Question about Maytag Freezers
Maytag upright freezer mqf1656tew00 not cold enough
Thermostat clicks at 2 which I think is when it is shutting off and then clicks at near the max setting. Cannot hear a fan running inside. Can hear the compressor running. Ice flow coming from the bottom of the panel covering the evaporator and pooled up frozen (barely) in the bottom of the freezer. Getting a temperature now but things inside are soft frozen.
2 Suggested Answers
icansurf
  • 72 Answers
SOURCE: Hotpoint FZA50 Freezer not cold enough
try it on max setting. lint clogging up stuff in the back? needs defrosting? low on refrigerant (freon)? call repairman for that last one
Posted on Jul 11, 2007
My Woods upright freezer MU07W running great for 9 years. Will it continue to run if I decide to place it outside on the balcony where temperature goes down to 20 below F or to max of 90 F plus?
Not the best idea. We had one in our garage where it got cold but not that awful cold. Not a good idea unless you want to take a chance.If the unit shuts down for a long time because of the cold the system could freeze or seize up.
Feb 05, 2017 | Woods Upright Freezer MU07W
Upright Freezer not cold enough
Honestly it sounds as if you have a sealed system issue, most likely low on freon.
Jun 13, 2012 | Freezers
Freezer & fridge not cold enough
Please check the Thermostat switch settings. Try to put it to max cool and then see the results. If it still does not cool the you have to check the refrigent. It is lee and leaking somewhere. Get a technician and get it charged up.
May 18, 2011 | Freezers
Maytag upright freezer (MQU1556AEW L1)top shelf
my maytag freezer not wotking correctly, the top shelf not cold, I bought a meat and tryed to put it on the top shelf, unfortunately, my meat went to the garbage and just the botttom shelf takes time to freeze, better than the top shelf
any help ?
Jan 02, 2010 | Maytag 15 cu. ft. / 425 liter Upright...
My Whirlpool upright freezer keeps building up ice inside the bottom back wall. The fan starts rattling and freezer will not stay cold enough to make ice. If I take everything all out and leave it off...
Either your defrost timer, defrost heater or defrost thermostat has failed. All parts are located behind the lower back panel inside the freezer. Most likely are the defrost heater and defrost thermostat.
Jun 09, 2009 | Whirlpool 20 cu. ft. / 566 liter Upright...
Freezer not cold enough/ice maker not working
Check the coils in the freezer to see if they are blocked with ice.
May 01, 2009 | Frigidaire 11.6 cu. ft. / 328 liter...
Kenmore upright older freezer coils frost up
the tech was telling you to put it in defrost and if ater the time you didn't hear the click the defrost timer is defective but like you are describing the defrost thermostat (bimetal) could be bad. here's a simple test (if your handy with a screwdriver) just dissasemble the panel and you will see the coil and defrost heater. if your handy with a voltmeter (please disconnect power first!) locate the two wires to the defrost element put the meter in "audible" mode and check for continuity on the defrost heater if you hear a beep it's good if it dosen't beep it's bad just replace heater w/ bimetal and your ready 2 go! email me @ hvac.tech7872pr@gmail if you have any questions
Jun 09, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezer dying
IS THE FREEZER AN AUTO DEFROST FREEZER? IF SO, IS THERE FROST BUILT UP ON THE BACK WALL? IF FROST APPEARS ON THE BACK WALL, THERE IS A DEFROST FAILURE. THERE ARE THREE ITEMS IN THE DEFROST CIRCUIT. THE TIMER, HEATER, AND BI-METAL.
THE TIMER IS USUALLY LOCATED ON THE BACK OF THE FREEZER DOWN NEAR THE COMPRESSOR IN THE CORNER. IT HAS FOUR WIRES ATTACHED TO IT. YOU CAN ADVANCE THE TIMER BY TURNING THE KNOB ON THE FACE OF THE TIMER. WHEN IT CLICKS LOUD AND STOPS THE COMPRESSOR RUNNING, IT IS IN THE DEFROST CYCLE. WAIT 5 MNUTES AND CHECK INSIDE THE FREEZER
TO SEE IF THE HEATER COMES ON. YOU MAY BE ABLE TO HEAR THE FROST MELTING AND DROPPING ON THE HEATER. IT WILL SIZZLE AND POP. ALSO, LOOK FOR A GLOWING DOWN AT THE BOTTOM OF THE BACK PANEL.
IF THE HEATER IS ON, THE TIMER IS BAD. IF NOT, CHECK THE HEATER AND BI-METAL.
IF THE COMPRESSOR IS NOT RUNNING, CHECK THE COLD CONTROL TO SEE IF IT IS GOOD. IF THE COLD CONTROL IS O.K., THE START DEVICE ON THE COMPRESSOR MAY BE BAD. DOES THE COMPRESSOR HUM FOR A MINUTE AND THEN CLICK AND SHUT OFF. IT CAN BE EITHER THE START DEVICE (RELAY) OR THE COMPRESSOR IS BAD.
Apr 02, 2008 | Frigidaire 14.1 cu. ft. Upright Freezer...
Jul 10, 2007 | Hotpoint 4.87 cu. ft. / 138 liter Upright...
Open Questions:
Freezers Logo
87 people viewed this question
Top Maytag Freezers Experts
John Tripp
John Tripp
christian nielsen
Ismael Rodriguez...
Are you a Maytag Freezer Expert? Answer questions, earn points and help others
