Question about Kwikset Smart Code
Kwikset smartcode parts
The small motor that drives the lock is dead where could I purchase the motor wrote to kwikset they don't sell parts
    Scholar:
  • 101 Answers
It might not be the motor. It could be the electronic circuit that powers the motor. I ran into the same problem with a Kwikset electronic deadbolt. I separated the motor from the electronic circuit board and found that the motor was OK. When I couldn't get replacement parts I bought a Master Lock unit. It's not motorized and uses 4 AAA batteries, which last a long time. Kwikset just wants to sell locks, but the same problem exists with Schlage and other brands - including Master Lock. One year warranty on electronics.
Posted on Apr 10, 2014
  • 963 Answers
SOURCE: I'm using a kwikset smartcode
I have reviewed the installation instructions for the Kwikset 907-11P; here is a link to it:
http://s7d5.scene7.com/is/content/BDHHI/40486-02
I would recommend verifying that the batteries are new and installed correctly. I did not see anything about an insertable/removable battery pack or the need to hold a lock button while changing the batteries. Under normal circumstances there is no need to reprogram the lock codes when batteries are changed.
I did see that if the bolt does not extend when the lock button is pressed that you need to reprogram the handedness of the door (see Step 4.9).
On page 9 of the installation instructions is Troubleshooting tips and a contact number for Kwikset USA :
1-800-327-5625. I'd recommend calling them directly if, after going through the installation instructions, that you have the same problem.
Posted on Apr 26, 2011
  • 963 Answers
SOURCE: H do I reset all
This link will take you to the PDF image of the installation and programming instructions:
http://s7d5.scene7.com/is/content/BDHHI/kwikset-smartcode
(PDF files require that you have Adobe Reader or similar installed on your computer
http://get.adobe.com/reader/ )
It's a good time to replace the batteries while you're reprogramming. Please review each step carefully, because it's easy to goof up this programming process, if you don't follow the procedure properly.
Posted on Jun 27, 2011
  • 963 Answers
SOURCE: Kwikset smartcode deadbolt. The
Let's review the programming steps, in case you are overlooking something. This information was found at this link:
Important before proceeding: 1. Verify that position #2 of the "Settings
Switch" is in the OFF position. (Refer to section 11.) 2. Work with the
door open (away from jamb) to avoid accidental lock out. 3. Make sure
the bolt of latch is in the extended (locked) position
8. Automatic - Bolt Direction Determination (Door Handing).
IMPORTANT: DO NOT SKIP THE FOLLOWING STEP.
LOCK WILL NOT BE ABLE TO OPERATE PROPERLY!
? In the steps below, the SmartCode mechanism automatically determines the "door handing" and sets the proper direction for motor to rotate.
a. Press and hold the "LOCK" button on the exterior keypad, while fully inserting the battery pack into the interior assembly (the tabs on the pack must face out)
b. When the unit begins to operate the bolt, release the "LOCK" button.
c. Do not disturb the unit for approximately 20 seconds until the interior Green LED flashes followed by a beep. During this time the system will drive the bolt several times, will determine "door handing", store data in memory and exit. It is very important that this process is allowed to finish properly.
Proceed with programming your Usercodes per the instructions.
Finally, here is the contact number for Customer Service At Kwikset. Call them if you still have the problem.
1-800-677-5625
Posted on Aug 04, 2011
  • 963 Answers
SOURCE: How do I change the lock to operate with my
Watch this video:
http://www.kwikset.com/Customer-Support/How-To-Center.aspx
Posted on Nov 08, 2011
  • 963 Answers
SOURCE: What's is the standard preprogramed code for smartcode locks
If there was a standard preprogrammed code for locks, given that there are many people either too lazy or too stupid to reset their own unique lock code, thieves would be having a field day. Therefore, there is no standard preprogrammed lock code, for digital locks or digital safes.
Posted on May 07, 2012
Reset code kwikset
Here is the link to an excellent video of how to install, hand, and program the Smartcode 909. It includes switch-0controlled features of the lock:
http://www.kwikset.com/Videos/Vitro/smartcode.aspx
Sep 18, 2012 | Kwikset 909 909-15 Satin Nickel Smart...
Need to reset code
Here is an excellent video of how to install, hand, and program the Smartcode 909. It includes switch controlled features of the lock:
Installation instructions:
Jul 17, 2012 | Kwikset 909 909-15 Satin Nickel Smart...
Need to reset program numbers
Here is an excellent video of how to install, hand, and program the Smartcode 909. It includes switch-controlled features of the lock:
Everything you need to know about your lock!
May 06, 2012 | Kwikset 909 909-11P Venetian Bronze Smart...
None of the buttons on the device will work. Batteries are fine and blinking light inside appears normal. Cannont lock the device from outside or get the code to unlock the door.
Check to be sure the keypad is still connected to the inside assembly. There is only a one year warranty on the electronics and Kwikset will not sell the electronic parts separately. If you want to replace it, there are other brands that are key-compatible with Kwikset. You'll still have the same problem if the electronics breaks though. The main difference is that other brands don't move the bolt with battery power, they just enable it to be moved by hand.
Aug 06, 2011 | Kwikset 909 909-L03 Lifetime Polished...
Kwikset smartcode deadbolt. The lock button unlocks it the code locks it. I followed the handing instructions and tried the bolt in both positions while doing that procedure after the initial problem.
1-800-677-5625
Aug 03, 2011 | Kwikset 909 909-15 Satin Nickel Smart...
I lost my instructions to my lock, and I need to change my codes but i don't know how.
Here is the link to the installation and programming instructions for the 909-15 lock:
It is a PDF file format, which requires that you have Adobe Reader installed on your computer to display properly. If you don't have it--http://get.adobe.com/reader/
It is a good time to replace the battery if you haven't done so already! Please carefully follow the programming instructions, because they can be tricky. If you goof up, simply start over.
Jul 02, 2011 | Kwikset 909 909-15 Satin Nickel Smart...
H do I reset all the codes and establish a new one on a Kwikset 909 909-L03 Lifetime Polished Brass Smart Code SmartCode.
Jun 27, 2011 | Kwikset 909 909-L03 Lifetime Polished...
Dead bolt does not align with the keypad, every time i turn the dead bolt it only goes in so far then i hear a click, and if i push the lock button it doesnt turn i hear a continuous click then the keys...
I have included a link to the installation instructions for the Kwikset 909 lock. I think that if you go through the installation instruction routine carefully, you will solve your problem. Pay particular attention to Step 8, the synchronization routine.
Apr 16, 2011 | Kwikset 909 909-15 Satin Nickel Smart...
Kwikset keypad deadbolt will not lock or unlock. Batteries OK.
Apr 10, 2011 | Kwikset 909 909-15 Satin Nickel Smart...
The dead bolt handle started turning the wrong way so cant use code only key and now if i put a code in nothing happens but when i hit lock i closes the wrong way
Here's the info on your lock:
http://www.kwikset.com/Products/Details/Electronic-Locks/909-15-SMT.aspx
Clicking on the link "Installation Guide" will take you through the programming steps:
I think you'll find your answer there.
Mar 03, 2011 | Kwikset 909 909-15 Satin Nickel Smart...
Kwikset Smart Code Logo
149 people viewed this question
Top Kwikset Locks & Locksmithing Experts
Jim Thurston
Mike
J.D. Browning
J.D. Browning
Are you a Kwikset Lock and Locksmithing Expert? Answer questions, earn points and help others
