Question about Siemens Dishwashers
Siemens dishwasher won't heat properly, runs for 7 hours
Hi, Our SE36A290SK dishwasher has recently got a problem where it runs for many hours before finishing. At first I thought it was the infamous "Runs forever, showing 1 minute" error caused by a defective relay on the controller board, but it does actually finish the cycle after about 7 hours. The timer starts at 199 minutes, slowly counts down to say 60 minutes, then goes up again to perhaps 130 minutes and so on. Finally it counts down to 1 minute and stays there for a long time while the machine is still rinsing. Normally it would be at the end of the drying cycle now. At last it finishes, though. It also does heat, albeit not very much, but eventually the water gets more or less hot but it takes a very, very long time. While running it never seems to consume more than about 150W which explains why it takes so long to heat the water. I have checked the relays with a multimeter, they work fine. Also the solderings look fine and there are no other signs of problems on the board. What should I do next to locate the problem? I am familiar with fixing stuff, having electronics as my hobby. Thanks in advance, Martin
  • 1 more comment
  • Martin Larsen
    Martin Larsen Mar 24, 2014
    Can I somehow bypass the control board and manually turn the heater on to test it?
  • Martin Larsen
    Martin Larsen Apr 13, 2014
    I have measured the power consumption from the heater with a clamp meter. It's only around 1A, what does that say?
  • Martin Larsen
    Also, I replaced the relays with no luck. Please give some advice. Thanks!
techman
  • 3130 Answers
SOURCE: Electronic controls don't count down properly
Your problem is the electronic control board and unfortant that you cant repair or even get parts for it . Only if you get the whole control board will you fix your problem assy unless you find a good appliance man that repairs electronic control boards
Posted on Apr 14, 2006
jsrock516
  • 5911 Answers
SOURCE: Dishwasher wont finish cycle
I have experienced this problem before and it turned out to be the main control board in the console. Not a cheap fix, either. The control boards are not serviceable, and can run over $100. Sorry, I hope I was of some help.
Posted on Jul 10, 2007
  • 213 Answers
you have to replaced the main control resoldering wont fix it because the relay itself has gone bad replacing the board will solve the problem
Posted on Nov 20, 2007
futureloginn
  • 734 Answers
SOURCE: Dishwasher runs for a long time
If your dishwasher's cycle times are too long, check these:
Water pre-heating
Cycle not completing
Water pre-heating Yourdishwasher may pre-heat the water. If so, and if the water entering thedishwasher is cool, the heater may take up to half an hour to heat thewater.
To avoid the wait, increase the incoming watertemperature before turning on the dishwasher. Do that by running thekitchen sink faucet until the water runs hot. Or increase thetemperature of the hot water to the entire house at the hot waterheater.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Posted on Dec 12, 2008
SOURCE: Bosch SHU5300
If your heat cycle is not coming on, which it sounds like it is not, then you may have a problem with the heating system. There is a well known issue with many of the Bosch dishwashers that use the (266746) control module. Basically, there is a relay (which is a kind of electro-mechanical switch) that is used to turn on the built-in heater. There is a solder joint on the main Printer Circuit Board (PCB) that allow electricity to flow to the heater, that joint often will melt away and burn the surrounding area of the PCB. This is most likely a design flaw and appears to occur at about the 4-5 year mark. One way you can test for this is to run the onboard diagnostics routine that is programmed into the firmware of the micro-controller (brain) of the dishwasher. The way to do so it to press and hold the (Scrub Wash & Delicate/Econo) buttons at he same time and then press the on/off power switch to the on position. The LED lights above both those buttons should begin to flash, when they do, press them both again and the diagnostics program will start. It is a multi-phase program that will run for quite a while. Once it finishes, if it is a heating problem, it will end with a number 2 code in the display. If this is so, then it very well maybe the solder-joint issue on the control module and it will need to be replaced. It runs $128.10 US directly from www.bosch-appliances.com. Good luck.
Posted on Jun 30, 2009
Siemans sl33a dishwasher won't drain, interior is scummy
My Siemens runs constantly, for hours, and doesn't drain all the water from the bottom. Is this also a "clogged drain" issue or is there something else wrong?
Jan 01, 2013 | Siemens Dishwashers
My Whirlpool dishwasher washes but does not rinse or dry
Most likely the control panel is defective. Go to the repairclinic.com for further diagnostic help and parts.
Apr 25, 2017 | Dishwashers
I used my frigidaire self cleaning setting for the first time. It cleaned the oven well, but now the oven will not heat up properly.
useing a flashlight look over the elements top and bottom you are looking for a type of damage like bubbles or brakage , get back to me Frank
Dec 15, 2011 | Frigidaire Professional Series 24 in....
Hi, My Siemens is an older model and seems not to be rinsing off the dishes enough. They are drying with a film on them. Thanks so much . Launa
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Apr 09, 2011 | Siemens Dishwashers
My siemens dishwasher bottom arm does not spin to clean the bottom basket of dishes. Everytthing else works fine. I have removed and cleaned out all washing arms and plastic water carrier inside...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Feb 23, 2011 | Siemens 24 in. SE64A630GB Built-In...
Hello. Our siemens built-in dishwasher is not cleaning properly in the upper tray. While there is some element of cleaning there remains a residue in the upper tray only.
Dishwasher
How to Buy
heatman101
Dec 17, 2010 | Siemens 24 in. SE55A560 Built-in...
The SE24M262EU dishwasher is not cleaning properly. It is leaving some dull stains on the utensils. the product is just 3-months old
heatman101
Oct 27, 2010 | Siemens 24 in. SE25A836GB Hi-Line...
Why does my siemens dishwasher take 4 hours to finish running
Should only take 120 minutes to run a complete cycle. Your drain pump might not be expelling all the water.
Jul 18, 2010 | Siemens 24 in. SL34A006UC Built-in...
Siemens dishwasher does not wsh the dishes
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
Dishwasher Problems The Heating Element not Working
heatman101
eqrte
Jun 16, 2009 | Siemens 24 in. SL84A305UC Built-in...
Electronics problem with Maytag Dishwasher
the outlet pump may have become clogged, try removing and cleaning it.
Mar 26, 2008 | Maytag 24 in. MDB9150A Built-in Dishwasher
Dishwashers Logo
143 people viewed this question
Top Siemens Dishwashers Experts
Paul Bade
shaun taylor
Mike
Are you a Siemens Dishwasher Expert? Answer questions, earn points and help others
