Question about LG Washing Machines
The agitator in our LG WF-T653A washing machine repeatedly separates from the base even though I tighten the bolt as much as possible. Suggestions to fix this issue would be appreciated
Machine is 11 years old and only started to play up say 4 weeks ago
4 Suggested Answers
SOURCE: Maytag Preforma washing machine
I would suggest Service Technician is cheaper than doing it yourself Bev007. It will save you headache too. Depending on the severity of the damage, you'll be working on the transmission attaching the shaft of the pulsator or agitator.
Posted on Dec 29, 2007
jyackle5
  • 8197 Answers
SOURCE: MANUAL FOR LG WASHING MACHINE,
You can get the manual on the link below. Just click on where it says it is free top right.
http://safemanuals.com/user-guide-instructions-owner-manual/LG/WF-T653A-_E
Good Luck and please rate 4 thumbs up for the free answer
Posted on Sep 06, 2010
  • 44045 Answers
SOURCE: after replacing the inlet valve assembly on a lg top loader washing machine, the machine now fills up with water and does not stop. How can this be fixed?
The fill level control is not working. May have gotten detached during the inlet valve replacement.
Posted on Oct 26, 2012
How to remove agitator from lg wf t753A
in the centre the is a plastic cap pop out with small flat bladed scewdriver, there is a screw or bolt under it remove that andtake out the agitator
Jan 21, 2018 | LG Washing Machines
How to remove the agitator in order to clean the bowl?
To remove agitators on these models, this fastening bolt must first be removed. To access the bolt, remove the cap at the top of the agitator - this can usually be done either by hand or by prying with a screwdriver. Take care if the cap is glued down
Jan 05, 2017 | Washing Machines
I have an LG model WF-T7015TP Turbodrum top-loader automatic washing machine. Having problem in that the drum does not agitate to and fro during the washing cucle. It's draining fine and even spin-drying...
check the agitator module unit and the start capacitor both in the back of the control panel One controls the agitation and the other starts the motor. If the start capacitor is failed simply replace it with a new one The agitator module will cost more . Have an appliance electrician check it out.
Aug 16, 2013 | LG WFT1071TP Top Load Washer
My LG Fuzzy Logic WF T653A machine deposits little black unknown deposits on my clothes after every 2nd or 3rd wash, they look like little bits of black wet paper ?? some-one said to change the lint bags,...
Its called scrud.
Solution is to use a couple of quantum dishwasher tablets on a hot empty heavy wash.
Doing this on advice from an LG rep. May need to repeat it 3 times.
Brendan
Mar 24, 2013 | Washing Machines
MANUAL FOR LG WASHING MACHINE, MODEL NUMBER WF-T653A
Sep 06, 2010 | Washing Machines
How to separate auger from agitator. whirlpool ultimate care II
When you look down into the agitator, are there 4 white plastic points that look slightly melted or otherwise deformed? If so, using a small flat head screw and a small hammer, separate the white plastic from the surrounding translucent plastic. Once you've done that, it should easily pull apart.
Jan 03, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Agitator (can't get to the dogs)
Not sure if you mean the agitator is stuck to the shaft or the agitator will not separate now that you have it out of the machine, if the agitator is stuck, you may be able to get it loose by rocking it back and forth while pulling up on the base or bottom of the agitator. If you have the agitator out already, then stand on the base and pull up sharply on the top section and it will separate.
Jan 09, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
32 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
