Question about Heavyduty Jazzy 1121 Standard & Heavy Duty Power Wheelchair
My jazzy 1170 XL will not move slow on right, all lights on controller are on??
Chair will charge, all lights on controller stay on,but left side wont move, right side slow. checked all conections, eny answers
4 Suggested Answers
SOURCE: Jazzy 1121 power chair won't go
It may not be the joystick. I have had the same problem before. The edel cable that goes from the joystick to the back of the wheelchair could be bad. You can try unplugging it and plugging it back into the joystick. Check the prongs on the cable and make sure their not broke. You can also try flipping the switch that is located down by the charger under the chair. The cable is around $200 and the joystick is quite a bit.
Posted on May 16, 2009
  • 692 Answers
SOURCE: jazzy 1121 power chair won't charge when plug in
you have either bad batteries or a bad charger or the charger might have come unplugged at the controller or power module. When you have the charger plugged in and you turn on the joystick the lights on the joystick should ripple to indicate the charger is plugged in. If you don't see this ripple then either the charger is bad or disconnected. Trace the charger cable from the rear of the chair (you have to remove the seat and shroud to do this) to the front module and make sure that the cable is plugged in. Hope this helps
Posted on Oct 23, 2010
SOURCE: My Jazzy select wheelchair does not run
According to the troubleshooting sheet, the parking brakes have a bad connection.
"9 Flashes:
The park brakes have a bad connection. Check the left and right motor connections and
wiring.
Check to make sure that the power chair is
not in freewheel mode."
Pride Mobility Troubleshooting Sheets
Posted on May 19, 2013
Jazzy 614HD will not move. Lights flash from right to left, then cuts off. Unlock instructions are not effective. Chair is fully charged.
If chair has a tilt, recline or lift seat on it it may be going into lock-out mode on its own due to a limit switch fault. If you don't have any of these options then I suggest you remove the joystick, controller and any wire harness between the two and send them to a shop like mine for repair.
The usual lock out light chase is from left to right - not right to left so this is suspect of a different issue.
Dec 28, 2012 | Pride Jazzy 614 Hd JAZZY 614HD
I just replaced the batteries in my Jazzy 1170 PLUS. Now my speed control lights blink constantly and the chair is totally unresponsive.I have double checked to be sure the freewheel levers are totally...
According to my 1170 manual the flashing lights are error codes. 1 red = low batt., 2 red = left motor disconnected, 3 red = Left motor wiring fault, 4 yellow = Right motor disconnected, 5 yellow = right motor wiring fault, 6 yellow = Inhibit active, 7 yellow =possible joystick fault, 8 green = possible controller fault, 9 green = Solenoid brake fault, 10 green = high batt. voltage
Feb 13, 2011 | Pride Mobility Products Jazzy 1170 XL Plus
CONTROLLER LIGHTS UP OK AT START. BUT IF U MOVE THE JOYSTICK, ALL THE LIGHTS FLASH RAPIDLY AND IN UNISON. WHAT FAULT DOES THIS REPRESENT?? THX U
I think you might have a joystick fault but first make sure that the chair is not in freewheel. If the chair is not in freewheel then you have a joystick problem and it will have to be replaced Hope this helps
Feb 12, 2011 | Pride Mobility Products Jazzy 1170 XL Plus
Lights Flashing Right to Left and will not turn off
That should have unlocked the controller. You might try disconnecting the power to the chair and then reconnect and try again. Start with just the joystick plug-in in the rear, and then try the main battery harness unplug.
May 22, 2010 | Pride Mobility Products Jazzy 1170 XL Plus
Chair no longer charges, no flashing or blinking, lights,
The number of lights that are blinking indicate what the problem is. Visit this site to locate the type on controller on your power chair and you will be able to see that the blinking lights mean:
http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Try to reset your manual brake release as this is a common problem.
If you continue to have a problem, contact your manufacturer or dealer for service. If your insurance purchased they power chair for you, they may also cover the cost of repairs.
May 07, 2010 | Pride Jazzy 1103 Ultra Standard Power...
Jazzy 1420 not 1170
sounds like the wiring from the motor to the controler is not making good connection, try unpluging motor wiring from controller box. Use a plastic safe elec. contact cleaner and lube spray on connections. water in the joystick can also cause this.
Jan 05, 2009 | Pride Mobility Products Jazzy 1170 XL Plus
Jazzy wheelchair 1170....left side stops and sticks,.
Change out the motor brushing on the motor that is not working, or get a nail filer & rub it against the metal pins the back of the chair for a better connection
Nov 30, 2008 | Pride Mobility Products Jazzy 1170 XL Plus
Heavyduty Jazzy 1121 Standard & Heavy Duty Power Wheelchair Logo
56 people viewed this question
Top Heavyduty Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Heavyduty Health and Beauty Expert? Answer questions, earn points and help others
