Question about Garden
Lawn mower will not shift forward or in reverse
How can we get into shifting place to look at it
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 37 Answers
There is a few problems that would cause this. Does the shiftier move when trying to put it in to gear? If it does then there is something wrong with the clutch collar or the shift fork lawn mower will not shift forward or in reverse - 26e2a13c-665f-4308-b04b-24e348fc5a3e.jpg
Posted on May 09, 2014
SOURCE: Murray Riding Lawn Mower won't start or move
The Drive Belt keeps coming off as soon as I engage the mower I replaced the Drive Pulley and put on a new belt but it still comes off. Any Ideas.
Posted on Aug 15, 2009
  • 396 Answers
SOURCE: wont move forward or reverse-- transmission??
Does it have gears or a hydrostatic (automatic) transmission?
If it's a gear model, sounds like a loose drive belt.
If it's hydrostatic, it could be a belt problem or a problem inside the transmission. If it's a tranmission problem, this is not good. Many of the transmissions on riding lawn mowers are not serviceable - they are just replaced.
Posted on Oct 10, 2009
SOURCE: Loss of drive in a Craftsman Lawn tractor
I also have a Craftsman tractor with the same problem. Sears repairman said it needed a new transmission and it would cost $1,400 to install. A new one is about $1,000. Anyway, if you remove the battery and the battery tray under the seat it will expose the transmission fill hole (hex). I opened the top and it looked empty. I had a bottle of 90 weight gear oil in my shop and filled the transmission to the top. I have not had any problems with it since. $4.00 bottle of oil verses a new tractor is worth a try.
Posted on Nov 30, 2009
kel1guy2002
  • 3740 Answers
SOURCE: lawn mower has hydro gear transaxle reverse was
Most of the time when this happens the reverse shift linkage is too short. It is usually cause by either a bent linkage or worn linkage bushings.
The internal shifting fork can be bent inside the transmission which is rare but does occasionally happen... most of the time it is a linkage problem. Also check on the side of the transmission to make sure the shifting lever has not moved from the original position on the Yoke shaft.
Thanks for using FixYa.
Kelly
Posted on Mar 29, 2010
SOURCE: Lawn mower transmission won't shift .
i have a craftman mower and it wont go in gear dont now if it is the rodes thats making it not go in gear or the trans bad do i have to be sitting on the seat for it to go in
Posted on Sep 13, 2010
Model 917.203900 22 HP lawn tractor. Shifts consistently into forward but frequently won't shift into reverse. What's wrong?
  1. Craftsman Hydrostatic Transmission Fluid Change - YouTube
    ? 40:15
    www.youtube.com/watch?v=vd1EqFtTYgk
    May 10, 2012 - Uploaded by Smokeasammie
    I change the gear oil and hydrostatic transmission fluid on my Craftsman Lawn Tractor. Fluid per Peerless ...
Jul 20, 2015 | Craftsman Garden
Why won't my riding lawnmower shift into reverse?
Some mowers will not allow you to shift into reverse with the blades engaged for safety reasons. Try disengaging the blades then shift into reverse.
Aug 22, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
make sure the shift linkage is connected and the brake is releasing properly.
Mar 22, 2014 | Garden
My lawn mower model 425613x8a only drives in reverse what is my problem and how do I fix it?
I'am not to familiar,with this model number,of this tractor. But i do know that there is a safety switch,installed below the shift lever. Usually this switch,controls the neural,forward and reverse for your tractor. I suspect the forward motion contact is bad in the switch itself. You will have to remove the motion drive assembly and purchase a new switch,sometimes the safety switch is part of the whole assembly. You can find this assembly,under the shifting lever under the tractor,s floor. It could be on the right side or the left side depending on the location of the shifting lever.Sincerely,Brad Locke DTD 12/03/15
Sep 07, 2013 | Sears Garden
My old Cub Cadet riding lawnmower will drive in reverse only. It will not drive forwards. Is this a transmission issue or shift linkage?
mine was operating in forward not reverse it was the linkage adjustment under the pedal one clip and turned the stud
May 21, 2012 | Garden
Lawn mower has hydro gear transaxle reverse was
Kelly
Mar 29, 2010 | Craftsman Garden
Tractor will not go in forward gear, only reverse.
Try rocking the mower forward and backward while you try to shift it.
Aug 19, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Stalls when engage blades in forward, but cuts fine in reverse
Did you try to disengage the safety feature that should shut the tractor off when the blades are engaged and the tractor is placed in reverse? I believe that it is located under the shift leaver
May 14, 2009 | Mtd Garden
Garden Logo
67 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
