Question about Definitive BP7006 Main / Stereo Speaker
Loud, constant static
I've started getting a loud static from a Definitive BP7006 speaker, even if it not connected to the receiver. Is this repairable?
    Genius:
  • Definitive Master
  • 1,054 Answers
Need to have the amp assembly replaced
Posted on Mar 24, 2014
Loud speaker static when the car is off. It drained that battery. I tried pulling the radio fuse but it was still making the noise. I had to disconnect the battery to get it to stop. Any ideas?
I GUESS that the speakers are driven by an after market amplifier. An amplifier needs to be connected to a power source that is only on when the radio is on, through a relay.
So I GUESS that:
  1. The wiring is incorrect. Or
  2. If is has a relay, the relay is stuck.
Feb 01, 2015 | Cars & Trucks
Alot of static or interference through speakers
Check all leads are plugged in the right spots and are in good condition. Sometimes "static" is caused by plugs not connecting properly.
Nov 29, 2013 | Altec Lansing Audio Players & Recorders
Loud static noise coming front right speaker on home theater system. I've removed all cables and all speaker wires except that one and still get the noise. I've tried plugging the unit into another...
Make certain you have not started some kind of test signal going by looking in the the user manual, if not by all means send it back. Phone or E-Mail the makers helpline first they should sort any problems and confirm you have set it up right.
Jul 04, 2011 | Audio Players & Recorders
There is persistent low volume humming sound coming through all the speakers when the reciever is on, it is just loud enough to interfere with the audio I'm trying to listen too (especially dialog on the...
You could have done a very slow damage to the Yamaha if your UPS was not a pure sine wave type ( on line UPS ). Most of the UPS we get are called Off line type and are far cheaper than the On line pure sine wave type. The out put of the Off line type UPS is not a sine wave ( the natural waveform of AC voltage ) and strains the Power supply circuit of any device connected to it.
Now if the humming sound is the same irrespective of the volume position, it is a power supply problem. You might be having a leaky rectifier diode or capacitor. First change the diodes and see if its ok then change the main filter capacitors too.
Apr 28, 2011 | Yamaha RX-V663 Receiver
The sub on the left speaker don t play and the light went off but the mid and tweeter have sound coming out
The amplifier that drives the built in subwoofer has stopped working. The first thing to do is check that the power cord is plugged in to a live power outlet. Next, replace the fuse which you'll find on the large black metal plate on the back of the speaker. Use only the size and type fuse specified. If that does not work contact Definitive customer service at (800) 228-7148.
Apr 02, 2011 | Definitive BP7006 Main / Stereo Speaker
Hi i am having problems with my lg home theatre system. The front right speaker will every now and then make a loud distortion noise like static and its annoying. I,ve tried new speaker wire, new contacts...
Hi.
First make sure all connections are firmly in place. Not only speakers, but any other inputs too.
swop the left and right channels over at the amplifier end. If the sound happens on the other speaker now, you have a faulty av receiver. If it's still on the same speaker, that speaker is "broken" and requires replacing.
Jan 14, 2011 | Audio Players & Recorders
When I plug in my speakers, they make a constant static sound. It can become quite loud at times and I've found that turning the input chord around can sometimes work, or unplugging the charger for my...
if your speakers are near to some electronic devices you'll get theses static noises try to keep them away from electronic devices which solves it very easily..
Sep 30, 2010 | Audio Players & Recorders
BellSouth 1010 walkie talkie receives constant static
you have opened up the squelch - refer to the manual to close and return radio to normal operation
Aug 27, 2009 | BellSouth Radio Communications
Alot of loud feedback through speakers, a loud buzzing noise
What sources make it happen or which do not? All buzzing = something in the amplifier end. is it from all speakers or just one?
One external source= RCA cables not grounded. Reconnect them tightly with a twisting motion to wipe off oxidation.
Apr 10, 2009 | Onkyo TX-SR606 Receiver
Pioneer VSX-D85OS very loud static through speakers.
Its over heating no cheap fix. But wait if u buy an eternal fan n place it on top or behind it will do the trick. Try blowing on top when static happens n sound comes back on.
Nov 07, 2008 | Pioneer VSX-D509S Receiver
Definitive BP7006 Main / Stereo Speaker Logo
148 people viewed this question
Top Definitive Audio Players & Recorders Experts
 Grubhead
Grubhead
Rob
Rob
Are you a Definitive Audio Player and Recorder Expert? Answer questions, earn points and help others
