Question about Air Tools & Compressors
Master elite 1 hp hush series
I need to know how to lower the PSI.
    Champion:
  • 205 Answers
Im assuming you want lower air line pressure,the best thing for you is to get a air pressure regulator and install it between the compressor outlet and you air line which has a knob to regulate air line pressure
Posted on Mar 23, 2014
How to open case of HP 8300 Elite Desktop Computer to add RAM
http://h20566.www2.hp.com/portal/site/hpsc/template.PAGE/public/psi/mostViewedDisplay/?sp4ts.oid=5232852&spf_p.tpst=psiContentDisplay&spf_p.prp_psiContentDisplay=wsrp-navigationalState%3DdocId%253Demr_na-c03650192-4%257CdocLocale%253Den_US&javax.portlet.begCacheTok=com.vignette.cachetoken&javax.portlet.endCacheTok=com.vignette.cachetoken
Sep 09, 2014 | HP Business Desktop Elite 8300 C6Y68UT...
Why would my 1 hp pump only maintain 45 psi running 1 garden hose?
Without knowing all your variables with well it is hard to say. Bladder tank needs to have 30 psi with no water pressure. It is possible that the screen down the well is restricted and you are only getting that much water. Or you may have clogged impeller in pump.
Sep 04, 2014 | Utilitech 1-HP Cast Iron Shallow Well Jet...
Sears 2550 psi power washer does not have any water flow with the motor running, but has a low flow from the wand when the motor is off.
If this unit has set for that long has you have rust inthe end of the nozzle. take it of or undo the wane and soak it in CLR this will take the rust out. GOOD LUCK....
May 19, 2014 | Briggs Stratton 020273 Elite Series...
How many hvac blend door actuators are there in a 2002 chevy silver ado and where are they located. I tried to purchase the part and it gave me an option for upper and bottom actuators. I need to know...
I'm having the same problem with my 00 GMC Sierra. If you do NOT have dual zone climate control, it's just to the passenger side of the transmission hump under the hush panel underneath the dash. 3 screws take off the hush panel, two take off the actuator. One screw on the hush panel is a pain in the **** to get out. I'm still trying to figure out if the "upper" or "lower" is the proper fit for it. If you have dual zone, then one is under the passenger side, and the other is under the driver side. Hope this helps!
Sep 16, 2010 | 2002 Chevrolet Silverado 1500
Need to know where oil drain plug is on 6.75 hp Briggs & Stratton engine on 2550 psi troy bilt pressure washer!!
I have the same model...... it should be just underneath the unit.... it will look like a square head recessed. I used the ratchet set extension and it fit just right. I literally had to tilt the darn thing upside down to find it. Then once it was loosen a bit, I put the machine upright on the wheels again, and slip a plastic pan underneath as I finished unscrewing the oil plug, Out came the black goo.
Aug 07, 2010 | Briggs Stratton 020273 Elite Series...
I have 5.5hp briggs&stratton pressure washer Simoniz S2350. Would you know the PSI for this item?
Every 5.5 HP pressure washer runs between 2,200 and 2,500 PSI with most set by the manufacturer at 2,400 PSI with 3,600 RPM of engine speed.
Due to the power required to produce more than 2,500 PSI a 5.5 HP engine would lose engine speed as it can not produce enough power for the higher PSI output. It is a matter of hydraulics vs input power.
Any gas pressure washer will produce lower pressure with lower engine RPM. Looking at S2350 as your model number yours may be set to 2,350 PSI by Simoniz.
Thanks for using FixYa.
Kelly
May 16, 2010 | Garden
Accurate pressure for 2 hp ag hayward pool pump
the psi range is normal and will fluctuate with the cleaniness of the filter. Depending on wether or not you have a Sand filter or an Earth Filter, you should periodically backwash(for sand) and "bump" for the earth filters. You will notice that the psi will lower back down to the lower psi range. This indicates that your water is flowing freely with little resistance.
Jun 12, 2009 | Waterway Supreme Hi Flo Pump Dual Speed 2...
Xbox games
Try This Hacked Firmware for the 360
What you need
- A PC
- Xbins Downloader 2008 (HQ Downloads)
- Winzip
Let's Get Started
1. Ok first download and install "auto_xbins_2008.zip" which I have uploaded it here on HQ for your convenience.
2. Unzip the auto_xbins_2008.zip file to your computer and start the program.
3. When you start the Xbins Downloader 2008 program, it logs you on the IRC server and takes you to the correct location all by itself.
4. When logged in you will see 2 folders in the right hand window, one (1) for Xbox(original) and one (1) for the Xbox 360.
5. Go to the 360 folder, from there you will see all the sub folders listing all the other types of files including firmware. Yes the latest ixtreme is in there.
Warning (DO NOT BE GREEDY OF YOU WILL GET BANNED) get 1 file at a time, and if you get warned leave and come back after 24 hours and go again. (Speeking from experience here).
Just drag the file from the right to the left window.
This tut is for all those that think this info is out of your reach IT IS NOT and for those who want to keep these files and locations Hush, Hush and make money from free info, and for those who hate torrents as I do.
For help on installing the files go to the HQ VIP forums here and yes become a VIP Member it helps to keep this community alive and helps pay for the site fees. (They are not free)
360-HQ Forums: here
Nov 20, 2008 | Microsoft Xbox 360 Elite Console
Air Tools & Compressors Logo
98 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
