Question about John Deere Garden
My John Deere D130 won't go into gear.
This happened after I removed/replaced the deck and rear tires. The transmission bypass lever is pushed in. Real wheel axle pins are in place and the drive belt is attached but it is very loose. The drive belt is not moving.
  • cass taaning Mar 22, 2014
    Rear wheel axle pins are in place
  • cass taaning Mar 24, 2014
    Problem solved. When I put the real wheel on the axle pin fell out. Found, replaced pin and it's good to go.
panilling9
  • 284 Answers
SOURCE: Need to remove rear wheels to replace tires on MTD riding mower.
most likely rust has taken over
find some liquid wrench or pb blaster and spray the axles liberally and let it penetrate the axles and wheel hubs where the axle goes through.
use a 2x4 and a hammer to tap against the wheel hub to try to move it down the axle then tap in back on to try to free it up as the penetrating oil works in, spin the wheel and tap in different areas of it
the worst case cenario would be to use a torch and heat the axle and hub up and drive it off, but it sounds as though you are moving it some and with some patience they eventually should come off
when you put them back be sure to coat the axle with some grease and do not forget to reinstall the key stock in each wheel, if they have it
the bolt in the center of the axle is all you need to remove and note where the washers came from and where they go back.
hope this helps you some
Posted on Jun 14, 2009
  • 21 Answers
SOURCE: john deere stx38 wont move transmission locked up?
Engine OFF, raise drive wheels and check if transmission is locked
Posted on Jul 14, 2009
mickey813
  • 472 Answers
SOURCE: have a john deere 115 and the drive belt came
ya that be were id start
Posted on Oct 05, 2009
spiegela
  • 3 Answers
SOURCE: john deere 445 tractor v twin 22 hp engine, john
Where did you get it fixed for $300. Dealer wants 6 hours labor and $400 in parts. Total cost will be $1,000.
Posted on Jun 05, 2010
SOURCE: John Deere 185 deck height adjustment
having a problem with dive belt being hit by the mower deck 185 john deere suggestions !!
Posted on Jul 16, 2010
Price on a john deere 130 with 48" deck
the d130 is about $1,900.00 but does not come with a 48 deck a 42 to have a 48 would have to be special option
D130Lawn Tractor
Aug 11, 2016 | John Deere Garden
Why will my Gx325 John Deere not go in forward or reverse
For a more precise answer give the Year/Hours on Meter, and a brief description of the events prior to the problem. When did it last run correctly? What has happened since then?
The first questions that comes to mind...
  1. Can you manually push the mower around?Easily?
  2. We need to know if the brakes are locked up?
  3. We need to know if the transmission bypass lever is in or out?
  4. With the bypass lever out, brakes off, can you roll the machine?
  5. Is the bypass lever still properly connected and unbent?
  6. Looking under the machine (right in the center above the cutting head) are the drive belts intact?
  7. Do the drive belt idler pulleys/bearing look ok?
  8. Is the drive belt engagement plate still connected to the foot pedals?
  9. Does the pulley wheel and fan on the transmission spin when the motor is running? (is power going to the transmission?)
These are your first things to check. You may have to remove the cutting head to fully examine these things.
Mar 10, 2015 | John Deere Garden
My john deere la 105 will not go forward or reverse, what's wrong?
Check your transmission belt from engine to rear diff. Up high above the deck belt. Its either broken or off its pulleys possible
Sep 24, 2014 | John Deere Garden
Why wont my john deere d140 move when I ngage the double foot pedal
The drive belt may be broken, or it may have slipped off a pulley.
Aug 03, 2014 | John Deere Garden
My john deere L130 with hydrostat won't drive,eng is fine
did you knock the drive belt off?did you pull the lever that allows you to push it when not running?
Aug 15, 2012 | John Deere Garden
How do i bypass the yellow button you have to press when cutting whilst driving in reverse on a john deere d130. i tried just unplugging it but then it wont cut atall..... i think there must be a wire
hello rich, as far as i know there is no way to bypass the reverse safety button,this was put on there for your protection and by law to keep from backing over people such as children and animals,,hope this helps,
Feb 17, 2012 | Garden
How do you change to rear tires on a peg perego john deere turf tractor?
remove the center caps from the tires then the metal push washers then slide the tire off, don't pull the axle out, there are spaces by the gear boxes on the axle
Jul 01, 2010 | Peg Perego John Deere Turf Tractor
John deere stx38 wont move transmission locked up?
Jul 14, 2009 | John Deere Garden
The rear end on my 1987 750 4wd john deere quit working yesterday, it will still go forward when i step on the lever to engage and lock both back tires but will not move unless i do, front end works fine,...
Check first to see if the drive belt has jumped off a pulley or the belt is stretched or broken. Next if there is a grinding noise it means the transmission has a broken or chewed up gear.
Jun 24, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
69 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
