Question about Canon PIXMA MG5320 All-in-One Printer
Black ink is not printing
Printer is not printing black items. The ink cartridges were changed and it still does not work. Colors come out, some black items come out.
  • Canon Master
  • 365 Answers
Deep clean the head a few times
Posted on Mar 23, 2014
Joed911
  • 4338 Answers
SOURCE: new cartridge won't print
  1. Make sure you removed the tape from the ink cartridge.
  2. Press the <Menu> button on the printers operation panel.
  3. Press the left [<] or right [>] arrow buttons to select [MAINTENANCE].
  4. Press the <Set> button.
  5. Press [<] or [>] to select the cleaning setting you want. Select [HEAD CLEANING] for normal print head cleaning. Select [HEAD REFRESHING] for deep print head cleaning.
    Note: [HEAD REFRESHING] uses more ink than [HEAD CLEANING], so perform [HEAD REFRESHING] only when necessary.
  6. Press <Set>.
  7. Print a Nozzle Check Pattern and perform at least two Head Refreshing if the pattern is not correct.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 26, 2008
Bogdy_3003
  • 17 Answers
SOURCE: Canon i9900 printer will not print group 2 colors.
Set your printer at maximum quality and dpi
Posted on Dec 27, 2008
  • 291 Answers
SOURCE: Changed ink cartrigde and printer no longer printing.
microsoft logo is in colour and so its printing while everything else on test page is black so its not printing. the problem is common.you need to do automatic deep cleaning for the ink flow to start once you install new cartridges.go to printer maintanance option and click the option deep cleaning .it will pull out the ink in printer head and it will start working.sometimes also requires cleaning twice. thanks and do not forget to accept the solution.
Posted on Apr 03, 2009
hsanfor
  • 71 Answers
SOURCE: changed black ink cartridge to LD brand. Now
Canon printers do not like non Canon inks. Maybe other printers have similar issues but it seems that Canon is particularly finnicky.
Posted on Jun 20, 2009
  • 107 Answers
SOURCE: printer doesn't print black
if the cartridge is not flowing...I would NOT soak it in water as that can flow back into the cartridge...remove it and use a q-tip with rubbing alcohol to clean...then you can use toilet paper to rub across it to make sure its flowing...you should get a solid black line...be sure not to touch where the electronics connect to it...if you do, clean it with the alcohol also
Posted on Aug 28, 2009
Testimonial: "Got it partly to work, but after one nice print in black... it again got worse, up until now when it won't print black at all anymore. "
HP All-In-One 4500 prints YELLOW when Black is SELECTED Could this be a PRINT HEAD PROBLEM?
The inkjet printers print colors as they combine the major 4 colors contained in the cartridges CMYK (or said in words cyan, magenta, yellow and black) in some proportion.
If you print black the printer gets ink from the black cartridge only. If the black cartridge is empty some devices start to print black as a combination of the colors in the color cartridge - for example gets some of the cyan, gets some of the magenta, gets some of the yellow.
In your case maybe some of the other colors are empty too (or the nozzles are clogged) and the printer cannot prepare the correct mixture of colors to start printing black.
I suggest you to change both black and color cartridges.
Hope this helps.
Sep 12, 2011 | HP Officejet Pro L7580 All-In-One InkJet...
I replaced an ink cartridge because the printer stopped working and showed a message that the old cartridge is empty. However after putting the new one in but the printer still refuses to work and shows...
maybe the cartridge is wrong, release it and clean the electrical contacts, put them again one by one, if notting happen, try this
Solution As the printer operates, it moves ink from the ink cartridges into a printhead reservoir. The printer does not deliver a message when an ink cartridge goes empty, because it still has ink in the reservoir. The printer continues printing until the ink level in the reservoir falls to a first trigger point - then a message appears advising the printer owner to Replace Cartridges Soon . At this point, other cartridges that are empty but have not reached the trigger point are also mentioned in the message, to save trips to the retailer. After the first trigger point, the printer can continue printing until ink levels in the reservoir reach a second trigger point. At the second trigger point there is only enough ink left to perform vital servicing tasks, and a new message appears, saying Ink Cartridges Empty . The options offered depend on the usable inks remaining. If no options are offered, the cartridges indicated must be replaced before printing can continue. The Ink Cartridges Empty options are described in the table below: Ink colors out Option Print mode possible All Cancel None Black
AND
Cyan, Magenta, or Yellow (any or all) Black only Continue with other colors Cyan/Magenta/Yellow mode (composite black)
Text and photo quality will differ from those printed when all colors are available Light Cyan or Light Magenta (either or both) Cyan, Magenta, or Yellow (any or all)
(Black still available) Print with black ink only Grayscale
Apr 07, 2010 | HP Photosmart 3210 Printer
Printer only won't print in black
My printer did that a few months ago. I tried everything to get it printing black but in the end I had to take the ink cartridge back and return a new one. Some ink cartridges dry out when they are being shipped if not stored in proper conditions.
Mar 14, 2010 | HP Officejet 6500 Wireless All-in-One...
When printing colour, black appears green
A worn out printhead can allow inks to contaminate each other, after cleaning you need to check your cartridges, if yellow is a brown color, you are getting contamination and need to replace the printhead. Black is hard to tell but when cyan gets too dark it's contaminated as well.
Aug 12, 2009 | Canon BubbleJet i560 InkJet Printer
Wont print black
Change the black ink cartridge.
Jun 08, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Black ink simply won't work
go to the control panel for your printer and disable mixing colors for "black" ink
Jun 05, 2008 | HP Business Inkjet 2230 Printer
MFC-420CN does not print black
My yellow cartridge was doing the same thing as your black. So I took the cartridge out, and took a flashlight to see how it works. There is like a little straw on the right hand side which goes up into the printer cartridge, this I assume is to measure the ink. I took a needle and cleaned that 'straw' thoroughly. Reseated the ink, ran cleaning and test print, and then the printer found the yellow ink! You could give that a try. It might work for you too. (I have never used any ink but Brother ink in the printer, btw.)
Apr 20, 2008 | Brother MFC 420CN All-In-One InkJet...
Can we print with other three Color ink cartridges when Black Ink cartridge is emptied?
hi,
as u have ran out of ink you cant print anymore... you have to replace a new ink cartridge.... this is because when u print something, the colors will get mixed to print the exact color.... even if u are printing only in black, some other colors wil get mixed to produce the black color on the paper... so u need to change the ink cartridge.... u cannot run with a blank filled ink cartridge.... and the selection of your printer is very good...
thanks and regards
agnel
Mar 19, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
Ink Cartridge Settings
Have you tried Canons FAQ? They suggest checking the grayscale box, which apparently only works with certain kinds of printing (duplexing and borderless will still use colors). I don't understand how colored inks are used to create black, but that's what they claim. Anyway, here's the link: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=257&modelid=11641
Jan 29, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Canon PIXMA MG5320 All-in-One Printer Logo
113 people viewed this question
old marine
old marine
