Question about Dryers
Maytag neptune model mde5500awy
Sound that alerts you to drying cycle complete continues even when items removed from dryer. Can't figure out why because we turned off dryer and it continues making sound. Only way to stop is to unplug. What could be causing this?
    Prodigy:
    An expert who has answered 500 questions.
  • 512 Answers
Short on control board
Posted on Mar 24, 2014
4 Suggested Answers
frankgant
  • 250 Answers
SOURCE: Maytag Neptune dryer timer won't stop
If the timer is not stopping as it goes around then it's for sure the timer. The timer does pretty much all the work with controlling the dryer. And if it's physically not stopping going around then it has broken.
Posted on Jul 08, 2008
mc1bean
  • 3053 Answers
SOURCE: My Maytag Neptune dryer makes a horrible noise
Hello, imcclain I was trying to help you out here. I wasgoing back to some customers that asked questions in the past and it appearedthat no one answered them, so I thought I would take some of my personal timeto see if I can help. Here is a link to about everything you want to know aboutyour dryer, from repair to trouble shooting it. If you go to this link andclick around, I am sure you will find out so much about your dryer, you willknow more that the company that made it. Here Is the link for you to click onhttp://home.howstuffworks.com/how-to-repair-a-dryer.htmPlease if this helped you at all, if youcan find the time to rate my help and some kind words written would beappreciated for my free help , I would appreciate it. Here is also my direct link to my own pagesof other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks So Much, Mike http://beta.fixya.com/users/mc1bean
Posted on Oct 26, 2011
  • 16987 Answers
SOURCE: maytag neptune model mde5500awy
There is a spec sheet for that machine under the drum, take the bottom panel off and look for an evelope or a clear bag. IT will tell you the tests that you can run to diagnose the issue. One of the common complaints is that unless the drum is packed full, clothes dont brush up against the sensors enough to tell it how moist they are. Then the dryer shuts down thinking that it is done.
Posted on Jan 20, 2014
Jan 20, 2014 | Dryers
My maytag neptune dryer is taking twice as long to dry cloths. i've had it 5 years & it's gas.
Clogged Vent
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But...if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Cycling thermostat
Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork . This thermostat usually has four wires going to it. Check the 2 terminals that are opposite each other and are the closer together of the 2. These 2 terminals should have continuity. If not replace the thermostat.
This is a free answer, Please rate me.
Oct 05, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Dryer not dring clothes completely
need to check your vent duct. if clogged it won't let the air flow through the dryer needed to dry your clothes.
Jun 24, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Matag NeptuneDryer MD5500AWW - intermittent heat - not drying
this is joyce
It is as you guessed your sensor. it is usually located in door but some models are in back of machine on inside, go online download document papers go to maytag.com put in model# and then download your model # and it will show you where your sensor is located, it should be simple to replace. I had the same problem with my dryer.
I am glad you said you checked the dryer lines because if these get clogged up they will cause the dryer not to dry the clothes correctley. very smart....if you need me to help let me know.
thanks,
joyce
Feb 03, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Nepyune not drying completely
There is a cheap PDF repair manual on eBay for this model. It is item number 200258764242.
Premmy
Oct 14, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune Dryer
You really need a volt / ohm meter to check for Continuity & Volts
Its well worth the investment... $15.00 bucks give or take a few
I would check to see if you have 220v to back of dryer where the cord mounts to dryer,
If dryer is getting only 1 leg 110 volts instead of the 220 will it not heat.
Check themostates & heater for Continuity... Most models, Now have a.. Hi-limit fuses that need to be checked for Continuity
Oct 14, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
Top Dryers Experts
