Question about Refrigerators
Water line to water dispenser broken
I have a side by side LG refrigerator with a water / ice dispenser in the freezer door. The water line for the water dispenser is broken so when the button is pressed to dispense water, water runs onto the floor. Ice maker is still working fine and water doesn't leak unless the button is pressed. How do you take the dispenser out of the door? I was able to take the trim ring with the electronics panel off and also the button actuator and plastic chute so that everything is open. It appears that the door was assembled around the dispenser assembly and that nothing is accessible without tearing into the door which can't be done because it is foamed together. How can I replace the water line to the dispenser?
  • Ralph Russell
    Ralph Russell Mar 22, 2014
    Update. Pulled the bottom panel off the front of the fridge. The line is broken where it makes the bend and goes into the bottom of the door. Is it possible to remove this line from inside the door and replace it? If so, how?
  • Ralph Russell
    Ralph Russell Mar 23, 2014
    Model number is GS73W64CEF
SOURCE: Ice and Water Dispenser not responding...
had the same problem, there was a component in the front user panel that was shot
Posted on Apr 23, 2008
SOURCE: ice/water dispenser control panel
@ Scootertramp
You tell us about this board or that board but never tell us where to located or get at these boards. Would you please clarify that?
My ice and water started dispensing sporadically, though the lights were working fine. After I removed the kick board at the bottom, cleaned out the little connector and put it back together, nothing on the door works. All else works fine.
Posted on Sep 08, 2008
larryyb
  • 291 Answers
SOURCE: BROKEN WATER SUPPLY LINE IN FREEZER DOOR
it should just snap off and on ,,,, something they are tuff to get loose
Posted on Nov 29, 2008
woodchuck789
  • 4070 Answers
SOURCE: RS25AWXEW01 side x side refrigerator has leak at
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
Posted on Aug 13, 2009
Testimonial: "THANKS, THAT SEEMS TO HAVE DONE IT! SHAAN"
woodchuck789
  • 4070 Answers
SOURCE: I just replaced ice maker
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don’t refill with water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Posted on Sep 02, 2009
Our LG fridge had an issue where the water supply was cut off, so the ice cube maker stopped working as well as the water dispenser in the front. The water valve was replaced, and the ice maker started...
it could be a frozen water tank inside freezer door. if so, door will need to be replaced; as, there was maybe a spot where the foam inside door wasn't sprayed properly. disconnect water line fitting under door behind kick plate; close door and try dispenser. this will verify if it's the door or not.
Sep 22, 2010 | LG LSC26905TT Side by Side Refrigerator
The ice maker isn't working. There is no water in the line.
I have a similar problem for my LSC27911ST. There is no water coming out from the dispenser, although ice maker seems to be working.
I didn't do anything other than keep trying water dispenser in hope that water can be drawn out from the inner pipes.
After opening the freezer door a number of times, tried dispense ice and then tried dispensing water a number of times, eventually water come out again.
Maybe the water line in the refrigerator was frozen. It is very hot today, and maybe the refrigerator over work too much.
Jun 13, 2010 | LG LRSC-26922 Side by Side Refrigerator
GE Side By Side Ice Machine & Water dispenser not getting water
you may have a pin hole in your water line to your dispenser or you could be leaking at the water valve itself on the water dispenser side. you'll have to pull the refrigerator out from the wall and look where the main water line goes into the back of the refrigerator. you will probably have to take the back off to see. be sure you put the back of the refrigerator back when you are through.
Jun 05, 2010 | GE Profile PSW26P Stainless Steel Side by...
How to resolve our "lack of water" issue..within the last few weeks, the water dispenser's water flow lessen with each day-now it does not just doesn't work
there may be a problem with the water lines or bottles in the fridge compartment is frozen raise the temp in the fridges to about 38 for a couple of days and this should unthaw the lines
Apr 13, 2010 | LG LFX25971ST Bottom Freezer French Door...
No water but ice is fine
turn freezer side to zero for 1 minute press water dispenser
Mar 29, 2009 | GE GSH25JSRSS Stainless Steel Side by Side...
Water dispenser not working but ice maker does
The water line freezes inside the freezer door. There is now an add-on water line heater you can install to thaw the line.
Mar 01, 2008 | GE 24.6 cu. ft. Side-By-Side Refrigerator...
2 possible problems.
#1 water valve for the water side is stuck in the closed position.  Only way to tell is to pull the bottom kick panel out and look for the water line disconnect.  Separate the line, close the door and try to draw water through the dispenser.  If the water comes out of the disconnected line, then the water valve is good.
#2  if water is coming out of disconnected line, then the problem is in the freezer door.  There is a heater that keeps the water line from freezing inside the freezer door.  It is not repairable!!  The freezer door has to be replaced.
Nov 21, 2007 | LG LRSPC2031 Side by Side Refrigerator
Refrigerators Logo
32 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
