Question about Scag SFZ61-730FS Freedom Z Zero Turn
Have a 2008 freedom z with a Kawi engine, it has about 220 hrs. On it. I changed hydraulic fluid fluid after 200 hours. Just started to get it ready for the new season, noticed hydraulic fluid, under
How would I go about to check and fix this leak?
  • Scag Master
  • 2,478 Answers
Did you change the filter? The o-ring on cover is could be why leaking.
Posted on Mar 26, 2014
Bucket goes up but don't want to come down very slow. All other hydraulics good. Hyd.fluid and filters changes 30 hrs ago
It's possible your hydraulic control manifold valve linkage needs adjusting, or some internals in your manifold shuttle valve came off.
Mar 09, 2016 | Garden
My sons Clutch would not engage or for that matter it would not do anything
You didn't use DOT5 brake fluid did you. DOT5 brake will swell some types of rubber and aerate the fluid which becomes compressible.
Apr 20, 2015 | Cars & Trucks
On our 20 generac a notice came up tat it needed a oiland filter chnge we did thisbut the message is still there hodo we get his message off andmke thhe light on the side go off thanks
The yellow LED is a maintenance reminder light. To reset a maintenance reminder, press the Enter key on the control panel. The reminders will be displayed at the following intervals.
"Inspect Battery" 1 Year
"Change Oil & Filter" 200 hours or 2 years, 100 hours or 2 years on 20kW models
"Inspect Air Filter" 220 Hours or 2 years
"Change Air Filter" 200 Hours Or 2 years
"Inspect Spark Plugs" 220 Hours or 2 years
"Change spark Plugs" 400 hours or 10 years
Here are a couple of links
5875 Resetting maintenance reminder light question Ziller Electric Inc...
Dec 31, 2014 | Generac Standby Generator - Residential -...
How to check hydraulics on toro timecutter z480
check the fliud level and chang filter and hydro fluid this might let it start working again if dont look at buy new hydrstatic pump about 200 hundred dollars pump goes bad if oil is dirty or if low on fluid
Aug 25, 2014 | Garden
Whining sound jd 4510 four wheel drive
accord to my books this tractor has a wet clutch transmission (12 speed) , first thing is to ck your fluid level in transmission , this is bit hard to reach on this one but is possible second obtain a small sample of fluid from transmission, have it tested , It can tell you alot , second you mention that hydraulic pump overloads engine with simple tasks like raise 3-point, this could be a stuck pressure relief valve due to yep you guessed it dirty filter (it bypassed itself) ck hyd fluid for proper level and clarity ohh and one more thing this tractor uses hyd pump for power steering (some others have 2nd pump for this) is it possible that noise is coming from that area , cus I have had to replace power steering valve on that model once for a loud Noise reason
remember if your gonna have a all hydro tractor save yourself a lot of grief and periodly wash shaft seals with water sure saves a lot of grief and leaks !!
Jun 21, 2014 | John Deere Garden
Gilare runner st 200 my 2008 runner 200 st won't start after heavy rain.
The ignition components are getting wet and the Ignition charge is being discharged down the side of the wires and not through the spark plugs are required. The next time it does not start in the wet, try spraying all the spark plug wires with wd40 and if it fires up, replace the ignition wires.
Nov 18, 2013 | Motorcycles
My toyota rav 4 is overheating iit is boiling from the reservoirtank what can i do l have changed the radiator and the thermostat checked all the hoses but it is still boiling can you help me please
Check fan operation. It should come on at approximately 102 degrees celcius.Which fan drive do you have? The older RAV 4 has a hydraulically driven fan while the later models have an electric fan. Both are "turned on by the computer". So check for the thermo sensor at the coolant outlet from the engine. As it gets toward boiling point you should find a lowered resistance of approximately 200 - 300 Ohms there. When cold these sensors run in excess of 2500 Ohms.On the older models with the hydraulic drive it is provided with hydraulic pressure from a pump in the transmission. Check for transmission fluid level and pump operation by loosening off the supply hose and starting the engine in neutral. If the pump is inoperative no oil will be supplied to the hydraulic fan motor. Happy hunting.
Oct 30, 2011 | Cars & Trucks
Now i somehow lost my power steering
you changed all the oils and fluids. uumm theres really not much you can do when it comes to that check the belt and if thats not it get a new pump
Mar 27, 2009 | 1989 Audi 200
Troubleshooting
High pressure fluid is present in operational hydraulic systems. Fluids under high pressure are dangerous and can cause serious injury or death. Do not make modifications, repairs or adjustments to any hydraulic system unless you are competent or working under competent supervision. If in doubt consult a qualified technician or engineer.
Aug 27, 2008 | Stanley 60 220 20 Piece Screwdriver Set
Scag SFZ61-730FS Freedom Z Zero Turn Logo
266 people viewed this question
Top Scag Garden Experts
JP Services
JP Services
Ted Maxwell
Rick Oudette
Rick Oudette
Level 1 Expert
Are you a Scag Garden Expert? Answer questions, earn points and help others
