Question about Samsung LN40A550 LCD TV
New samsung 40 inch LCD. When in the wide mode
New samsung 40 inch LCD. When in the wide mode people's heads are cut off and I can't see the writing on the bottom. The next size is too small (only covers the screen sometimes)
Cannot get help from Samsungca. Called twice. Both times they couldnt help.....
    New Friend:
  • 58 Answers
If you are watching cable or satelite, you need to change the screen format output from the source to make sure it matches with the TV
Posted on Jun 15, 2009
Adjust my 40 Samsung 1080p 120Hz LCD to see the entire picture. t is currently cutting off the edges; left, right, top and bottom
First check if your zoom is on..if it is switch back to normal setting. If picture is still cropped with no zoom then try go to the menu seen string and check for aspec ratio..try different sttings..
Feb 23, 2015 | Samsung UN40EH6000 40-Inch 1080p 120 Hz...
Just recently my sharp aquos lc 40 e is stuck in stretch of wide screen and the heads or top of things are being cut off. When i go to view mode it only gives me 4 options wide, stretch dot to dot or zoom...
Not all TV programs are broadcast in 1080. When you use zoom or stretch on a program in 720 or 480 and a 1080 program is viewed you have to go back and take off zoom and stretch to get a correct picture.
Aug 29, 2011 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Samsung lcd tv 40" model#ln40a450c1d.
try changing the aspect ratio to 16:9 if not it could be a burnout.
May 20, 2011 | Televison & Video
I have a 52 inch SONY Bravia that has been stuck in zoom mode since last night. iI am unable to see the writing and/or tops of heads on top of screen. any help available?
Press the "WIDE" button on the TV remote a few times to change the TV wide mode settings until you get it to "FULL". If that does not fix it, look on your Cable box remote for an "Aspect" or "Format" button and press it a few times. I hope this helps.
Apr 19, 2010 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Image does not position well
Your Sony TV remote has a "WIDE" button. Press this a few times in a row some that you understand it's operation. Then pick a mode (I would recommend "FULL") that fits your needs. I hope this helps.
Mar 23, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Image on 'normal' setting isn't using full height of tv screen.
What you will need to do is grab your remote that came with the tv - click "Menu">select "Settings">go down to "Screen" and make sure that:
1. Wide Mode reads "Full"
2. Auto Wide reads "On"
3. Display Area reads "Full Pixel"
Hope that helps.
Apr 06, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Samsung 52 Inch LCD 120hz. 3 inch wide vertical line on screen
This is a problem with the LCD panel. If the tv is out of warranty, I would call Samsung and see if they will pay for the panel and you pay for the labor. The panel is not cost effective to repair. If Samsung will not do anything you will need to buy a new tv.
Nov 16, 2008 | Televison & Video
Heads cut off and no score...
Try your setting on your cable box (Screen position)
also maybe wide mode try switching to wide zoom good luck
Dec 10, 2007 | LG 42LC2D 42 in. LCD HDTV
Samsung LN40A550 LCD TV Logo
153 people viewed this question
Henry  Thomas
Henry Thomas
