Question about Neff W4380X1 Front Load Washer
Detergent & Conditioner Drawer
We have a Neff W4380X1 Front Loading Washing Machine with a slight problem. We have had the wahing machine approximately 3 years but this problem has only been aparant during the last 8 months.
The problem is that when the machine has finished the wash cycle water collects in the conditioner drawer and does not drain away. The drawer has to be removed prior to starting the next wash cycle before more conditioner can be added.
  • Anonymous Sep 20, 2008
    sometimes the fabric conditoner goes before last rinse
  • Anonymous Mar 17, 2014
    how can i get to unscrew the detergent solution pump without damaging it?
Perhaps it needs to be thoroughly cleaned out first - sometimes the gloopy mess collects and blocks the outlet hole.
Posted on Feb 10, 2008
Washing machine will not spin
its probly either ur bushes on the motor that have gone and need replacing or the programer has gone. if it was my washing machine i would change the bushes first as it dont cost that much to replace them.
Jan 27, 2013 | Neff W4380X1 Front Load Washer
Neff washing machine - barrel doesnt spin
I would recommend it. Otherwise they will have to run new wires from control module all the way down to the motor. I would get my money back since they didn't replace the right piece.
Jun 23, 2009 | Neff W4380X1 Front Load Washer
Neff washing machine not spinning
sounds like motor brushes have worn out will need to remove motor to replace they are inexpensive.the clicking is the relay telling motor to rotate clockwise or anticlockwise.
May 30, 2009 | Neff W4380X1 Front Load Washer
My nef washing machine fills with water but doesnt spin ive cleaned the filters this has not solved it
Hi there - past experience tells me your water pump is U/S try this before anything else
Apr 28, 2009 | Neff W4380X1 Front Load Washer
Needing to replace the brushes on a Neff W4380X1GB
not the motor but the program switch
the motor only gets instructions from that switch or program board and the motor is running well if it does the rest of the wash well
Dec 02, 2017 | Neff W4380X1 Front Load Washer
Neff W4380X1 LED 01 appearing
This is a water supply fault. Check that the hoses at the back of the machine are not squashed and check to see if there is water getting into the machine
Aug 31, 2008 | Neff W4380X1 Front Load Washer
Neff W4380 error or warning '03'
Hello there,
when the machine makes drowning sounds and beeps error dry (while trying to drin out) blow strongly into the drain pipe. It should result in a higher flow of water out the drain pipe and error 3 should go away.
Jun 02, 2008 | Neff W4380X1 Front Load Washer
Power cuts when 'on' switch is released!
Easy, remove the top the switch unclips and slides out from the front panel, you cannot sucesfully repair these switches so a replacement should be obtained
Dec 31, 2007 | Neff W4380X1 Front Load Washer
Neff W4380X1 Front Load Washer Logo
331 people viewed this question
Top Neff Washing Machines Experts
Gerry Harvey
Gerry Harvey
Billy Detlefsen
Are you a Neff Washing Machine Expert? Answer questions, earn points and help others
