Question about Frigidaire FRT15G5CS Top Freezer Refrigerator
Want to raise the main cabin door 1/2 inch Lt side, lt side open
Frigidaire FRT15G5CS Top Freezer Refrigerator Just bought a new Frigidaire topFreezer Refrigerator, Want to raise the main cabin door 1/2 inch Left side, Door opens from left side. I can see the white body (5mm)of the cabin, I think the cold is escaping from the cabin. Any Solutions Please? Girish
tborn6
  • 700 Answers
SOURCE: Freezer door not sealing well (Frigidaire side-by-side)
your house may be settling and now the refrigerator needs to be tiloted back slightly. take run the adjusters on the front in a little until the doo closes by it self.
Posted on Mar 29, 2009
  • 105 Answers
SOURCE: refrigerator door pops open, frigidaire top
The refrigerator needs to be perfectly leveled side to side dn should pitch back slightly. Also look at the plane of the doors, that is to say that they should be squared to the cabinet. If they are sagging, you may need to adjust the hinges.
Posted on Apr 17, 2009
SolutionGuy
  • 331 Answers
SOURCE: Side by side doors uneven at top
Hi Carol,
Interestingly enough, I answered a similar question just the other day. Maybe there's an outbreak of lazy factory technicians who "forget" to tighten the hinge brackets? Hmmmm. Makes on wonder...
Anyway, it's easy... The door alignment adjustment is done at the top hinge. Pull up a step-stool, then remove the hinge cover. Under there you'll see three screws, I think they're 5/16". Loosen these (since your door has dropped, they're probably already loose), then lift up on the door handle to align it with the other door... while keeping the door aligned, tighten the hinge screws (and put alot of torque on 'em to keep 'em from loosening in the future). Now just replace the hinge cover and your done!
SG
(pssst!... don't forget to rate me, will ya? C'mon, throw me some love.)
Posted on May 29, 2009
  • 4 Answers
SOURCE: Frigidaire Gallery side by side not working
You must reset the icemaker. There is an off / on button. You might have to remove the ice container. Mine is above the container at the back of an upper shelf. First, turn the switch OFF for about 30 seconds. Now, turn the switch ON, then push it tightly inward in the ON position for about 30 seconds. This will "jump start" your icemaker and you shouldn't have any more problems.
Posted on Jul 14, 2010
  • 1218 Answers
SOURCE: beer tap
Good day,
If it has the condensor coil mounted on the back of the machine.
(black coil) then yes, VERY DANGEROUS. Refrigeration lines run at an angle from the bottom back of the machine at an angle and terminate at the bottom of the freezer door.
This applies to both sides. Hit one of those and your finished.
Posted on Jul 21, 2010
Testimonial: "Thanks for the warning. Is their a way to still do it without hitting the lines? Is it just one line running up and the rest of the side is clear?"
How do I raise the level of my refrigerator door to be even with freezer door?
Thank you for your inquiry, Leland Dodd!
I see that you are having difficulty in raising the level on your Frigidaire refrigerator, FGHC2331PF. I have reviewed your manual and there are two types of adjustment for either front rollers or lower hinge. If you are having issues with adjusting the doors or leveling your refrigerator I would recommend having a professional technician out to properly level your refrigerator. Best of luck! -Matt
Dec 03, 2014 | Frigidaire FGHC2331PF Gallery 23 Cu. Ft....
The refrigerator,not cold enough,and don't make ice. I have a refrigerator type Frigidaire door side by side.
I would try <a href="http://www.atlasappliances.com/en/catalog/923-Kitchen/41-Refrigeration">refrigerator repair in Calgary</a> to see if they can help you.
Oct 31, 2013 | Frigidaire Refrigerators
Frigidaire FRT17G4BW9 doors not staying closed
Adjust the front legs of your refrigerator slightly to raise the refrigerator. and and store items on the freezer door shelves to add weight. This is a problem of pneumatics and a testament to how tight newer refrigerators are. When you close the large refrigerator door it compresses the air in the refrigerator compartment. Both compartments are connected by air passages and thus the pressure change is transferred to the freezer causing the freezer door to pop open.
Raising the front of the refrigerator a tiny bit will help both doors close from the 90 degree point, which is desirable. Adding weight to the shelf will just help the process.
An additional aid in self-closure will be to use vegetable oil on a paper towel to wipe down the hinge side face of both door seals. All these maneuvers should aid in causing the door to stay closed and re-close if it should open slightly. Good Luck
Aug 23, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
The refrigerator is not getting or staying cold enough. the freezer seems to working ok
Check the vent at the top of the shared refrigerator wall for cold air from the freezer. If not, then you can either replace the motorized flap inside the vent or prop the flap open with a stick or something. The manual solution won't harm anything. The motorized flap is an over-engineered solution designed to create service calls. :<)
May 21, 2009 | Frigidaire FRS3R5EMB Side by Side...
Water Leaking - Freezer
My mother's fridge had a leak on the freezer side in the front. I removed the cover below the doors and found a plastic coupling in the water line to the water in the door option, when anyone filled their glass with water the coupling leaked. I bought a new plastice 1/4 inch coupling and replaced the old one and the problem was solved. The coupling costs about $3.00 a Lowe's and it took about 2 min. to change.
Apr 18, 2009 | Frigidaire FRS26R4A Side by Side...
Refrigerator door pops open, frigidaire top
Apr 17, 2009 | Frigidaire FRT21H8 Top Freezer...
Light switch
correct, you can either take off the refrig door and place asmall shim under the hinge raising it an 1/8 inch or soor you can slightly pry down the light switch from the liner, and fill the small gap created with a small bead of silicone
Oct 23, 2008 | Frigidaire FRT21H8 Top Freezer...
Side by side frigidaire
check the evaporator fan motor, behind the back wall of the freezer. If that is turning check if the damper is opening, top lt of the refrigerator compartment. I hope this helps you.
Jul 09, 2008 | Frigidaire FRS3R5EMB Side by Side...
Bottom Part
Have you inspected the door gaskets .escpecially at the bottom.Make sure your not getting any air through the door seal,Whats the temp in freezer?
Jun 15, 2008 | Frigidaire FRT15G5CS Top Freezer...
Bottom is too warm
Make sure your fan is working ,its in the freezer behind panel .If not the fan your passage area is probably covered with ice and the air cant get in freezer
Jun 14, 2008 | Frigidaire FRT15G5CS Top Freezer...
Frigidaire FRT15G5CS Top Freezer Refrigerator Logo
29 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
