cover as well. A long bristle brush made for dryers works well at removing any lint inside the dryer in the hard to reach places, followed by vacuuming.
NOTE: After cleaning, you may experience a slight burning odor. This is normal as lint gets stirred up in the cleaning process and can settle on the heating components. The odor should dissipate after a short period of use.
If you have any questions, please let me know. I hope this helps you.
Posted on Sep 29, 2009
Tumble dryer overheating
Check and clean your lint filter. If problem persists, check the discharge of your dryer vent. A clogged dryer vents will cause abnormal heat build up in a dryer.
Feb 17, 2012 | Dryers
The tumble dryer is working perfectly and is vented through the external wall with a plastic hose , however the dryer is producing high moisture levels we have checked the connection fro the dryer to the...
Your problem is probably a heavy lint build up in the Dryer or Hose.
Check your blower system on the dryer for a heavy lint build up, also remove to clean or vaccum or whatever is necessary to clean the plastic tubing because they will still flow some air, but be really plugged up with lint and could cause a dryer fire.
This is a free answer, Please rate me
Apr 11, 2011 | Dryers
Dryer Model LER3624JQ0 tumbles clothes, has heat, but clothes are hot and damp. Cleaned lint filter & took of vent in back (thought maybe clogged wall vent) but didn't help. Don't think much (if any)...
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Mar 20, 2011 | Whirlpool LER3624JQ Electric Dryer
Hi, My maytag bravos dryer is one year and 2 months old. Suddenly it has stopped drying the clothes, it takes forever to dry a load and clothes are very warm and wet, lots of steam in the dryer, also the...
Sounds like the exhaust fan is not working. There's an electric blower at the back of the unit that forces air out through the exhaust vent. Unplug the unit, pull the vent off the back, and see if you can reach in and touch the fan blades and make them move. If it won't move something is probably caught in there. You may need to take off the back of the unit and remove the housing cover to the fan assembly in order to really tell what's going on, but it sounds like your fan has an obstruction. It could also be that the fan motor is fried but that seems less likely. Remember to have the unit unplugged, there's some dangerous voltage inside.
Jan 03, 2011 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
We have a Kenmore 80 gas dryer that tumbles, has hot air, but takes 2 hrs to dry. Vent line is clear, but lint filter is getting lint on back side of filter as well as normal amount on correct side. The...
Have you cleaned out the lint build-up from inside of the dryer yet? When you disconnect the vent from the back of the dryer, look inside the dryer. It probably have years of lint build up covering everything and needs cleaned out. You also will need to clean out the filter reservoir (with the filter removed) if you can get to it with a vacuum attachment. Be sure to unplug the cord and close the gas valve while you are working on it. Also be sure your vent flap outside is not stuck and allows hot air to open it when in use. Lastly, when you push the dryer back into place, make sure you don't squish the vent tubing if it is an expandable plastic or foil vent, which will restrict air flow and cause drying clothes to take longer. Hope this helps. Douglas
Jun 03, 2010 | Kenmore Dryers
Clothes dryer produces black soot when drying and leaves clothes darkened
lint build up is on heat element canister. take dryer apart on clean with a good vacumm cleaner. unplug first.
Mar 02, 2010 | Dryers
Estate dryer do's not dry fast anymoe
Couple of things to check, the blower fan assembly that is close to the lint filter, might be clogged or the exhaust duct hose might be too long and has too many bents, that restricts the air flow. check also outside for restrictions
Jan 06, 2010 | Estate Dryers
My dryer heats,tumbles,but takes several cycles to dry a load(small).Not much air coming out of vent and have cleaned vent out.Any ideas?
The fan that pulls the hot air through the dryer and pushes the exhaust out through the vent hose is plugged with lint. You will want to remove the cover on the fan and manually clean the fan out. I had the same problem with my dryer, I was astounded by the amount of lint that was trapped in the fan.
Also look inside the cloths drum on the back wall and make certain the hole in that wall are not clogged with lint also. Use a flash light and make sure the hole are perfectly clean.
Good luck, clean it all out and let me know.
Regards,
Sep 09, 2009 | Maytag Dryers
Black carbon/soot on the door and lint filter of my dryer
Soot would mean lint is circulating around in your machine, and getting to the combustion area. Take the machine all apart and clean it thoroughly, including taking the cover off the fan and cleaning it too. A dirty fan will slow down the whole works. Check with your hardware store for a chimney-sweep's brush. I once bought one that could be tied to ropes and pulled up and down a flue. If they have a brush the right size, you could do that and really clean your dryer vent.
May 12, 2009 | Crosley CDG6000 Gas Dryer
Kenmore Elite HE3 Steam 8674 Dryer Logo
211 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
