Question about Maytag Dryers
Dq 120 dn
Maytag mini dryer, Model DE 50, works of 120 volts,smoke comes out of motor. Is there a replacement available?
  • Victor Carrasco May 21, 2014
    Hi Lester Muramoto, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
    Have you checked that the power cable wiring is installed correctly?
  • Lester Muramoto
    Lester Muramoto May 21, 2014
    the power cable was working properly for 50 years. The motor that drives the drum and the blower started to smoke. So I figured the best thing to do was to replace the motor, but no one seems to carry a replacement motor. Lester (I've had the dryer for 50 years now.)
  • 171 Answers
Check appliance dealers who sells used parts
Posted on May 22, 2014
dragonsthatk
  • 547 Answers
SOURCE: MAYTAG DRYER DE-306 REPLACING HEATER ELEMENT
the elament is in center of drum take off back of drum
Posted on Feb 18, 2009
SOURCE: maytag model MDE7057AYW 5600 Watts dryer runs ,but
Most electric dryers run on 110 volts, but heat on 220 volts. Unit needs to be wired to 208 to 240 volt, 30 amp circuit to Run and HEAT properly. Motor, interior light and controls run on 110 volts, neutral (white wire) and one hot wire, usually black. The heater works on both 110 volt hot wires, usually one red and one black wire. Unit can be hooked up to run and heat on 110 volts but will allways take two or three times as long as a 220 volt setup. It is producing half or a little less of its 5600 watt rating. It takes three things to efficiently dry clothes: heat, air flow and tumbling action. Remove any one and the unit runs much less efficiently. If you need a dryer to run on 120 volts, buy one that says 110 - 120 volt operation only, but it will still take up to two hours or so to dry a load. Brent
Posted on Mar 12, 2009
jumptrout51
  • 3361 Answers
SOURCE: Whirlpool Dryer not heating
The motor has to be running for voltage to exit the motor going to the heater. With the back off the dryer and the motor running you should read 220 volts at the heater if all safetys and thermostats are good.
There is a thermal cut out relay on the heat canister. It must read continuity also.
Remember you must remove at least one wire from each component being tested to get a true open or closed reading. If a wire is left connected you get a false reading.
The heating element could be broken and part of the heater wire touching the canister. This would cause a continuity reading and still no heat.
Finally, yes,the centrifugal switch in the motor could be bad and not sending power to the heater on the red wire.
Posted on Oct 18, 2009
Testimonial: "I did determine it to be the cetrepetal switch..specifically the slide for the weights was heavily gummed up with dryer belt dust. It works now."
hunter19_46m
  • 7482 Answers
SOURCE: I have a Kenmore Elite electric dryer that we
Sounds like you need to replace your electrical breaker in the main control box of the house that feeds the dryer. You should get 120volt on each leg coming into the dryer. Good Luck, I hope this helps Please rate me, Thanks
Posted on Dec 27, 2009
SOURCE: Maytag Gas dryer not heating, Model #MDG8600AWW
Called Maytage directly, information is free. Thanks anyway
Posted on Jan 16, 2010
Model de50, mini, operates with a 120 plug. Motor smokes
You need a new motor but unfortunely it is no longer avalable.
Mar 22, 2014 | Maytag Dryers
Maytag dryer Model MDG 6400AWW not heating
A good place to start would be to check the igniter. If you are confident in your safety, check for 120 volts at the igniter when the dryer is calling for heat. If there is 120 volts but the ignitor is not heating, the ignitor is probably bad. If there is not 120 volts, the problem is probably in the timer or control circuit.
Oct 23, 2013 | Maytag Dryers
The voltage in my country is 230volts 50HZ I have a 120/240 volts maytag dryer what can i do to get it working
Normally the 240 volts rating is nominal and the device will run at 230 volts. The question is will the dryer run at 50 HZ? Check on the electrical rating tag on the machine. It may work. The motor may just spin at 50/60, 5/6 of the 60 HZ speed.
Gary
Aug 31, 2011 | Maytag Neptune MDE5500AY Electric Dryer
What part number is the drum belt for a maytag electric dryer model # DE 50 Serio no. 997874 KF?
part number and demensions Dryer drum belt - Length is 87-3/4" Width is 1/4".
Part Number: AP3865318 made by FRIGIDAIRE does not come up as maytag.
Oct 09, 2009 | Dryers
Replaced timer module. Dryer did not run.
Check the voltage across the timer motor, make sure that you have 120 volts. If you have 120 across the timer motor, then it is bad. Also check your wiring to make sure you have wires in right place
May 01, 2009 | Maytag Atlantis MDG8400AW Gas Dryer
Maytag model MDE7057AYW 5600 Watts dryer runs ,but
5600 watts will not operate off 120 volts.
This is a 220/240 volt hookup.
There are 2 legs of 120 volts each that operate the dryer.
The only part requiring 220v is the heater.
Otherwise 120v routes through the various controls and relays.
Mar 12, 2009 | Maytag Dryers
Maytag dryer model HYE3657AYW
I assume that your u.s. dryer is the standard 220 volt, and your question is what is the voltage in Mexico where your father resides. Most places in Mexico will have the 220 volt supply available. This should be easily found out with any cheap 15.00 meter. If the receptacle accepts the dryers plug, it is more than likely the proper voltage.
( Maybe your father is really wanting to save energy and realizes that his clothes will last forever when they are hung up to dry! )
Mar 04, 2009 | Maytag Neptune MCE8000AY Electric Dryer
Power conversion
If you have 110 - 120 volts AC at 60Hz, then the mixer must be bad. Unless 50 Watts isn't enough. Does the voltage drop when you plug in the Mixer to the convertor?
Geno
Mar 05, 2008 | Denon Dn-X1500 Professional DJ Mixer...
Dryers Logo
37 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
