Question about Tecumseh Garden
Yardworks snow blower
I have a Yardworks 30 " snowblower with a 10.5 hp Tecumseh engine. It is about 5 yrs old and has always leaked oil after use, since it was new. Also the electric starter just spins and will not catch. Thanks for your help
  • Rob Cameron
    Rob Cameron Mar 24, 2014
    thank you for the infomation.
  • 1,162 Answers
Leaks are normally from bad seals or ones put on engine wrong. Many snow blowers leak oil, very common. Electric start needs to be taken apart. Rust is problem most likely. When you engage the starter it kicks out the gear to turn over engine. Carefully remove the starter from engine, try to start starter an if the pinion gear does not kick out from starter disassembly it an try to clean rust away from action. Dont break wires around electric motor careful about getting dirt an rust in winding. Try to lube spring an moving parts around gear. One other thing it could be a sheared off gear on starter also.
Posted on Mar 24, 2014
Testimonial: "thank you for the information"
2 Suggested Answers
  • 13 Answers
SOURCE: I have a yardworks snowblower
It is very possible that improper storage has left residue in your fuel system causing restriction of fuel supply. answer these questions and get a better answer. 1. Do you have to use partial choke or have to continually prime your engine to keep it running. 2. Look for physical damage to shutdown switch button or key switch wire. If this wire comes in contact with any metal surface other than its intended contact, usually near the engine. 3. Finally use an additive in your fuel system that attacks varnish such as carb and choke cleaner. In many severe cases your fuel system may need to be serviced by a professional familiar with the teardown and inspection of the fuel system. Good start though by changing your plug and fuel line antifreeze. As far as fuel stabilizers go I have been told but am still a novice when it comes to fuels that contain ethanol as I have heard that they may not have a very long shelf life. A few tips from an old ag. tech. Gods Speed to you! P.S. If this is a 2 cycle engine their are other things to consider.
Posted on Mar 01, 2011
My snowblower pull cord is siezed
Are you sure the engine isn't seized up?
Dec 28, 2016 | Garden
Can I use 0w 20 Mobil 1 oil in my snow blower
It can be used, although the manufacturer recommends;
Super S 5W-30 Snow Thrower Engine Oil - Sears
www.sears.com/explorer-5w...snow-thrower...oil/p-07188298000P
Sears Rating: 4.5 - ‎5 votes
Oct 21, 2010 - Explorer 5W-30 snow thrower engine oil is a premium formulation for use in all four cycle engines when temperatures are below 32 deg. F. Explorer 5W-30 snow thrower engine oil protects the engine by lubrication, cooling, cleaning and sealing internal moving parts.
Aug 23, 2015 | Craftsman Snow Blower / Snowblower Bottom...
I just bought a brand new yardworks snowblower 357 cc works great but it dosent seem to throw the snow very far for such a big motor any suggestions?
it would depend on the kind of snow you are blowing
check for proper tension on the belt
you can add rubber to the blower paddles to take up space on the outside of housing check youtube
Feb 11, 2015 | Garden
Yardworks snowblower problem engine no starting
check out the interlock switch system, check battery with a load meter first to make sure battery is up to snuff
Nov 24, 2013 | Tecumseh Snowblower Snow Blower Starter...
My yardworks snowblower engine not running
need more information, several reasons why an engine won't run
We have a yardworks snowblower and when not using the wheels always lock up. how do you unlock them without turning on snowblower.
Had the same issue and found out that the wheels lock when the motor isn't running and the accelerator handle is engaged. I still had both handles tied down from transporting home and it rolled fine after they were untied. Hope that helps
Oct 21, 2012 | Tecumseh 5hp Engine Snow King Mtd Blowers...
I need a manual
Try Home Depot. They carry a wide range of snowblowers with tecumseh engines.
Jan 09, 2012 | Tecumseh Snowblower Snow Blower Starter...
Garden Logo
300 people viewed this question
Top Tecumseh Garden Experts
Mike Squire
lnbn1975
itsman
Are you a Tecumseh Garden Expert? Answer questions, earn points and help others
