Acomdata hd750uhe572 hear like the clock clicking sound, light is not flashing, computer has sound like an USB device detached but no drive shows up in "my computer" or in device manager
PauldLucky
  • 268 Answers
SOURCE: Acomdata external hard drive
No ned to check in that.
The external hard drive can be fomatted by :
Open the my computer, in the my computer or explorer window you should see the drive letter for the external drive.
Right click on the drive you will get the popup menu.
In that select the format option.
But always use NTFS file formatting system.NTFS provides several advantages over FAT32, including support for larger ile sizes.
Use the full format option.
Wait for sometime, until the format is completed.
Then you are good to go.
Good Luck.
Live, Love, Laugh.
Posted on May 09, 2008
SOURCE: EISA configuration
I believe that he EISA configured partition is where your computer manufacturers 'Restore System' data is kept so that you can't normally access it and mess it up. You seem to have gone to a lot of trouble to do work around that.
I would be interested to know if you can still restore your system now using the data that you transferred to a different partition?
Posted on Jun 09, 2008
SOURCE: External drive recognized as CD drive
You need to do a firmware flash. It worked for me. Here's the link to the fix.
http://www.techsupportlive.com/index.php?_m=downloads&_a=viewdownload&downloaditemid=29
Posted on Aug 29, 2008
SOURCE: XP (SP2) not recognising Maxell USB Flash Drive 2.0
whan i fix my usb in computer and try to open it ,the message appear "please insert a disk into drive d".
what is it? how could be solved this problem? help me
Posted on Nov 21, 2008
zzptichka
  • 95 Answers
SOURCE: My external hard drive is unreadable
Does you drive make any sounds like these? If yes you have a mechanical problem and you should get a specialist to work on it. If not - try to remove the drive from USB casing and connect it directly to your PC or put into another USB enclosure. This should help if the problem is with the enclosure itself and not with the drive.
Posted on Dec 30, 2008
What is the model number (and Windows 7 driver) for Acomdata external hard drive serial number AC07111300220
  • 1Connect the Acomdata external hard drive to your computer through the USB cable that came with the drive.
  • 2 Click the "Start" button on your computer screen and then click on the "Control Panel" tab.
  • Sponsored Links
  • 3 Click on the "System" button and then click on the "Automatic Updates" tab if you are running the classic view. If you are running the standard view, click on the "Performance and Maintenance" button and then click on the "System" tab.
  • Read more: http://www.ehow.com/how_6880582_troubleshoot-acomdata-external-hard-drive.html#ixzz345dOHa31
    got it by just searching and a whole buch of solution came
    May 05, 2014 | Acomdata Computers & Internet
    HD not showing up on my Computer is there a driver for it?
    sounds simple but have you tried moving the USB cable to a different port? sometimes that fools the PC in thinking its a different drive & it reloads the USB driver.
    Jun 12, 2013 | Acomdata (HD080U2FE-72) 80 GB Hard Drive
    External Hard Drive won't respond
    ok 1. you need to be sure that you can`t have acces anymore by usb to the external HD... try in another machine example a other laptop.. or you need to open the HD and connect to other way with a new conector that sell in comusa or other computer store... pls click that my solution was usefull
    Dec 27, 2009 | Acomdata E5 HD320UHE5-72 320 GB USB 2.0...
    When I turn my acomdata 2.5 250 gb hd on it churns and beeps at me and my computer does not recognize it
    One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
    A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
    1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
    2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
    3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
    4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
    5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
    6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
    If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
    Any exclamation marks by hardware need fixing before you investigate any further
    USB flash drives can fail for no apparent reason.
    Sandisk Cruzers are especially bad for this.
    USB hard drives should be treated with extreme care.
    This is a real hard drive ! and knocks and bumps can quite literally kill them.
    It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
    You should also do this to cheack the drives connections are not bad inside the enclosure
    Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
    Known as "The Click Of Death"
    If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
    Oct 13, 2009 | Acomdata E5 (HD250FE572) 256 GB Hard Drive
    I have a Acom data hard drive Model HD500uhe5-72
    Here's what you need to do:
    1. Try connecting the HD (hard drive) into different USB ports of the computer.
    2. Try another computer to see if the HD would be detected.
    3. Try another USB cable.
    Do you hear a clicking sound on the HD itself while it's turned on? Check the Disk Management of your Vista computer to see if the HD would be detected under the Disk Management. Please follow the steps below:
    1. On your Desktop screen, right-click the "Computer" icon > select "Manage".
    2. Double-click on "Disk Management"
    3. Connect the HD while looking at the Disk Management. If the drive letter appear then, it's your Acomdata HD.
    4. Check the status if it's healthy or unallocated disk space. If it appeared to be unallocated, you need to reformat the HD to make it work again.
    To reformat it, just right-click on the drive letter that would appear and there's an option to reformat.
    NOTE: Formatting a HD would erase all the data saved in it.
    Have a great day!
    Sep 21, 2009 | Acomdata 500GB External Firewire HD 500 GB...
    I have a model HD320UHE5-72 external acomdata hard drive that when pluged into usb and power turned on is not reconized by computer. Vista It worked fine until yesterday.
    I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and OTHER devices (though not always)
    Sep 18, 2009 | Acomdata E5 HD320UHE5-72 320 GB USB 2.0...
    How to eject (exit) from nomad mobile desktop program/acomdata e5
    Have you tried changing your display size for you computers desktop?
    Try a higher resolution first, then if that doesn't work try a lower resolution.
    Most like the items are there and your display resolution is the problem.
    Jan 03, 2009 | Acomdata 500GB External Firewire HD 500 GB...
    Computers & Internet Logo
    37 people viewed this question
    David Payne
    David Payne
