Question about 2011 Toyota Camry - 2.4L 4-cyl. engine - Premium Wrench-Off Oil Filters
What size oil filter wrench for a 2011 toyota camry
Oil filter wrench
    Habit-Forming:
  • 179 Answers
New Toyota uses special wrench.you can buy in your auto store
Posted on Mar 23, 2014
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
It hasnt been a month since the oil was changed in my 2011 Toyota Camry and the maintance required was reset. Now the maintaince required has now came back on. What would the the problem since I know
Take it back to the oil change place. Or check the oil. If a seal is leaking or oil filter was not tightened or put on correctly oil may have leaked out and you will blow your engine!
Is is there any oil leaking in garage or driveway or where you park?
Jul 25, 2014 | 2011 Toyota Camry
Change cabin filter 2011 toyota camry
cabin AC Filter replacing video on Toyota V6
Nov 27, 2013 | 2011 Toyota Camry
How do I change the oil pump on a 2000 Camry, 2.2L??
For oil pump,oil pump pressure,oil warning light,oil low,oil ewplacing and other car engine oil problems,the help links are provided below.Click the link to go through the procedure :-----Oil light came on and the car died?http://schematicsdiagram.blogspot.in/2012/03/oil-light-came-on-and-car-died.html--------How to replace Oil filler cap or breather cap?http://repairhelpcenter.blogspot.in/2012/02/how-to-replace-oil-filler-cap-or.html---------Oil pouring out from left front of engine?http://schematicsdiagram.blogspot.com/2012/01/oil-pouring-out-from-left-front-of.html------Common Causes of Car Oil Leaks?http://schematicsdiagram.blogspot.com/2011/12/common-causes-of-car-oil-leaks.html--------Troubleshoot Car Oil leak?http://schematicsdiagram.blogspot.com/2011/12/troubleshoot-car-oil-leak.html--------Oil change details?http://repairhelpcenter.blogspot.com/2012/01/toyota-highlander-sport-oil-change.html---------Low oil pressure light?
http://howtobyme.blogspot.com/2011/11/low-oil-pressure-light-on-dodge-magnum.html
leaking oil from oil pan?
http://howtobyme.blogspot.com/2011/11/kia-sportage-leaking-oil-from-oil-pan.html ----------
Car Turns OFF due to low oil pressure warning light?
http://schematicsdiagram.blogspot.com/2011/12/car-turns-off-due-to-low-oil-pressure.html
leaking oil from timing cover?
http://technoanswers.blogspot.in/2012/02/toyota-corolla-leaking-oil-from-timing.html
For more oil and oil pump details check out the direct links below: ---
How to Replace Oil Pan on car?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-oil-pan-on-audi-a4-and.html
How to Replace an Oil Pan Gasket?
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-oil-pan-gasket.html
HOW TO REPLACE AN OIL PUMP
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-oil-pump.html
HOW TO CHANGE ENGINE OIL AND FILTER
http://schematicsdiagram.blogspot.com/2011/07/how-to-change-engine-oil-and-filter.html
HOW TO REPLACE AN OIL PRESSURE SWITCH (SENSOR)
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-oil-pressure-switch.html
How to Check Differential Oil Leaks and Replace Oil
http://schematicsdiagram.blogspot.com/2011/07/how-to-check-differential-oil-leaks-and.html
HOW TO PERFORM A BASIC ENGINE TUNE UP-OIL CHANGE
http://schematicsdiagram.blogspot.com/2011/08/how-to-perform-basic-engine-tune-up-oil.html
Oil pan Gasket on car?
http://howtobyme.blogspot.com/2011/11/oil-pan-gasket-on-1998-toyota-tercel.html
Oil pressure for car?
http://schematicsdiagram.blogspot.com/2011/12/oil-pressure-for-2001-gmc-jimmy-v6.html
How to replace Oil Pan on car?
http://schematicsdiagram.blogspot.com/2011/12/how-to-replace-oil-pan-on-2008-honda.html
How to replace Oil Pressure Sensor on car?
http://schematicsdiagram.blogspot.com/2011/12/how-to-replace-oil-pressure-sensor-on.html
How to replace Oil Pump on car?
http://howtobyme.blogspot.com/2011/12/how-to-replace-oil-pump-on-2008-honda.html
Car oil leak?
http://schematicsdiagram.blogspot.com/2011/12/car-oil-leak.html
Car oil leaks from valve cover gasket?
http://schematicsdiagram.blogspot.com/2011/12/car-oil-leaks-from-valve-cover-gasket.html
Oil light blinks on dashboard?
http://schematicsdiagram.blogspot.com/2011/12/oil-light-blinks-on-dashboard.html
Oil pressure issues on car?
http://repairhelpcenter.blogspot.com/2012/01/oil-pressure-issuers-on-toyota-tundra.html
Oil leaks from air filter on ford?
http://technoanswers.blogspot.com/2012/01/oil-leaks-from-air-filter-on-ford.html
Wire running from oil pan to alternator?
http://technoanswers.blogspot.in/2012/02/wire-running-from-oil-pan-to-alternator.html
Why car leaks oil from oil filter?
http://schematicsdiagram.blogspot.in/2012/02/toyota-camry-leaks-oil-from-oil-filter.html
Why engine is consuming lots of oil?
http://schematicsdiagram.blogspot.in/2012/02/2008-scion-xb-24l-engine-is-consuming.html
Maint REQD message on car dash?
http://schematicsdiagram.blogspot.in/2012/02/maint-reqd-message-on-2008-lexus-rx350.html
Remove Sump oil pan?
http://repairhelpcenter.blogspot.in/2012/03/remove-volkswagen-sump-oil-pan.html
Sump not coming OFF?
http://repairhelpcenter.blogspot.in/2012/03/sump-not-coming-off.html
How to remove the sump on car?http://repairhelpcenter.blogspot.in/2012/03/how-to-remove-sump-on-vw-beetle.html----------Car oil sump removal diagram?
http://repairhelpcenter.blogspot.in/2012/03/volkswagen-beetle-oil-sump-removal.html
This will help.
Thanks.
Feb 05, 2012 | 2000 Toyota Camry
I have a 2010 toyota camry 4 cyl. I am trying to remove the oil filter and it will not budge is it the standard righty tighty lefty loose?
Yes, turn left & do you not have the proper
oil filter cup, along with a ratchet & extension
for leverage?
Some filters you can use a band wrench
Aug 05, 2011 | 2009 Toyota Camry
What size socket to remove oil filter cannister from a 2009 Toyota Highlander?
K-D Tools 3253 End Cap Oil Filter Wrench This is a comment for this filter wrench I found on amazon.com here is the link-----The following is not my comment, but hopefully it'll help you.
http://www.amazon.com/K-D-Tools-3253-Filter-Wrench/dp/B0002SR4AY/ref=cm_cr_pr_product_top
I bought this tool to remove the filter housing on my 2009 Toyota Highlander 4-cyl. The filter housing seems to be made out of some composite material and I did not want to grab it with the pliers-type oil filter wrench. K-D Tools 3253 end cap wrench fit the housing perfectly and made the removal and the installation of the filter housing easy.
May 22, 2011 | 2009 Toyota Highlander
Location of oil filter
on the camry with the 2.4L inline 4, the oil filter is located just behind the plastic shield which extends below the front of the car... it will be on the passenger side, and is best removed with the variety of oil filter wrench which attaches to a ratchet (custom fit super graphite from shcuck's is the best I've found). I DO NOT recommend you use a strap type, or serrated jaw type wrench on this car, or you WILL have to remove the plastic shield, and waste a lot of time in the process.
On a camry equipped with the 3.0L V6, the oil filter is on the driver's side of the engine - mounted sideways. you SHOULD be able to get it through the driver's side wheel well. You WILL spill oil getting this one off - it's almost impossible not to, so be prepared for this. I'd personaly reccomend the type of wrench that attaches to a ratchet for this filter, but a strap or serated jaw type might work as well.
Hope this helps
Oct 20, 2009 | 2009 Toyota Camry
Oil filter, how to remove it
If the oil was properly changed the last time it shouldnt take anything more than just a FRIM counter clockwise turn, If that doesn't work then you will need a Strap Wrench, or an oil filter wrench. shouldn't be anything more than 1/4 to1/2 turn past snug.
May 07, 2009 | 2002 Toyota Camry
How do you get to the oil filter in a 2005 Toyota Camry?
they make a wrench that goes on the back of the filter and a 3/8 rachet to it you can get one at any auto part store
Dec 09, 2008 | 2006 Toyota Camry
How to I replace the oil filter on a 2009 Toyota Camry V6 engine?
Under the engine in the front you will see an aluminum cover.There is a square hole that fits a 3/8 ratchet remove this first.The new filter comes with a drain adapter that snaps in the hole under the cover.This lets the oil in the housing drain.Then take a oil filter cup wrench or a big channel lock to twist of the larger portion.Then change the filter and o-ring and reinstall.Make sure the o-ring on the square drive cover is there also
Nov 30, 2008 | 2004 Toyota Camry
2011 Toyota Camry - 2.4L 4-cyl. engine - Premium Wrench-Off Oil Filters Logo
Top K&N Products Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a K&N Products Vehicle Part and Accessory Expert? Answer questions, earn points and help others
